Prius c Steel Wheel Specs
Discussion in 'Prius c Main Forum' started by kkim, Mar 17, 2012.
  1. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    I took one of my steel wheels off to get some info that seems to be in short supply right now. Hope this helps those looking at other wheels for their car.
    First off, weight w/ tire and wheel was 32.5 lbs.
    According to Tire Rack, the stock Turanza EL400-02 in 175/65R15 weighs 17 lbs. Subtract that from 32.5 and the steel wheel weighs 15.5 lbs.
    Wheel size is 15x5.
    These are the only markings on the wheel. Is the offset part of these numbers or is it just not stamped on the wheel?
    Some other tidbits... The wheel lug nut size is 21mm. The threading and pitch, however, are the same as my Honda FIT and I was able to test fit some aftermarket 19mm lugs I have for the FIT onto the c wheel studs. Also, bolt pattern is 4x100, same as early Civics and FITs, plus many other small, 4 lug cars.
    Lol... the breadbasket/beehive looking thing behind the shock is either the muffler or resonator. I never noticed it before I took off the wheel. That's one weird looking muffler. :lol:
    Sorry I couldn't provide the offset of the wheels, which is what, along with the wheel weight, I was after.
    So, does anyone know the offset of the stock steel wheel? How about the 15" or 16" alloy wheel offsets/specs?
    4 people like this.
  2. F8L
    19,011
    4,080
    Grass Valley, CA.
    The wheels weight about the same as the OEM GenII 15x6" alloy wheel.
    Thanks for posting this. :)
  3. formula
    formula Member
    320
    32
    CA
    good job. :) I can properly do that after I picked up my C with 15 inch alloy.
    I think the tire is the same one the 15 inch steel and 15 inch alloy?
  4. priuscpower
    priuscpower Junior Member
    Spring Branch, TX
    I just took off my steel wheel from my Prius-C Two and did some measuring...tried to be as accurate as possible when measuring with a tape measure...
    Since I couldn't take the tire off of the wheel, various web sights said to add 1" to width of wheel to get total width of wheel. Divide total width of wheel to get center point which would then be 3" for the stock 5" wide wheel.
    Offset = 4-9/16" - 3" = 1-9/16" which = 39.69 mm
    OEM wheel: 15" x 5" 4/100
    Weight: 15.5 lbs (per previous post)
    Backspace: 4-9/16"
    Offset: 39.69 mm
    Hub Diameter: 2-1/8"
  5. Tek55
    Tek55 Junior Member
    96
    Houston
    This might be a dumb question, but just how big of an impact is wheel weight. I'm thinking of getting aftermarket rims and it would seem like the lightest rim would be beneficial for mileage.
    Of course, lighter is more expensive, so how does wheel width/weight impact handling, and is it worth it to swap it out based on weight or width or both? Any suggestions for improvements beyond the tower strut and/or sway bars would be extremely appreciated.
  6. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
  7. Tom Hamill
    Tom Hamill New Member
    Boulder, CO
    Any informed guesses as to whether this old Yaris wheel below would fit? Looks like 5-mm spacers would be needed given its 45-mm offset, but otherwise? Is the 5.5 inch width vs. Prius C's 5-inch likely to make any difference fitting the 175/65-15 tires?
    Yaris wheel description: The Manufacturer Part Number is: 4261152530 and the identification stamp/number is: SA20K. This is a 4 Lug 15x5.5 inch, 4x100 bolt pattern (45mm Offset), One Piece Alloy Factory, OEM Wheel, Rim. The position on the vehicle is: Universal. Interchange Number: 69553.
    Thx,
  8. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Some confirmations on the weights I posted earlier. I've had the tires dismounted from the stock steel wheels in preparation of having them mounted on some lighter rims that are being delivered.
    The weight of one tire-
    The weight on one steel rim with the TPMS sensor still installed varied between 15.5 and 16 lbs. Scale is only reads in 1/2 pound increments-
    Wheels that are being delivered weigh between 11-12 lbs, so I'll be (hopefully) saving 3.5-4 lbs per wheel/tire assembly once the tires are mounted to the new rims.
  9. Lenwood
    Lenwood Junior Member
    53
    san Mateo ca
    I'm putting on 15x6.5 38mmoffset. My tire guy says the 175 65 15 tire should fit fine.
  10. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Mine said the same thing today when I went to pick up the dismounted tires. We'll see, though... there are always surprises that one overlooks when selecting wheels and you can never really be sure until the tires and rims are mounted onto the car.
  11. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
  12. phenoyz
    phenoyz Member
    108
    nevada
    Hello
    Which tire is better for "Fuel efficiency / Performance" this is for daily driving
    (car will be lowered NOT slammed)
    205/50/15 or
    195/50/15 or
    195/55/15
    Thanks
  13. Yuval Legendtofski
    Yuval Legendtofski Junior Member
    Hi fellas, I was looking into getting alloy rims under the guise they are lighter and stronger than the OEM steel rims..I'm in Australia so we use kilograms, but according to your weights 15.5 lbs = ~7kg!!!
    The 15" alloys I looked at the guy said they were about 9kg ~ 19lb each!!
    SO for weight/fuel efficiency the OEM steel rims are better, so it all come down then to the tyres? Correct?
  14. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    With aftermarket alloys, the trick has always been to find something that is lighter, aesthetically pleasing and reasonably priced. I've found you can find 2 out of the 3 relatively easily, but meeting a wheel to satisfy all 3 is the real challenge. :)
    Tires are an entirely different discussion which will largely depend on what you are after in terms of their "performance".
  15. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    these two sites may help finding wheels and tires
    wheel weights
    Wheel Weights Specs Guide
    tire size calculator
    Tire size calculator
    I currently have 195/50/15 falken fk-452 tires on my 15x6.5 Volk TE37. they're weighted 8.8 lbs. Please correct me if i'm wrong, but because my tire diameter is less than stock, i feel like i'm not getting enough ground coverage to hit the factory rated MPG. my readings are mostly around 48mpg on the eco display.
  16. Yuval Legendtofski
    thanks for that list, but unfortunately more than 3/4 of those rims aren't available in Australia!!
  17. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Just FYI, I weighed my stock steelies w/Brigestone's and they came out at 31.2 pounds
    IMO there are several wheels out there that hit all three points nicely, but then again I like the two wheels I chose for my car, so I'm biased. :cool:
    Your tire size is 22.7" diameter, 1.3" shorter than stock, which is huge. 70 MPH indicated is actually 66.1 MPH with those tires. A more appropriate tire size would be 195/60-15, which is what I'm running for my 3-season setup.
    Big props for running TE37's though, those are hot wheels! You have any pictures on the forum?
  18. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    Thanks! I have a bad cloudy day pic at the bottom of my introduction thread. My first C3 and belated project | PriusChat It's been raining all week here in SF area. I will take some better ones when the sun comes back out. Once i wear out these tires, i'll definitly pickup some 195/60/15 RR tires. thanks for the tip
    since the weight matters greatly for our cars, I think Volk wheels especially the "gramlight" are good to run. although they are pricy but worth it.
  19. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Does anyone know the weight of the C's alloy 15" wheels?
    Thanks!
  20. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Oops! Despite having searched several times before, only just now found F8L's opinion that the alloys are between 15.5 & 16.5 lbs. Still, if anyone knows for sure, I'd like to hear it.
    Thanks again.
