Michelin Defender
Discussion in 'Gen 3 Prius Fuel Economy' started by Armyguy03, Mar 30, 2013.
  1. Armyguy03
    Armyguy03 Junior Member
    I was at Sam's Club checking out some tires for the Prius I'm soon to purchase. I've read here that the Michelin tires give the best bang for the buck. Would anyone disagree? I'm looking to purchase the Michelin Defender XT tire. The Sam's Club mechanic who I've spoken with many times said that he has them on his Sunfire and they offer a quiet and safe ride, even in the snow.
  2. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Good tire for other cars but not the best for Pri's. Michelin Energy Savers and Bridgestone Ecopia's in that order are more ideal.
  3. Armyguy03
    Many thanks!
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    If you drive a lot of miles annually they are a good economical choice. Fuel economy will be lower than OE and a lot lower than the Energy Saver A/S but the long tread wear makes up for some of the efficiency loss. Still, the Energy Saver A/S is cheaper in the long run.
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I am on my second set of Michelin Energy Saver AS tires, 195x65x15. They are a true 60,000 mile plus tires, if
    you rotate them on a regular basis. I kept mine at max pressure 44 psi in all four and the tires wore perfectly
    even. MPG's are at least 3 mpg more than the Ecopias and the original Avid tires.
    TwoUnderPar likes this.
  6. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Just curious, any reason to NOT follow the factory spec to have the rears 2 psi lower? Thanks.
  7. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    Likely because the car is front heavy. I do this with my TDI Beetle as well. Third set of tires on the VW and second set on the Prius with even wear. PSI adjusted after each rotation. To hard in the back makes it loose.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    Like mentioned above, I would suggest keeping them with the factory pressure split unless you regularly carry a heavy load or 4 people.
