New All-WeatherMat? Any good -- bad -- different?
Discussion in 'Gen 2 Prius Main Forum' started by cyberpriusII, Jan 31, 2013.
  1. Patrick Wong
    18,210
    6,512
    Maybe the rear brake clearance was set too tight resulting in some drag on the rear brakes.
  2. Handygeek
    Handygeek Member
    110
    17
  3. Patrick Wong
    18,210
    6,512
    What is there to hear?
    If a plug is defective or incorrectly gapped, that will not help engine performance and will worsen fuel economy...
  4. Handygeek
    Handygeek Member
    110
    17
  5. Patrick Wong
    18,210
    6,512
    The MAINT REQD warning light is based upon an odometer timer, which starts that light blinking 4,500 miles after the last time it was reset, and turns solid 5,000 miles after the last reset.
    I am not aware of either a bad production run of plugs, or of a systemic problem with the plugs not being properly gapped.
  6. Handygeek
    Handygeek Member
    110
    17
  7. Handygeek
    Handygeek Member
    110
    17
  8. Handygeek
    Handygeek Member
    110
    17
