DRL - LED Design
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SAronian, Apr 7, 2013.
  1. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Anyone discovered the logic behind designing LED Daytime Running Lights with 6 individual lenses but only 4 LEDs?
    Doesn't it look like some aftermarket hack job? One lens is only showing half way through the plastic frame.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    the 10s and 11s had what appeard to be LEDs in the headlight housings but they were not... cruel
  3. El Dobro
    El Dobro A Member
    6,979
    3,214
    Probably just to give some style to the DRL lamp shape.
  4. SAronian
    334
    144
    Oakland, CA
    Thank you, that's very interesting. That's a good insight into how Toyota optimizes parts and costs.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Simply Aesthetics ☺
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yea! makes me warm and fuzzy!
    But they do look nice.
  7. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    that's funny.. never noticed it and I was just thinking of modifying it to have a only a single column light up so it looks like a line.
  8. 4everS2K
    4everS2K Junior Member
    Los Angeles
    Having 2 on out of 4 would be perfect if combined with the headlights on!!!
  9. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Logic? Cost savings... 4 works so why add more is probably the philosophy internally.
  10. CygnusX-1
    CygnusX-1 Junior Member
    Maybe when they first designed the mechanical housing, they thought they might need 6 LEDs. Then after building the prototype, the realized that they only needed 4. Or maybe LED technology improved such that they only needed 4. WooHoo built-in cost reduction...
  11. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :confused:Most would assume there's six LEDs. When the LEDs are on, it makes sense to me they used only four. They are about the size of a fog light and the six LED shape might not look right. I use my LEDs everyday and I like the look. Audi started the LED look and almost everyone does it now. Biased, but I like the LED look on my 2011 Lexus IS the best.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Those 4 DRL LEDs are pretty bright. It does it's job.
    To be honest, I didn't release only 4 of them light up until you pointed out.
  13. Rezar1
    Rezar1 Junior Member
    Is there anyway to have the DRL on at the same time as the headlights? I like them much better than the fog lights.
  14. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Yea I wish they were always on as well, not sure why there is even a point to having the ability to turn off DRLs, my other Toyota doesn't have this feature, and almost every PiP I see on the road is running around with them turned off (even my wife doesn't realize that DRLs aren't on when in switch is in the OFF position).
  15. Chris_SoCal
    Chris_SoCal Junior Member
    44
    Wildomar, CA
    I never really looked at them that closely.
    Now I feel I need to find some parts to activate the other 2 Positions in each assembly...
  16. Sfcyclist
    1,621
    375
    SF, CA
  17. Chris_SoCal
    44
    Wildomar, CA
    Some weekend when I have time I will pull my board out and see if it could support the requirements of another LED or 2. (I am sure this board has some spare power capability present) I may not be able to find the exact matching array they use in the existing 4 positions but I have some cutting edge surface mount devices that are astoundingly bright for very low power consumption. Maybe I can rig something up and post pictures.
  18. Sfcyclist
    1,621
    375
    SF, CA
    With LED parts readily available, might be easier to build a new assembly all together! These are fairly powerful though.
