Rear ended, pictures and questions regarding the damage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by unit333, Jan 4, 2013.
  1. unit333
    unit333 Junior Member
    77
    NYC
    Hi
    Pretty straight forward situation. Was rear ended on the highway in NJ by someone. Their insurance turns out to be crap so I have to go through Geico (mine) to get the damage covered. Then Geico goes after them to recover their money. Of course, I have a 1K deductible which is really annoying considering I have no fault in this situation.
    Anyhow, what i will most likely do, meet tomorrow with the Geico person who will evaluate the damage and cut me a check. Then I will try to find auto body shop (decent one though) which will hopefully agree to fix my car for a little less so I don't eat the whole deductible.
    My main question is, from the pictures and from you experience, considering that the Prius has a lot of computerized parts and sensors in the tires, etc - do you see a possibility of there being more damage then it shows?
    - Bumpers definitely needs changing
    - There is a gap between the back of my right rear light, and that side section of the car - from the impact or from the bumper pushing on it. Would that need changing or could it possibly be pushed back to fit nicely behind the light again?
    - Are there any possible other damages underneath the bumper I am not seeing?
    Thanks for taking the time to look!
    52,127
    ouch! sorry. in mass, when it is the other persons fault, there is no deductible. is that not true in jersey?
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I would take it to a good body shop (ask friends/neighbors who have collector cars) which is approved for use by your insurance company and let them work it out. The shop will carefully inspect the car and provide a full estimate to the insurance company. There is often hidden damage that is not seen until they take things apart. A good shop will also do careful paint matching so the repair is not apparent.
  4. unit333
    77
    NYC
    Well, I live in NY, just happened to be passing through Jersey. Apparently NJ has some lame A Dollar A Day insurance which is illegal in any other state. It allows a person to drive their car in NJ but doesn't cover anything or anyone in a case of an accident regardless of the fault. So Geico will try to recover the deductible as well but I am not holding my breath. Just trying to get ready and get some tips before I meet the insurance person for a repair estimate tomorrow.
  5. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I'd suggest that you spend a few minutes reading your policy as well as finding some info on both NY and NJ insurance regulations. I have GEICO and all of my documents are available online so you should be able to get everything pretty easily online. This will arm you with the best info possible before you meet the insurance adjuster.
    Someone mentioned hidden damage - typically the adjuster will write up the repair but once the body shop is able to pull the car apart they will handle it from there. If there is additional damage they will get an authorization from the insurance company. I had this happen to me, it was a fairly major issue and the adjuster went back to inspect it. It was all handled by the body shop and insurance company with no muss or fuss, the only issue is it added a few days to the repair.
    I went through it just after moving to PA so I just went to the local dealer - I figured that they would be as good a choice as any and also would also be the best folks to handle it if there were any funky hybrid issues with the car. I had a terrific choice - the body shop was terrific even though I have had pretty poor experiences with the dealer itself.
    JMD likes this.
  6. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    That looks bad. 1k deductible is a lot but the damage is a lot more, IMO.
    I had a small bump, just a paint scrape but the their car went under my Prius that did damage and the insurance gave me a quote of 1140.00. Half was labor the other half was all OEM parts.
    Make sure the exhaust system is included. That pipe and hangers go all the way to the front and that could be all crinkled, I suspect. Also make sure they cover the collapsible white foam in the bumper.
    Sorry to see it.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Do you see any visible damage inside the vehicle? Remove the triangle false floor cover over the aux battery. I would actually remove the whole false floor. It is really easy, the same as if you were changing a spare tire. Take out the 2 corner triangles, unlock the main cover, that folds up and slides out. The crap-storing-tray just lifts up in full. That should give you a clear view.
    The 12v battery vent is down there. And as someone mentioned the exhaust is awfully close to that.
    Usually you are surprised by the amount. I would suggest not having the insurance agent just write you a personal cheque now. Take it to a body shop, have them work with the insurance company. That way you only get billed your deductible and the body shop and insurance company fight over the details. Otherwise you are going to be in the situation to resolve issues, and there will be. If something new is found, or they have to respray that side to colour match, I would rather have the body shop tell the insurance company that and bill them, then to bill you and have you ask your insurance company. That will then spin off a new claims agent looking at the car, blah blah blah.
    And not to mention that any money over the amount you collect from the insurance company not put towards repair with your full deductible is insurance fraud...
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    unit333, you seem to have received some bad info. In NJ the at fault driver is responsible. Collision insurance covers damage to the insured's car. This is optional. Comprehensive insurance covers damage to the insured's car against other-than-collision damage. This is also optional. Liability insurance covers damage caused to others. It is not optional.
    By going through your insurance then yes, you'll have to cover your deductible. The other insurance company will reimburse you with a check.
    I presume you also have uninsured/underinsured insurance.
    In my not-expert opinion I think you'll find more than bumper cover damage.
  9. unit333
    77
    NYC
    Hey
    Well according to the guy's insurance he basically have no coverage other than a same day emergency room if anyone is injured. After googling the dollar per day NJ insurance this seems to have happened to a lot of people. They end up using their own insurance. Those pictures actually look worse then the bumper looks in person. I'll let you guys know what happens tomorrow. Thanks for the feedback
  10. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Geico often has their "approved body shops" it might make sense to use one of their shops, might give you more leverage if there is hidden damage.
  11. Me Here
    Me Here Member
    149
    26
    My Prius was hit hard and a bit higher than what yours was and they had to replace the exaust, floor pan, piece of frame and the works. A lot of stuff can get bent that an appraiser won't see. It's all good and well they want to come out, but take it to a shop after.
    Take it to an approved shop if they have some, in the event there are repair issues geico will have to help you follow up with the body shop.
    You'll most likely have to go after the individual themselves for your deductible, as well as for the diminished value. I bet its about $5k all together they will owe you, small claims court would be best and you wouldn't need a lawyer.
    I'm gonna guess that as long as the rear floor pan isn't bent, and as long as your gaps inbetween your passenger side doors aren't off (there is no frame damage,) repairs will be in the $6k-$8k range. Possibly lower if they managed to miss anything vital.
  12. unit333
    77
    NYC
    Well Geico is going after them to possibly recover the deductible too...whether it happens or not who knows. Small claims court or anything for that matter is too much of a pain in the nice person I am not sure i would want to deal with that honestly. It will be such a headache. I guess let me see what the Geico dude comes up with first. Definitely keeping it in the approved shops as that way they guarantee the repairs no matter what....
  13. Me Here
    Me Here Member
    149
    26
    They won't be able to get you diminished value though and for a bit of time and paperwork you can get a decent amount for what you've lost. But if you plan on keeping the car until the wheels fall off then you won't be out any money.
  14. unit333
    77
    NYC
    I guess I can look into that. How does one go about finding out how much your car is depreciated? The Blue Kelly book or whatever it was called or do I need someone to actually look at it and decide?
  15. Me Here
    Me Here Member
    149
    26
    You can contact a dealer after the repairs are made and its marked on carfax as having been in an accident. They can tell you what its value you is now and what it would have been had it had a clear title. Keep in mind thats only trade in value, private party value is always more. Chances are its somewhere around 2k-4k loss in value. Again that number goes up if there is structurual damage. There are also diminished value experts, you want one that comes out to look at the car after the repairs are made, that can cost $200-$400 depending on who you get. Do NOT pay for a desk appraisal. You can add in your deductible if the insurance can't get it back for you too.
  16. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Glad you are ok, sorry that happened to you.
    Thank you for the lesson, I wasn't planning on it, but now I know never to drive in NJ.
  17. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
    Make an effort to reduce deductible to $250 asap.
    Normally not too much more on a monthly basis.
    Takes a lot of the sting out of situations like this.
    Me Here likes this.
  18. Me Here
    Me Here Member
    149
    26
    Even a $500 deductible would be better. I'm still sure I follow exactly whats happened as far as the at fault party and their insurance or lack of. Did they have liability or not? Do you have underinsured/uninsured coverage on your policy?
  19. unit333
    77
    NYC
    I do have the uninsured motorist coverage but it only applies to body injury and stuff, not for collision. Geico (at least in NY) doesn't offer a different version.
    From what I read and after speaking to Geico, a depriciation of a vehicle due to an accident is not legal in New York so it shouldn't be an issue. I am still researching this but so far it looks like it is true...it seems a bit of a gray area.
    I am going to talk to Geico for the 8th time on Monday and see if I can once more push for reduction of the deductible or if they have had any success with trying to recover funds from the other insurance company. They started the process immediately today after I got the damage inspection.
    The guy's insurance is a New Jersey specific insurance for people on Medicare, it doesn't cover anything other then a visit to the ER in the same day as the accident if needed. It's barely legal in NJ and illegal in a lot of other states. Total BS!
    Anyhow estimate went ok, so far is around 1.5k but they warned me it will probably be more after they take the bumper out (Thursday) and look for more damage. The initial and obvious damage so far is as follows: Rear Bumper Damage, Right Quarter Panel Damage, Tail Lamp is fine but could be damaged inside, so they will change it anyway, Exhaust pipe looks fine, but they will look it under in more detail when they get the car.
    The damage doesn't really seem like the end of the world and the shop I went in has a shit ton of great reviews on Yelp so hopefully they will do a good job. I am really more irritated with the fact that people are allowed to drive in various States with crap insurance and then basically create all this shit for other people who are obviously not at fault. But again, there are worse things so I will survive whatever the outcome on this one.
  20. unit333
    77
    NYC
    Here are a couple less dramatic pictures since I only had the once from the other night. That's from the geico person.
