HDD startup issue (blank map screen)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CharlesH, Sep 17, 2012.
  1. CharlesH
    2,797
    1,164
    Roseville, CA
    I have the Advanced package, and occasionally, right after I start the car, the HDD display screen will be dark for a minute or two, and then display the map. I can go to the other screens, like Audio or the setup screens, but the map and the backup camera screens are dark. The still-functional buttons are responsive as usual (no delays/hangs). When the map finally "wakes up", it behaves normally. I don't have to do anything other than wait for it to wake up. It does this about 10% of the time. I have tried to correlate this to something, but it seems totally random. Makes me wonder if there is something wrong with hard drive or something.
    Any ideas?
  2. CharlesH
    2,797
    1,164
    Roseville, CA
    I thought I would inquire about this again, as it is about time to take my car in for scheduled service and this is possibly an issue I would want to raise. I was wondering if any other Advanced owners have run into this situation? Note that this is not a case of lagging or slow response. The map and backup screens just simply are blank for a minute or two after starting the car, then everything is fine, and the situation only occasionally happens.
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I haven't seen this on mine.
    CharlesH likes this.
  4. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Does not happen on mine....
  5. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Nada
