Boy this car likes the warmth I Blocked front grille to experiment
Discussion in 'Prius c Fuel Economy' started by hoarybat, Oct 25, 2012.
  1. hoarybat
    hoarybat Junior Member
    24
    I am sure others have experimented with other C's with this but after some extreme hypermiling to work RT almost 14 miles RT to work and another stretch of 24 RT stretches,s (I know not a lot of miles) in my PC2 and finally getting some cooler temps here in NewEngland I checked my mileage.
    Summer: 3 trips outside air temps mid 80's: 99 mpg 95 mpg 97 mpg
    Early fall ... temps mid 70's 81 79 82
    Yesterday without modification. temp. 54 62 mpg 64 and 63
    (Modification see below) temp. 54 72 mpg 73 and 72
    I realize other things are affected by the warmth which may increase mileage but the engine turns on a lot less obviously when it is warm out even when the battery is charged. I also had no lights or heater on or A/C when I did these seasonal tests and prewarmed the engine (a few seconds) before starting every RT. I am sure if I had put more miles the difference would have been less as a percentage but blocking the grille must have had an effect as seen. I used kitchen bags taped to bottom and under hood. My wife's (lead foot) mileage mostly highway some back roads has gone from 54mpg to 49. Still very good for her. HERE ARE THE GARBAGE BAGS:
  2. chicagoaficionado
    chicagoaficionado Junior Member
    57
    Chicagoland
    Pics don's show up! RE-upload
  3. hoarybat
    24
    Daze likes this.
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I have a Gen III and was wondering if Toyota placed the inverter in another location on the C? On the Gen III your not suppose to cover up the inverter which resides in the upper open part of the grill. Just checking, I may be off base with the C.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    You drove it like that? :p
    Take that crap off and go to Home Depot for pipe insulation. LOL
    sdtundra, PriusCinBlack and WE0H like this.
  6. napmaster
    napmaster Junior Member
    MA
    lol I can't believe you drove it like that. :sick:
    Daze likes this.
  7. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    very stylish :)
    But interesting result.
  8. hoarybat
    24
    LOL only for one day. I'm an engineer so it is function over fashion. Yes I've been planning on using dark grey pipe insulation which matches our color perfectly but before buying I wanted to confirm that blocking would increase mileage. Somehow I now have to slip in the insulation without telling wifey. She frowns upon my experiments! Thanks all...
    ElectronFlux and RocMills like this.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    If you slip it in and tuck the edges she may never notice. ;)
    Dylan Murphy likes this.
  10. rjdriver
    409
    170
    Rhode Island
    Now that actually makes a nice contrast with your paint color. Hmm........I wonder if they make the stuff in red.....?
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    There is always PlastiDip. ;)
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nice expedient proof of principle test!
    It would be a really good idea to monitor important temperatures with a ScangaugeII, Torque App on an Android device or some other OBD-II monitoring device.
    ProZach likes this.
  13. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    You'd be pulled over in a heart beat in my neck of the woods for covering up the license plate like that. Get some pipe insulation ASAP!
    For those wanting some bright color contrast, may I suggest water noodles. Probably get them pretty cheap right now in the off-season. :)
  14. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Soo... the grille is there to vent. Aren't there circumstances where this will cause overheating and bad consequences?
  15. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    Have mine blocked, was unseasonably worm the other day. About 75+ drove on highway and engine temp did not go higher than when it is 40.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yes, that's why it's done during cool to cold weather and you should be watching temperatures when you do it.
  17. Mendel Leisk
    41,149
    With the regular Prius one guru cautions against full block of the upper, since the inverter radiator is there. Until you know what's what I'd be inclined to keep some open on both top and bottom. The inverter radiator would be full width but with short vert. dimensions, say around 4".
  18. Revan86
    286
    84
    What do base this claim on. I don't mean that to should argumentive, just asking.
  19. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    So the photo displayed by F8L, the red car with the dark piping... is that sufficient grill blocking? As it seems a block heater will not suit my needs, I'm looking for alternatives. Is that just wedged in there? If not, what sort of adhesive was used?
  20. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    I blocked mine off today as an experiment. Went for a drive afterwards and noticed a dramatic improvement in the temp inside the car :) I just spent $3 for 3 pieces of pipe insulation...the smallest size they had. I cut slits for the vertical pieces and just slid it into the crevices. The area behind the bottom of the license plate is open as it was difficult to get to and I figured it needs some air. It is easily removable if I have any problems.
    RocMills likes this.
