My EV Driving ratio
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 31, 2012.
  1. bisco
    52,863
    just had a brutal tank. did a lot of long trips. only 900 miles and my last pip is blinking. 60/40 hv/ev ratio.:(
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    40% EV is still great.
    I did 4 miles round trip for lunch and 5 miles for dinner. My EV ratio raised to 30%.
    On Sunday, I am going to the Giant stadium for a game so I am expecting my EV ratio to come down.
  3. bisco
    52,863
    go pitt!:cool:
  4. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Where is the dislike button? ;)
  5. bisco
    52,863
    two superbowls in the final moments? what's to dislike!:rolleyes:
  6. RBooker
    RBooker Member
    154
    56
    322 miles
    62%:38% EV:HV ratio
    Commute 4 miles each way top speed 45 mph
    drinnovation and usbseawolf2000 like this.
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    What are your consumption for electricity and gasoline?
  8. RBooker
    RBooker Member
    154
    56
    202 miles 52 Kwh unadjusted
    122 miles 2 gallons
    According to the car's computer I am averaging 118 mpg
    usbseawolf2000 likes this.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Ev driving ratio
    EV 65%
    296kwh
    HV 35%
    13 gal
    EV total miles 1260
    HV total miles 667
    Distance to empty 448
    Total miles 1928
    Fuel Saved by charge 24.8 gallons
  10. pip2012
    pip2012 Junior Member
    San Jose
    Ok - I'm ready to brag. Almost 5K miles and over 80% EV on it.
    It works very well for me. But, I do have to work hard at charging it. I often charge 2 or 3 times a day.
  11. Adam Leibovitch
    498
    102
    bwahahahaha, 78 gallons less sold by the oil companies! Good work!
    Rebound likes this.
  12. RBooker
    RBooker Member
    154
    56
    Very impressive! Please provide details on the strategies you employ to achieve a 4:1 EV:HV ratio.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    I totally missed where you traded in your GenII for the PIP. Congrats, bro! :)
  14. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    What are you talking about?
  15. John H
    John H Senior Member
    2,208
    558
    Torque is an Android app that talks to a OBD adapter to provide a custom instrumentation dashboard and logger.
    Torque for Android Web OBD log viewer
    The custom PIDs are vehicle specific codes for reading sensors from the OBD port, like battery state of charge, power flow, regen power, etc...
  16. pip2012
    San Jose
    I work hard at it.
    I have a level 2 charger in my garage. I use it even for 10-20 minutes at a time if I have to come home from work and then go out again soon for a short trip. Using the level 2 charger I get about 1 mile per 7 minutes of charging time.
    When I drive the carpool to school and then to work, I do stop and charge on the way and work on my laptop for the 30 minutes it takes to recharge.
    I *always* recharge at work.
    I make heavy use of chargepoint stations - even if I occasionally have to pay outrageous rates, although most chargepoint stations in the San Jose area are free. Overall, I've paid about $10 to chargepoint in charging fees in the last 7 months.
    And finally, the cheating way out - I take our 2008 Prius on most trips longer than about 25 miles. But, since it gets almost as good mileage.... Truth be told, I think I'd be at 60% if I didn't use the other Prius for those trips. And, the PiP would have gotten better mileage so overall I would have saved more gas. But, I've been actively trying to see how good a ratio I could get so I drove the other one anyway even on these longer trips.
    2 more things I do:
    I use the GPS short route option a LOT. It has helped many times to make a non-EV trip into a fully-EV trip.
    And, I also choose to drive the PiP for any trip within the EV range. So, for most trips less than 7 miles, I now drive the PiP and do not drive the 2008 Gen2.
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Including 15% charging loss, you are averaging 29.6kWh/100mi on electricity.
    You have actually consumed 2.73 gallons (322 total miles / 118 mpg = 2.73 gallons). You are getting 44.7 MPG on gas miles.
    Combined, you are getting 72 MPGe.
    RBooker likes this.
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    With the charging loss included, you are averaging 27 kWh/100mi on electricity and averaging 50.8 MPG on gas.
    Combined, you are getting 83 MPGe.
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    With 15% charing loss included:
    Electricity efficiency: 26.9 kWh/100mi (269Wh/mi)
    Gasoline efficiency: 51.1 MPG (estimate from fuel saved) / 58.3 MPG (932 mi/16 gal)
    Combined efficiency: 98.2 MPGe (using approx) / 102.8 MPGe (using truncated gallon)
  20. John H
    2,208
    558
    I guess I need to ease up on the pedal at 30kWh/100mi, or start taking the side roads.
