Dealer's applique install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by tag, May 26, 2004.
  1. tag
    tag Senior Member
    2,526
    Chicago
    Hey, do any of you(s) think I should make them do this over? :lol:
    They already ordered and received another one.
  2. DaveG
    DaveG Member
    806
    Vancouver, BC
    Looks a little bubbly to me. Wonder if they washed it properly before trying to apply it.
    Dave
  3. tag
    tag Senior Member
    2,526
    Chicago
    Good question! But I just saw a pic in the Photos section of Rick's (htmlspinnr) applique and it looks about the same as mine.
    This is a tough one because I'm not exactly sure how it's supposed to look. All I know is the guy in the service department wasn't happy with the result.
  4. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    They put it on backwards. They put the top on the back.
  5. Brian
    Brian Member
    480
    Bakersfield
    No, it is on correctly, just look to the left and you see the PRIUS logo.
  6. glscheil1
    150
    Raytown, MO.
    [/quote]
    No, it is on correctly, just look to the left and you see the PRIUS logo.[/quote
    The portion on the vertical surface with the little rectangles should be on the top of the faceplate (bumper).] That's the only way it fit correctly. Look at the installation sheet that comes with it.
  7. tag
    tag Senior Member
    2,526
    Chicago
    Just for reference, here's the pic posted by htmlspinnr (Rick):
  8. tappel
    tappel New Member
    44
    Brattleboro, Vermont
    Mine came installed...I assume the dealer did the work. I didn't realize it was an applique until reading a couple of posts on the matter. It looks as though it was painted on...no bubbles, etc.
  9. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Sorry if this sounds stupid, but what is it?
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    It protects the bumper from scratches when removing items from the trunk.
    I foobar'd in a previous vehicle and removed a furniture dolly blade down, and scratched the bumper big time. Such an applique would have reduced or eliminated such damage.
    Yes - there are bubbles in that pic. No, not all come that way. Mine was port installed I believe, and it looked just fine. No bubbles to speak of.
    -Rick
  11. Just-Jay
    Just-Jay Junior Member
    The pictures are coming up 404, and I haven't seen the applique but am considering one. If it is essentially a big, heavy-duty clear sticker as I suspect, there's a trick to applying them.
    Clean the bumper thoroughly. Mix up a very thin soap solution, like about a half-teaspoon of liquid dish soap to a quart of water. Put this in a spray bottle. Spray the bumper, and as you peel the backing off of the sticker, spray it. This will buy you time to align things perfectly and squeeze out any bubbles. Use a rubber roller or firm pressure to put it in place, and leave it undisturbed for a couple of days.
    I was shown this by a sign shop that puts permanent signs printed on clear plastic on the doors of vehicles.
  12. glscheil1
    150
    Raytown, MO.
    The portion on the vertical surface with the little rectangles should be on the top of the faceplate (bumper).] That's the only way it fit correctly. Look at the installation sheet that comes with it.[/b][/quote]
    If you look at the top surface from an angle, the words "PRIUS" appear.
  13. tag
    tag Senior Member
    2,526
    Chicago
    After returning to the dealer and having another service guy look at the applique, I decided against having it re-done. It is installed correctly and, upon close inspection, there were only a handful of bubbles on the right side.
    Frankly, I was concerned that the second one might have looked worse. Further, the service associate said that, since the applique was part of the original deal, it was guaranteed for 3 years and, if it started to look really bad, they'd re-do it free of charge.
