2011 vs 2012 Thanksgiving trip mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by jhinsc, Dec 1, 2012.
  1. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I just filled up my first tank since my trip to NY for Thanksgiving, so I thought I would compare my mpg results compared to last year when I made the same trip. My total miles last year was 1,769 vs 1,792 this year due to several local trips in NY. Weather was good both years, except I had bit more headwinds to deal with this year. Driving style is where I varied. Last year, I tried to stay at the speed limit when possible and half attempted for higher mpg's, but this year I traveled at least 5 mph over with no attempt at higher mpg's. Cruise control was used and lower grill blocked for both trips. I also had the original Yoko tires last year and this year I was running on new Bridgestone Ecopia EP422's.
    2011 mpg = 51.67
    2012 mpg = 49.83
    Difference is 3.6% and 1.84 mpg. Pleasantly surprised as I thought the difference would be greater!
    F8L and CaliforniaBear like this.
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Is this calculated mpg's or read out from car's display?
  3. Former Member 68813
    3,524
    983
    US
    For high speed hwy driving? What were the coolant temps and MG temps?
  4. jhinsc
    1,167
    259
    South Carolina
    Calculated - car computer is always about 5% higher.
  5. jhinsc
    1,167
    259
    South Carolina
    I don't know - I don't have a scangauge or equivalent tool to measure. This is my third winter with lower grill blocked - so far no problems.
  6. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    674
    179
    Vancouver, WA
    That's what you need to invest in now, get a SC2 just so you know for sure before anything bad could happen! ;)
