2004 Prius Warning LIght and Engine lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doomteam1, Mar 1, 2013.
  1. doomteam1
    doomteam1 Junior Member
    32
    Highland, Ca
    how do you know where it was originally sold
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    That original dealer that replaced the Inverter was clueless. Stay away from him.
    The car probably threw code:
    PAO80
    which is the death knell for the Hybrid Battery. That and a bouncing charge meter (which I think you initially mentioned early as I went uh oh)
    Prius's that old sometimes just have alot of corrosion on the interconnection buss bars between the battery packs in the Hybrid battery case. But you must have alot of technical or mechanical skills to repair that which is why I asked about you. Sorry, I should have been more clear.
    If your really broke you may be able to purchase a used battery pack locally from a junk yard cash$$. Its pretty easy to swap in and we can help you. Only thing is the pack is quite heavy and you may need help to install it.
    Post any price you find here first before you buy though as it may be the same price as a garanteed pack from the many different providers.
    Call AVI as he may be able to install this for you.
  3. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    You should be able to register the VIN on the Toyota owner's website. That will allow you to see its Toyota service history, which will probably give you an idea of where it was initially owned.
  4. doomteam1
    32
    Highland, Ca
    I hope its the hybrid battery, its still under warranty.
    I hope the history on there is true if so it is in california.
  5. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Does the history include new car prep? If so, it's almost certain that it was purchased there.
  6. doomteam1
    32
    Highland, Ca
    no the earliest it goes is 2006 with 26k miles.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    A Carfax printout would probably tell you, but that costs money. You might be able to talk to a service writer and see if he/she can pull that information up.
  8. doomteam1
    32
    Highland, Ca
    I got my error report code from toyota they gave me
    P0492 a quick google search came up with
    Secondary Air Injection System Bank 2 Malfunction
    Which doesn't make any sense to me
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Find another dealer or an independent shop.
  10. Patrick Wong
    18,204
    6,505
    That is not a valid DTC for Prius.
  11. doomteam1
    32
    Highland, Ca
    oh wow, that means they really don't know what they are doing.
  12. edthefox5
    10,096
    4,833
    Clearwater, Florida
    I think you fudged the 4 and I bet its an A resulting in POA92 Transmission/transaxle issue:
    Prius Service and Repair - Toyota Prius Specialists | Atlanta Hybrids
  13. doomteam1
    32
    Highland, Ca
    i called them again, they told me same code.
  14. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Hmmm. Not at home with my notes but that doesn't sound right. You need to get the printed out service receipt.
    If it was me I would go to another Toyota dealer or maybe AVI. Pay the $100 diag fee and have them pull all the codes and get them on a printed receipt because your just spinning your wheels here.
  15. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Avi won't charge $100 to read codes. Then again neither would AutoBeYours in Indiana or Mellors in Florida.
    JeffD
  16. Patrick Wong
    18,204
    6,505
    A reasonable guess, and if correct this would mean that MG1 within the transaxle had failed.
  17. doomteam1
    32
    Highland, Ca
    maybe the girl read it wrong cause i guess a 4 does look like an A.
  18. goitalone
    goitalone Member
    190
    Port St. John, Florida
  19. goitalone
    goitalone Member
    190
    I am curious, did you figure out the problem yet?
    I couldn't post any messages, so I contacted the admin and he fixed it for us. I guess it was more than just me anyway. :p Anyway, that was why my previous message was blank.
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah, I couldn't post any messages yesterday either. Glad they fixed it.
