Power mode ?
Discussion in 'Gen 3 Prius Main Forum' started by Angry Elf, Mar 8, 2013.
  1. Angry Elf
    Angry Elf Junior Member
    35
    I've read that the power mode adjust the throttle response .
    Does power mode adjust ignition timing or valve timing ?
  2. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    Nope.
    Just the 'ramp up' of the throttle.
    ForestBeekeeper likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    No. It simply moves the throttle plate more for less initial travel of the pedal, leaving more pedal travel closer to the floor with less effect.
    It is doing nothing you could not do in Normal or Eco by pushing the pedal further.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Toyota had told us (back in 2010) that it only changes the first 50% of pedal travel and after 50% pedal travel to 'full throttle' all the modes act the same.
  5. Andre Philipp
    Andre Philipp New Member
    That's not the full story though. In PWR mode Prius utilizes additional electric power during acceleration which is not available in other modes. It peaks current up to 70-90Amp during acceleration that cannot be seen in other modes ! Thus acceleration feels stronger but only if the battery has a sufficient state of charge .
    Eclipse1701d likes this.
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    That is correct. I use PWR Mode to get across traffic when turning or to take out the Butt Munch that wants to keep everyone below the speed limit. It really makes a difference!
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The different modes also affect the operation of "other" systems in the Prius. e.g. - in "eco" mode the fan runs slower.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Another strange one about ECO mode is seen when the climate control is set to Auto. In normal mode as the heater brings the cabin up to temp the mode will transition from floor only to floor and face level vents. ECO mode disables this--the mode will stay on floor.
  9. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Thanks! I knew there was more than just changing how the pedal responded. I knew it! I am always in the PWR mode when I drive...
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Do you know if ECO mode affects the use of the battery at all?
    P.S. - Welcome to PriusChat!
  11. El Dobro
    El Dobro A Member
    7,088
    3,270
    It seems Lexus CT200h videos explain power mode a little better.
    Here's another.
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Great. Just great.
    Now I want a CT 200h! :)
  13. Mendel Leisk
    41,786
    You lost me. How do you "take them out"?
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    What is the source for your information? That is not what we were told by Toyota when the car was introduced, although they could have been wrong. I have tried to find a difference in current draw between modes using my ScanGauge and have not seen any difference.
  15. El Dobro
    El Dobro A Member
    7,088
    3,270
    Probably means pass them.
    We know that the battery does boost the car on full acceleration, but the first video I posted above shows that in sport mode on the Lexus, the power goes from 500V to 650V. Since it's the same basic powertrain as the Prius, maybe this also happens for the Prius, too.
  16. Andre Philipp
    The source of this information is Scangauge II. My Prius is a 2011 model. It seems like in ECO Prius tries to maintain its 60% soc. In power mode it does not hesitate to boost the hell out of the battery.
  17. tumbleweed
    4,067
    692
    Eastern Oregon
    Interesting, I will have to rerun my tests and see what I get. As I recall I ran them last time at 6 bars, I'll try to do it again at a lower battery level.
  18. David Beale
    5,963
    1,989
    Edmonton Alberta
    Do keep in mind it's likely the Lexus is tuned differently than the Prius. They go for power not mileage. The Prius tuning is for mileage.
    What I'm saying is many parts of the -hardware- may be similar but the software is likely different.
    tumbleweed likes this.
  19. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    I checked my amp draw this afternoon and found no difference in the max draw in ECO and PWR. PWR mode definitely seems to be peppier, but it is just kicking in the acceleration sooner. If the valve timing or battery voltage is remapped, please post the reference.
  20. El Dobro
    El Dobro A Member
    7,088
    3,270
    I used to think so, but when I found this, it made me wonder. Listen to what the narrator says for the V in power mode.
