Warning indicators
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BetsyNC, Mar 13, 2013.
  1. BetsyNC
    BetsyNC Junior Member
    29
    Efland, NC
    When I got in my car to drive home from work, I had 3 warning indicators: a ! inside a circle with parentheses around it (in yellow); a picture of an engine with the word 'engine' underneath; and a ! Inside a triangle in red. What do these mean? The manual only says "take vehicle to Toyota dealer".
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The only way to really know is to have the OBDII codes pulled. These codes will tell u what the problem could be.
    This can be done with a ScangaugeII, Torque or OBDII scanner. The dealer can also get them but they charge.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    What year is your Prius Betsy and is it a Prius v?
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Hopefully when the codes are read they will indicate a problem still covered under warranty.
  5. BetsyNC
    29
    Efland, NC
    2006. It's not a prius v.
  6. BetsyNC
    29
    Efland, NC
    I'm at the dealership now. They charge $98 to just pull the codes. How expensive could this be?
  7. boppo
    boppo Active Member
    799
    139
    Owego, NY
    All depends what they find, let us know the codes before u say ok fix it.
  8. BetsyNC
    29
    Efland, NC
    Ok, thanks!
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    These indicators, right?
    Have them look for an inverter coolant pump failure, it should be under warranty.
  10. BetsyNC
    29
    Efland, NC
    Yes, exactly these three indicators. Thanks for the information. I will post once they call with what they say is the problem.
  11. BetsyNC
    29
    Efland, NC
    How do I set this as a "watched" thread?
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Above your first post, to the right, there should be a link to click on that says watch thread Betsy.
    BetsyNC likes this.
  13. Patrick Wong
    18,204
    6,505
    Unfortunately, it is likely that the skid control ECU will need to be replaced.
  14. BetsyNC
    29
    Efland, NC
    What is that, and is it an expensive fix?
  15. BetsyNC
    29
    Efland, NC
    But my brakes never failed. And I have had no difficulty whatsoever driving the car. The only thing that happened is that these warning indicators came on. The car drives fine.
  16. Valencia Orange
    192
    Valencia, CA
    2013 Prius Plug-in
    I had the same indicators show up on my hybrid on Saturday. On Monday the hybrid battery was replaced under warranty. 2006 Prius 96000 miles.
  17. BetsyNC
    29
    Efland, NC
    My 2006 Prius has 128+K miles. How do I know if that is still under warranty?
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You would have to know which state your car was registered in. (I could guess North Carolina, but I would be guessing)
    The US hybrid warranty is 8 years/100,000 miles but several states have adopted the CARB hybrid warranty of 10 years/150,000. North Carolina is not one.
    Many of those states have an effective date for the start or end of the warranty, WA starts covering with the CARB warranty for Model Year 2009, and AZ started in MY 2008, but repealed CARB after MY 2012
  19. BetsyNC
    29
    Efland, NC
    Can you clarify what 8 years/100,000 miles means? My car is not yet 8 years old, but it has more than 100,000 miles. Does that mean it's covered?
  20. Patrick Wong
    18,204
    6,505
    It is not under warranty at that odometer reading.
    If the skid control ECU is the problem, it will likely be a four-digit repair at the dealer. An alternate approach is to have an independent install a used ECU from a salvage vehicle.
