1/3 qt. oil consumed after 5.5k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rocketrob, May 21, 2013.
  1. rocketrob
    rocketrob Member
    104
    Los Angeles
    Here's the story: '07 with 72K. This past oil change interval I drove way more miles than typical. I made 3 round trips between LA and Bay Area, 350 miles each way. One of those trips the Prius was absolutely packed with heavy boxes and gear on a 90+ degree day. If anyone has made the trip on I-5, you would know about the Tejon Pass, aka the Grapevine, aka the car killer. For those that don't know, think long and excessively steep mountain pass. Right, so I've done that three times now.
    With all this driving I didn't have time to get the oil changed right at the 5K interval, so I wound up being ~500 miles over the recommended change mileage.
    Question: Is it alarming that the engine consumed ~1/3 of a quart over 5.5K miles given such taxing operating conditions?
    Probably nothing to be concerned about but wanted to run it by PCers regardless... Thanks!
    52,001
    are you saying it should have consumed more?
  3. rocketrob
    rocketrob Member
    104
    Los Angeles
    i'm asking if it's any surprise that any oil was consumed at all.
    could it be an indication of engine wear? (shocking!):eek:
  4. bisco
    52,001
    no, not at all. and under those conditions, even less. (y)
  5. rocketrob
    rocketrob Member
    104
    Los Angeles
    ok cool. Guess I'm ready for the next Cannonball Run...
  6. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    The Grapevine cannot be appreciated until you did the climb and decent. There have been train wrecks on it.
  7. JMD
    3,779
    1,282
    The Train Wreck 69 cars plus three locomotives. Dynamic brakes failed on the rear locomotive could not stop the train. Pullman applied the emergency brakes which deactivate the dynamic brakes on the 2 working trains thus the train speed up and at the bottom of the mountain on a turn derailed and afterward a petroleum tank explosion
    San Bernardino train disaster - Wikipedia, the free encyclopedia
  8. rocketrob
    rocketrob Member
    104
    Los Angeles
    woah. off topic, but your info on the rail line thru Tejon caused me to stumble across the Tehachapi Loop. Pretty awesome stuff.
    Anyways, it's not just the Tejon Pass. I-5 is a pain that entire stretch between Santa Clarita (where Route 14 splits off) and Grapevine. It's common to see disabled cars waiting for tows, even the nice new models (that is, if you're of the mind that Mercedes and BMWs are 'nice'). Semis take that stretch niiice and sloow, 20mph in the right lane.
    JMD likes this.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Seriously rob, you seem to have an unrealistic expectation that your Prius will never consume any oil. This could cause you to run low on oil at some time in the future if you get too complacent.
    Many people notice that at around 100k miles their Prius starts to use a modest amount of oil. You need to be open to the prospect of getting some oil consumption and perhaps even require topping off between changes as your Prius ages. So don't forget to check the dipstick fairly regularly, even if you think it shouldn't have consumed any.
    Britprius likes this.
  10. rocketrob
    rocketrob Member
    104
    Los Angeles
    I never said that I was surprised by the oil consumption. I asked if others found it surprising. I knew about the oil consumption because I regularly check the dipstick.
    Semantics aside, I think the Prius handles that tough trip like a champ. My '96 Corolla 1.6L 3speed, on the other hand, is a different story.
  11. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    This amount of oil usage would not be considered excessive by Toyota for a new Prius, so I do think you are overly concerned. However as Uart says the oil should have been checked at leased 5 times in that 5,500 mile period.
    John (Britprius)
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    No problems Rob, that's the way to do it. (y)
    Over the various cars I've owned I've noticed that oil consumption is often slightly greater at freeway speed when the engine is working hard, compared with around town driving where oil consumption is often less apparent. Depending on the age and mileage, anything less than one full quart over 5000 miles is not particularly seriuous. One third of a quart is pretty close to nothing. :)
    BTW. I've got about 112k miles on my 2005 Prius, and the consumption is pretty consistent at around half a quart per 5000 miles.
    rocketrob likes this.
  13. Britprius
    5,194
    1,921
    Uart do you use the UK or US quart in Australia.
    John (Britprius)
  14. rocketrob
    rocketrob Member
    104
    Los Angeles
    re: uart
    Thanks for your data points! Naturally, oil consumption can vary depending on driving conditions. I, too, notice that oil consumption slightly increases with freeway driving, particularly on older, high-mileage engines.
    Case in point, the Corolla I mentioned earlier can burn ~1qt over 1k miles if driven hard on the freeway. (its 3speed transmission requires high revs to go more than 65 mph) but in city driving consumption is reduced to something more like 1qt over 2k - 3k miles.
    Up until this point, I can say with certainty that my Prius has now not shown any signs of oil consumption. Oil was at the top of the dipstick and essentially clear at every 5K mile oil interval. Then again, I don't typically travel long distances at freeway speeds (not to mention that dang Grapevine! ugh :) )
    Thanks for the good discussion.
  15. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi John. We're strictly metric here, so km and litres etc. :)
    On these forums however I often use quarts (US) in place of litres. This is just because most of the participants here are from the US, so I figure it's easier for them. The conversion is close enough to 1:1 for discussions like this, where super precise quantities aren't required. I think the exact conversion is 0.94625L per US quart.
  16. bisco
    52,001
    in the 70's, i had a '66 mercedes that used more oil than gas! i used to keep a case in the trunk and would have to stop and top it up on trips.:p
  17. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Rob,
    I have been seeing more and more posts about Gen II Prii burning oil and the need to watch it every 1,000 miles or so. My Ema burns about a quart every 1,500 miles or there about. Then again she has 337K on her engine that is almost all highway miles.
    I can confirm that high RPM's and steep climbs do significantly increase the Burn in Ema. I used to climb big hills on cruise and just let the little engine whine up to over 4,000 RPM. Now I turn the cruise off and try and keep the RPM's under 4,000 (scanguage). It seems to help some.
    I personally have not had any luck with engine "treatments" but some have. If you want to look into that I recommend this thread - 2008 Prius - burning oil at 135,000 miles | PriusChat
    Avi seems to have had some luck with seafoam in lower mileage engines. I have tried several things and have concluded my engine is just pretty much worn out, lol. Of course after 337K miles I can't really complain.
    Happy driving,
    Chris
  18. Winston
    Winston Member
    614
    SF Bay Area, California
    I have 115k miles on my car and burn 1 qt per 5000 miles.
  19. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I guess thing have changed since they made my 88 Camry, I have 275,000 miles on it and change the oil every 5k and Betsy don't burn a drop. I guess I will have to start checking my Prius dip stick.
  20. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    that is very low oil consumption.... no worries there
    Something most people don't consider is that oil also functions as a coolant as well as it's primary purpose as a lubricant.
    Therefore, as the oil level drops below the full level the oil starts to run at a higher temperature. The lower the level the higher the oil temperature. The higher the oil temperature runs the faster it vaporizes (burns)
    So as others have said, check your oil more often, and add oil when necessary.
