vinegar smell on start up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by philobeddoe, Oct 7, 2009.
  1. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    this may sound odd ... but i hope someone has experienced it so that i may find a solution
    when i start the car up, it smells like vinegar in the cabin
    details ...
    it's a 2008 Prius, i leave the a/c on all the time (i'm in socal), the car is parked outside, but in the shade, and i religiously change the cabin air filter
    i've taken to starting the car with the door open, i reach in with my right foot and hold the brake, and reach in with my right arm to hit the start button ... so as not to be in the car when it starts to avoid a blast of it
    the smell dissipates in seconds
    anyone have a similar experience?
    what the ... ?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Are you sure you are not smelling the Antifreeze. It has a distinct sour oder, and if you are smelling it, you have a coolant leak, probably a small one since it seems to go away, but you say its back when you return to the car?
    Meebee a trip to dealer is in oder order!!
  3. philobeddoe
    575
    107
    Los Angeles
    i don't think it's coolant
    it's only on startup, for a second or two, and it smells decisively like vinegar
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
  5. philobeddoe
    575
    107
    Los Angeles
    nice ... thank you :thumb:
  6. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    men, I got the same problem last week. How was your car turned out to be?
  7. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Toyota to the rescue! :rolleyes:
    Most dealers stock a two part A/C Power Foam Evaporator Cleaner & Refresher
    Kit. Dealer will want you to have the service dept. do the job for ~$100, but if
    you're insistent, you can get the kit for ~$25 and DIY
    The sales pitch on the can says: 'is a quick and easy to use treatment for the
    elimination of odors caused by the presence of mold , mildew, and microorganisms.
    Power Foam's unique foaming and cleaning agents fill the entire evaporator
    case assembly with highly effective active ingredients which dissolve and wash
    away contaminants'
    You squirt the foamy stuff up thorough the evaporator drain tube, which you have
    pulled up into the cabin. After a short period of time you drain the foam-turned-liquid
    into a container. I used the cleaner, but not the perfumed 'refresher, as part of
    clearing a drain tube blockage last summer. Simple, pretty quick and effective in my
    experience.
    See also: Toyota Prius 2006 air conditioning ventilation service | PriusChat
  8. CaliforniaPrius
    313
    201
    Alameda, California
    How do I do that? Where can I find this evaporator drain tube?
  9. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Good questions.
    I used the A/C Power Foam Evaporator Cleaner & Refresher Kit about a year ago.
    Here's what I think I remember:
    The evaporator is located up under the dash on the passenger side. It would behelpful,
    though not necessary, to peer under the car to preliminarily locate the drain tube. It's
    black, about 3/16 in. in diameter and hangs down 3 inches or so.
    Inside the cabin, you need to peel back the carpet in the passenger's foot well to get
    access to the drain tube all the way to where it goes through the floor. I seem to
    remember that the tube runs through a soft rubber grommet. It doesn't matter if the
    grommet puls away with the tube when you pull the drain tube back in. I was able to
    do this without distrubing the hard plastic pieces near the door and the center stack.
    IIRC, the hardest part of this was reseating the rubber grommet in its hole, and getting
    the carpet to lie smoothly under the edges of the hard plastic pieces near the door and
    center stack when putting things back together.
    Hope this helps.
