Deadly CO Generators vs Prius Inverter
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Dec 24, 2012.
  1. bwilson4web
    16,332
    LOL!
    We had tornadoes rip up the TVA transmission lines three years ago come April. So I'm thinking used generators should become available over the next few years. Folks were buying them out of the back of semi-trailer trucks off the interstate.
    But fuel to keep them running keeps getting in the way along with their poor thermodynamic efficiency. Still, in an emergency, having any amount of power is less bad than no power at all.
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Bummer. Even with the car locked, and a remotely signalling alarm system (i.e. your house lights go out)?
    ..and how do you avoid the insurance company denying coverage unless you PROVE you didn't leave it running?
  3. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
  4. fuzzy1
    10,590
    Drop the 'h', make those 1.5kW or 1,500W.
    I bet not. Take a look at BWilson's chart of energy output vs fuel use, posted to another thread. His Prius inverter system is not up at the top -- commercial generators hit 6kWh/gallon at peak performance -- but at 4 kWh/gallon, it does match up with them under lighter loads.
    The generator you link has some specs posted elsewhere. If it meets those specs, it puts out only 2.8 kWh/gallon. And it is not CARB compliant, not for sale in California. So get a CO detector to go along with it.
  5. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Bob,
    I did a rough calculation and at full load my generator runs about 20% efficiency (120k BTU/gal of e10, 7kW for an hour). Not bad for an ancient monster (there is also a bit of oil burned and a significant amount of noise ;) ).
    I bought mine at an auction. Two small ones went for over $300 each; I was the only bidder on this one). I did have to spend some money to hook it up to my breaker panel (in a somewhat questionable manner - a heavy duty cable with two twist-lock plugs, a dedicated 30 amp 220 breaker to act as a secondary main breaker and an outlet box with a Twist-lock socket.).
    JeffD
    bwilson4web likes this.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    As I've reported elsewhere, I ran my steam boiler, a couple of 60W equivalent LED lights, internet and phone connections, internet radio, iPhone charger and laptop charger on an 80W inverter plugged into the lighter socket of my C for 54 hours after Sandy.
    I pulled the Prius into a tight corner next to the house, ran an extension cord through a tiny gap at the top of the window, locked the doors with the physical key, and put my wife's car right behind it. It was still there when I was done.
    Sergio-PL likes this.
  7. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ...not sure why but CO2 is not normally measured in confined spaces (O2, toxics (CO/H2S), flammables yes). CO2 is not considered toxic but over 3 to 5% is not good.
    Let's say you have a closed, air-tight garage at 4000-ft3. If I calc'ed correctly, burning 1-gal gaso depletes 250 ft3 O2 and makes 167 ft3 CO2. Room O2 would be down to 15% on O2 (yikes unsafe). CO2 would be +4% not good but the real problem is O2 loss. Of course there would be a vacuum in the room and a giant sucking sound when you opened the door, so this is hypothetical worse case sceanrio.
  8. bwilson4web
    16,332
    Combustion produces heat and would in such a perfect room, increase the pressure and blow-out the doors. Thus with doors blown open, it would allow fresh air to come in and the exhaust to leave.
  9. Corwyn
    2,171
    659
    Maine
    Can you post your math? Intuitively this doesn't sound right. CO2 is fairly low concentration (0.0003 or so) while O2 is around 0.2, seems like converting almost the same amounts should have a far greater affect on CO2 than O2. I note in defense of my intuition that humans trigger breathing based on CO2 concentrations, not O2.
  10. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    Here's my calcs (not claiming it's error-free yet):
    made this equation up
    CH2(gasoline) + 3/2 O2 ---> Co2 + H2o
    Gallon of Gaso at 3785 ccs/gal x 0.75 density = 2840 grams @ 85 wt% carbon & 15 wt% hydrogen
    So that gives you 5.3-lbs carbon = 0.44 moles x 380 Ft3/mole = 167 ft3 CO2 made
    O2 = 3/2 x 167 = 250 ft3 consumed
    I neglected the water, a lot is made so this would tend to say pressure is constant assumimg some condensation. Take a garage at 20x20 with a 10-ft ceiling = 4000 ft3 @ 21% O2 = 850 ft3 O2 to start off
    But now I am trying to understand why the egg gets sucked into the bottle in the classic school experiment.
  11. fuzzy1
    10,590
    Is this portion really unsafe for normal healthy people, at least at sea level? It corresponds to oxygen's partial pressure at about 7000 to 8000 feet, similar to the pressure altitude allowed in commercial aircraft cabins.
    I am aware that some people have problems in aircraft, and that newer aircraft are addressing this by aiming for lower pressure altitudes.
  12. bwilson4web
    16,332
    It is a little easier as this was discussed in this engineering forum. The only problem I see is engine exhaust temperatures for our Prius run a little cooler. But the analysis is correct that it is heat, not the increase in moles that causes the over-pressure.
    Let me suggest a more practical approach to the 'sealed garage' problem:
    1. carbon monoxide detector - use 24x7 especially if you have oil or gas heat. This is equal, possibly higher, importance than smoke detectors because carbon monoxide is deadly, odorless, and can come from other sources.
    2. park car with exhaust pointed away from house and open to the outside world - this will give at least the length of the Prius to dilute what little carbon monoxide is emitted from a car that will have at best a 50% duty cycle.
    3. Prop garage door open at least 1 ft - the excess heat from the car poses a greater risk to the car and this will ensure dilution.
      1. If using a gas generator without a catalytic converter, do not operate in a garage as it will generate about 5 times the amount of carbon monoxide as the Prius.
      2. A gas generator will also generate more heat per kWhr.
  13. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I run my generator in my two car garage with a long flexible exhaust pipe that reaches a few feet outside the garage door. With the door open about a foot, it does get quite warm in the garage. I should put a CO detector in the garage, but the one in the adjacent basement doesn't go off when the generator runs for a couple of hours (one tank of gas).
    JeffD
  14. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Do keep in mind with most combustion processes CO is generated when the O2 is starved. This starvation occurs when the exhaust is mixed into the intake. For example, a closed room. Initially CO production in a properly adjusted flame is almost zero. As exhaust CO2 builds up along with H2O vapour the combustion process becomes less efficient. CO is the result. It doesn't take much to be toxic. The CO is bonded with the hemoglobin in your blood before O2 can and your body can't release it like it can with O2. Essentially your blood cells are "used up" and must be replaced. This takes a -long- time, which is why CO poisoning can be so serious and takes so long for recovery (for those lucky enough to survive!). Loss of consciousness usually makes the process end in tragedy. :(
  15. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    15% O2 would be very dangerous. Most liberal lower safe limit is generally 19.5% O2. This is why confined space entry is very hazardous in industry/farming/sewers etc . Personally I prefer to set the limit at close to full air 21%. I am not sure how human lung works from a physiological persepctive but to my knowledge the key safety parameter is %O2 in the lungs at any altitude. I know CO binds with the hemoglobin stronger than O2.
    Now keep on mind it would be probably be very hard to do in your garage. By the time you burned a gallon of gasoline in your Prius it would probably be 24-hrs and there would be some air changes. But lets say you are not aware of this and you have a generator and a 2 Prii going in your garage or a kero heater. Eventually if you pulled a lot of the O2 out of the room you would probably start making CO, but I am thinking your health would be compromised before the CO appeared. Therefore CO detector is good - tells you if the there is a leak of exhuast, but I don't believe monitoring CO alone is enough to tell you when you went below the safe O2 limit.
    As I write this I am thinking I personally have not been safe enough in this regards...lets face it this applies to gas fireplaces, kero heaters and all that stuff I like to fire-up.
  16. Judgeless
    1,821
    257
    Cleveland, OH
    Talking about things you like to fire up. I just built this yesterday.
    I bought a 10KW tri-fuel generator after the power outage from Sandy. I ran a gas line to the side of the house to power it. When I was running the line I decided to run a line for the gas grill. Then I thought it would be nice to convert my little fire pit to natural gas. I finished that yesterday.
    Next I am going to build natural gas Tiki torches using these.
    http://www.ebay.com/itm/Outdoor-Gas-Light-Open-Flame-Burner-NG-Part-OFB-N-/110968999807?pt=LH_DefaultDomain_0&hash=item19d6448f7f
  17. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
  18. Corwyn
    2,171
    659
    Maine
  19. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    For CO2 783 ppm sounds fine...figure what? 400 ppm in the atmosphere at Muana Loa, and that's in the middle of nowhere. By the time the first Calfornian exhales, we're probably at 500 ppm CO2 background.
    Per the comments, one reviewer states that less than 1000 ppm CO2 is one recommended target for long term working (eg; office etc). However, nuke submarines try to keep CO2 below 8000 ppm in the breathing air. Typical levels in a sub would be 3000-5000 ppm CO2, but can get as high as 10,000 ppm (1%), which is the upper limit of the Amazon monitoring device.
    Interesting article (one study says excess CO2 impairs decision making)
    Claim: CO2 makes you stupid? Ask a submariner that question | Watts Up With That?
  20. hlunde
    hlunde Member
    419
    75
    I used my Prius together with an inverter to power the ignition system of my hydronic boiler during the recent power outage in NJ. The boiler ignition only used 9 watts standby and about 30 watts when firing. Using this arrangement for so little power draw proved very fuel inefficient. After one night I moved the inverter to a conventional car battery where it lasted for days. An issue with this second arrangement was that the inverter sounded an alarm and dropped out at anything below 11.5 volts. Ideally, one would need a deep cycle battery with an inverter that would operate at lower battery voltages.
