ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    What happens if something breaks your concentration while you are doing that Jedi mind trick:D Squash you like a bug it will.
    walter Lee, Tracksyde and F8L like this.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You know, if Skywalker sees you have repainted his speeder to purple, he's gonna be pissed!
    walter Lee and F8L like this.
  3. KK6PD
    4,003
    944
    118
    I called my local dealer, first they quoted me $300.00.
    When then found out I only have 36K, they refused to do the ATF change!
    Gotta make some more phone calls!
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Really?
    U would think they'd be all love the job
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    What I
    What I find amazing about dealers is that they state that Toyota does not recommend the transaxle fluid change in the maintenance schedule. Yet there is nothing in the maintenance schedule about fuel flushes, brake system flushes, transmission flushes and other add-ons and they freely push these !!
    pjksr02 likes this.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    $300 seems a bit high. I do my own every 30K miles, the local dealer charges me $7.20 a quart for ATF-WS (it lists for $8.00) and takes 3 1/2 quarts. The drain and fill plug washers are about $1 each.
    If you don't do it yourself any good independent mechanic should be able to do the job in about a half hour or so, be sure to take the Toyota ATF-WS fluid because he won't have it.
    I changed mine the first time at 20K miles and sent a sample to Blackstone Labs. The indication was that a change had been a good idea. The results from that sample are in one of the older threads, we decided at that time that after the first change 30K miles would be a good interval.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hey Tom long time no see!?
    Do you have the part number for the washers or are they the same as the engine oil plug?
  8. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Washers on the transmission is way different and bigger
  9. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Spidey,
    The washers on the transaxle are different. The part numbers are 90430-18008 and were $1.89 each the last time I bought them.
    spiderman likes this.
  10. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    If you know the size, you should also be able to get them at a good car parts store. They are just soft aluminum washers.
  11. tumbleweed
    4,067
    687
    Eastern Oregon
    Good to be back! long vacation. Also built a new garage with a lift and a new cement driveway. Prius is still running great, finally got rid of all the rattles.
    The washers for the transaxle are aluminum, part number 90430-A0003, they are listed as a gasket rather than a washer.
    EDIT: Part number 90430-18008 mentioned above by jd is also a good number, I think the A0003 number is the newer one. Just got two of them last week from Toyota Parts - Genuine OEM Toyota Auto Parts and Accessories
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Welcome back Tom !
    tumbleweed likes this.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, welcome back. Wow a long vacation and a lift... what more could a man ask for. :) Thanks for the info.
  14. Bill Norton
    Bill Norton Senior Member
    1,862
    612
    MONW, Ks.
    They're solid aluminum washers on the plugs.
    Why replace them?
    Torque them down and you'll never know the difference.
    It would be interesting to see an ATF oil analysis from a Prius and a Toyota model with a conventional Automatic transmission, both running Toyota's ATF WS, both with similar miles, ~30 - 60k miles.
    The Gen3 transaxle has that extra set of planetary gears. Lots of little gears.. to break-in and possibly make lots of little metal particles. No filter. No magnetic drain plug. Life is hard for the fluid in a Prius transaxle, me thinks.
    Oh, here's a great Tech-nerd article on Gen3. Explains a lot and has ideas for engine oil and transaxle oil temp sensing. So much data to gather !
    http://www1.eere.energy.gov/vehiclesandfuels/pdfs/merit_review_2011/veh_sys_sim/vss031_rask_2011_o.pdf
  15. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    They are very soft aluminum, once you torque them one to many times they will leak.:cry: Probably not worth trying to reuse. There are washers that are meant to be reused. They are called Dowty washers or Dowty seals. Basically a metal washer with a built in elastomer seal. They cost more but I have seen them used on Ford and GM products. The Dowty type drain plug on my GMC pickup lasted at least a dozen oil changes before the elastomer
    started looking worn.
    The Gen III has an extra set of planetary gears but doesn't have a chain so actually has fewer wearing parts. Chains are a real bundle of joyful wearing parts. My impression from reading oil analysis reports on Gen II and III is that the IIIs are chewing up the oil faster. Has anyone done a comparison?
    Thanks for the Tech-Nerd article link.
  16. Bill Norton
    1,862
    612
    MONW, Ks.
    xs650,
    I don't know how to do the cool 'quote paste' this site allows. Soon I will figure it out.
    But, com'on, look at those washers under magnification. You can't tell how many times those washers have been torqued down. I know I'm being a cheapass over buying ~$5 worth of washers, but,,, reduce, reuse, recycle, you know? And, one less trip to the dealer parts department.
    And so, I shall take on the research of reusing these washers and using a high quality synthetic ATF! 'Til the cows come home...
    But, I do spend an extra $15 at each ATF change for an oil analysis,
    for the "Benefit to the Knowledge Base here on Priuschat".
    I deserve points for that, no?
    SFO and DigitalNomad like this.
  17. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I have used aluminum washers to the point that they leaked. They looked fairly bad when they were to the point that they no longer worked.
    If you are looking at the washers and know the difference between a bad one and a good one, then you are in a small minority and that's good on you.
    There are different ways to do the quote paste. The easiest one for me to remember is:
    1. Copy the part of the original post I want to quote
    2. Move cursor to where i want to insert the quote.
    3. Click on the quote marks in the bar at the top of the edit area.
    4. Paste the copied text between the quote marks.
    Cheers
  18. F8L
    19,011
    4,081
    Grass Valley, CA.
    Stupid iPad doesn't show the editing tools for posting so you have to use raw UBB code. This page shows you how. It's very similar to HTML and easy to remember.
    UBB Code Explained
  19. tankyuong
    1,555
    660
    Central MO
    Use it til it leaks, which would probably when your car has 100k miles
  20. Bill Norton
    1,862
    612
    MONW, Ks.
    Thanks for the tutoring on using the site !
    Sorry I brought it up, but look, these washers are about ~1/8" thick solid aluminum.
    They have been torqued down 3 times in their lives.
    They look spotless.
    They are on a car with 115k miles and going for a record!
    I will take them to the limit.
    There is a difference between 'metal crush' washers and these perfectly cylindrical, solid washers.
    But, to make yourself feel safer buy brand new washers at every engine and transaxle oil change.
    And I'll keep my C.A. comments to myself, sorry.
