Front wheels chatter on any sudden bumps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saawan, May 11, 2013.
  1. saawan
    saawan New Member
    I have been driving 2013 model for five months. i noticed that whenever any front wheel rolls over cat-eye on the road and any sudden small bump then it generates noticeable clicking sound. i went to the dealer and they said it is normal and comes with all such cars.
    do you think that it is a true with all 2013 prius or any gen-III model?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    BS on the dealer's part. Mine has never clank, clinked or otherwise. It might be your brake calipers. There were problems with the 10 and 11 HB. They add shims to help things out.
    Welcome aboard by the way!
    Rupert B Puppenstein likes this.
  3. Rupert B Puppenstein
    Rupert B Puppenstein Active Member
    261
    126
    North Carolina
    I agree that it is BS. Take it to a different dealer to look at. Drive with them in the car so they can witness it first hand.
    spiderman likes this.
  4. El Dobro
    El Dobro A Member
    7,086
    3,263
    I have the same thing with my PIP and I had it with the 2011. It's the bottom of the front outer brake pad ends hitting the caliper bracket.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    There is a TSB for the 2010's for front brake chatter. I am not sure if this would apply to your 2013. I would think this fix would have carried over to newer cars.
  6. El Dobro
    El Dobro A Member
    7,086
    3,263
    You can apply the TSB if you want, but the clacking comes back, unless you also lube the spots I indicated in my previous post. I used a heavy paste silicone lube Delco makes for brakes, and it's been about 1000 miles and the noise I was hearing is about 75% gone.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    I had a similar noise on my 2005 and my 2012 Three. I can't remember if the PIP does it. I've gotten so used to the sound.
  8. El Dobro
    El Dobro A Member
    7,086
    3,263
    I couldn't, that's why I wanted to find out what the noise was. Going down a quiet street with the windows open was like fingernails on a chalkboard. :mad:
  9. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I regularly drive dirt roads with my 2010 and have the brake clicking and chatter. It's never worried me so I haven't brought it to my dealers attention.
  10. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    So this is in addition to the drive and brake release on bumps? That chatters. Come to think of it, the streets here are so bad I get a lot of rattling. I was wondering what was loose, my teeth or something on the car? ;)
  11. Former Member 68813
    3,524
    983
    US
  12. El Dobro
    El Dobro A Member
    7,086
    3,263
    The UK ones look pretty big.
  13. David Beale
    5,963
    1,988
    Edmonton Alberta
    Well you're not supposed to be driving with your wheels on the centre line! And when you cross it the game is to do so while missing the reflectors. ;)
  14. tach18k
    tach18k Member
    406
    SoCal Beach Area
    If you listen closely, it is the wheel covers that you hear when you go over bumps, remove them and see if the sound goes away
  15. El Dobro
    El Dobro A Member
    7,086
    3,263
    PIPs don't have wheel covers, but they still have the rattle. In my case, it's the outer brake pads hitting the caliper brackets.
  16. David Beale
    5,963
    1,988
    Edmonton Alberta
    If you look at my avatar I also don't have wheel covers. They're hanging on the garage wall and I'm pretty sure I can't hear them when I'm driving. ;)
    Do keep in mind the rocker panels are plastic and quite flexible. They could also contribute to strange noises. But the brake backer plates are probably the culprit.
  17. Gilbert
    Gilbert Member
    255
    I also have this annoying sound on my 2012 solar -_-
    sounds like somethings broken.
  18. JuRuKi
    JuRuKi Junior Member
    61
    i have this same issue. Did anyone go to the dealer and get this fixed? Im thinking about going soon but dont wanna get the same old "its normal" answer
  19. Gregg Symington
    Gregg Symington Junior Member
    28
    Connecticut
    I've got an appointment for this exact noise along with my 5000 mile service at the dealer this weekend. I'll let you know if they do anything. I hope they do...
  20. Gregg Symington
    28
    Connecticut
    *UPDATE*
    I was asked to take the technician on a test drive to verify the noise. He heard it and was shocked a car with only 5k on it was doing this. He put the car on a lift and was able to recreate the noise but hitting the tire with a dead-blow hammer. He pulled the wheels and dissembled the brakes. I was shown that there was a lack of grease between the pad and the caliper saddle. They applied grease to the saddle and caliper slide pins and performed the 5k service. I took the technician for a final test drive and the noise is now gone.
    Feri and spiderman like this.
