10k Mile Oil Change Interval too Long for Synthetic?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cycledrum, May 10, 2013.
  1. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    3 years later
    mmmodem and cycledrum like this.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Jiffy Lube scam, i could see that. Last year took my mom's car in for service, '92 Mazda 626. They sold me on transmission oil change also. That was a mistake. Turns out they don't drop the transmission pan, they only suck the fluid out of the dipstick port. Had transmission slipping for a while, but it's gone away thankfully.
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Point was Jiffy's lube and similar service centers marketing to convince everyone 3k mile oil changes were necessary.
    Scams...that can be anyone but we can decide where we bring it to.. I'm just telling you to know when.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I third that one. Went in with a 19 year old Mazda 626 just for an oil / filter change. Next thing they are showing me the color of its tranny oil vs. their new tranny oil. I knew it had been a 3 or so years since changed, so went for it. What they didn't say is they take the shortcut of sucking the oil out of the dipstick port. this caused transmission slippage under certain conditions. It stopped after a few months.
    I'll never go back to Jiffy Lube for any vehicle.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You found out why they are often referred to as 'iffy Lube
    Merkey likes this.
  6. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Mine are posted here up to the 40K change. I'll post the 50K UOA here shortly.
  7. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Here's my 50K UOA, along with some prior ones for reference: I now commute about 400 miles/week, so lots of highway miles. The 15K and 25K UOA's are samples drawn from the dipstick hole - not oil changes. I too was skeptical of the 10K oil change interval until I obtained these reports.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Doesn't surprise me at all. With my Old Accord, one time I let them talk me into a coolant flush and exchange. I watched them, they did NOT do it, then they apologized and "did it" outside the bay in the parking lot.
    I can't prove it, because the Accord over was 15 years old, but it had been running perfectly. Shortly after that shoddy "Coolant Flush and Exchange" my radiator died. This resulted in a whole new radiator being needed as well as the engine which had been perfect, suddenly leaking oil because of the burnt gaskets when the engine overheated.
    Never had a speck of engine problems or radiator problems until I made the mistake of letting Jiffy Lube do anything outside of an Oil Change.
    Yeah, I'm never going back to a Jiffy Lube or similar outfit, I just don't think you can trust them.
    sdtundra likes this.
  9. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,718
    1,759
    Bay Area
    There's YouTube now, all the "Do it yourself" automotive videos are on there. Watch it, learn it, and just do it! :) no more JIFFY LUBE!
  10. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I won a free oil change at the localJiffy Lube as a raffle prize back in the early 90's.
    Not knowing any better- I brought my car in for the free service. I was shocked to see the "technician" putting the oil drain plug back in using a 1/2" air impact wrench! Not a 3/8" air ratchet... but a true 1/2" air impact wrench- the same tool they use to remove & replace tire lug nuts! And- to make matters worse- he didn't even hand start the plug- the just power threaded it in the whole way with the impact wrench.
    Needless to say- I never returned to Jiffy Lube after that.
  11. Mendel Leisk
    41,804
    Someone with a bit of business savvy could likely come up with a viable alternative to Jiffy Lube and the rest of that ilk. Kind of a "Luscious Garage" for oil changes only.
  12. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    About to turn 100 (thousand miles) have followed Toyota's recommended schedule and my oil is still almost clean at oil change time.
  13. The Electric Me
    9,083
    5,801
    Sometimes a topic is introduced into a forum...and other points are made.
  14. ra3boy
    ra3boy Junior Member
    27
    NYC
    OK, enough with BS! Can anyone point me where it says 10K miles in owner manual?
    The maintenance booklet still states 5K miles or every 6 months.
  15. Mendel Leisk
    41,804
    In Canada it's 8000 km (~5000 mi) or 6 months. But in the States Toyota's saying 10,000 miles or yearly, whichever comes first. This is from a pdf from US Warranty and Maintenance Guide:
  16. ny_rob
    1,968
    813
    L.I.- NY
    Page 38 in the US 2012 Warranty and maintenance manual..
  17. Mendel Leisk
    41,804
  18. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    Toyota says 10k on my 2012 Prius and Mazda says 7500k on my CX5, I guess I follow what they say!
    My Toyota dealer have a $99 lifetime oil change when u buy a new car w/ a 200k engine warranty.............
  19. ra3boy
    27
    NYC
    Thank you! That red thingie helped a lot!!!
  20. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    As an aside....
    After my car had 40,000 miles on it, I did an oil analysis. The results came back with good marks and the assessor at Blackstone commented that the car could probably go another couple thousand miles between oil changes should I desire to do so (I don't desire to do so).
    Your Mileage May Vary. Past performance is no guarantee of future returns. Etc.
    Long and short, with modest driving and synthetic oil, your car should be able to do well with 10k oil changes.
