2007 Prius Inverter Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bruce Fealk, Jun 3, 2013.
  1. Bruce Fealk
    Bruce Fealk Junior Member
    My problem started about two weeks ago. The red triangle came on with the brake warning indicator. After I stopped the car, it wouldn't start again and several more indicator lights came on.
    I took it to the dealer and they replaced the auxillary 12V battery.
    I picked up the car, I was driving on the freeway, the same red triangle light came on with the brake indicator light.
    When I stopped the car at my destination and tried to start it again, the same warning indicator lights came on. I had it towed to the dealer. The told me the diagnostics gave them a code P0AA6 and 526 and told me I needed a new inverter, a $3600 part. I found a used inverter and drove the car to a repair facility that works on hybrids. They installed the used inverter and I drove the car to a restaurant near home about 20 miles away from the repair facility.
    When I left the restaurant, the same red triangle came on again and when I got home and tried to restart the car, the same multiple warning indicators came on as originally when I took it to the dealer.
    Any input that could help diagnose this problem would be appreciated.
    52,021
    what was the opinion of the place that works on hybrids before they did the install? how many miles on her?
  3. Bruce Fealk
    It has 114,000 miles. They tested it before giving me back the car after installing the used inverter. All the codes were clear.
  4. jdenenberg
    jdenenberg EE Professor
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You may have a failed Inverter Coolant pump or an air bubble in that coolant loop. Check for turbulence in the reservoir while in "Ready" mode.
    JeffD
  5. Bruce Fealk
    The repair facility I don't believe re-diagnosed the problem. They are sending a tow truck today and providing a free loaner.
  6. Bruce Fealk
    I did have the pump replaced under a recall in Feb 2011, but I was thinking the same thing. The repair facility did drain and refilk the inverter coolant pump.
  7. nklb
    nklb Member
    111
    edit: oops, concern was already addressed
  8. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    worth a quick look but do you have your grill blocked or have any debris in the radiator, and maybe worth checking that the radiator fans work.
  9. Patrick Wong
    18,210
    6,510
    I believe that you posted about this in another thread. Your car has a high voltage ground fault. It appears that the inverter is not the issue. The ground fault could be due to any component that is exposed to high voltage.
    The troubleshooting approach requires use of a megger (which is an ohmmeter that uses a high voltage) and disconnection of the various components, to determine where the ground fault is coming from.
    Here is an example of a ground fault which was determined to be from the transaxle:
    Luscious Garage | Blog | Gen 2 Prius (2004-2009) Transmission Failure, P0AA6, P0A92, P0A7A
    dragonspeak likes this.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    To follow up on Patrick's post above, here is the DTC information for a 2010 with P0AA6 with subcode 526:
    P0AA6-526
    Hybrid Battery Voltage System Isolation Fault
    - Hybrid vehicle transaxle assembly
    - Generator cable
    - Motor cable
    - Inverter with converter assembly
    - Frame wire
    - No. 2 engine wire
    - Hybrid battery junction block assembly
    - Compressor with motor assembly
    - HV battery
    - Battery smart unit
    I would expect your 2007 would be similar. The dashes at the bottom lists the possibilities.
  11. Bruce Fealk
    Thanks. I sent that information along to the facility repairing my car.
    jdcollins5 likes this.
  12. dragonspeak
    dragonspeak New Member
    So the red triangle with the brake warning light means an isolation fault possibly in the transaxle! Maybe replacing the unit or changing the transaxle fluid?
  13. Patrick Wong
    18,210
    6,510
    No. The master warning red triangle simply means that a problem exists.
    A brake warning light means that the skid control ECU has a problem.
    The high voltage ground fault would be reported by the hybrid vehicle ECU and the hybrid vehicle warning icon would normally appear in the upper left corner of the MFD. However the nature of the problem would not become apparent unless the DTC were read.
  14. maverick1970
    maverick1970 Junior Member
    32
    McDonough, GA
    Hello Bruce Fealk. Do you have an update for us?
  15. bisco
    52,021
    unfortunately, bruce hasn't been seen since 2013. maybe pm him, he'll get an email notice.
