Power socket in center console not working - fuse OK
Discussion in 'Gen 3 Prius Main Forum' started by sbddude, Jun 4, 2013.
  1. sbddude
    sbddude Junior Member
    62
    Bay Area, California
    2013 Prius v wagon
    My 2010 II has two power sockets, one under the radio, and another inside the center console.
    The center console one does not work, whereas the other one does. I checked both the fuses, and even swapped the two fuses. I also checked several other fuses just to be sure. No fuses are blown and nothing changes by swapping the 2 power port fuses.
    Anything else that could cause this?
  2. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    Had this happen to a Subaru and Mazda I used to own.They had a fuse attached to the back of the socket,I jumped them out,but the right thing to do is replace the socket.
    steve
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    Have you tried another cord. A lot of time the cord plug has it's own fuse in the tip.
  4. sbddude
    62
    2013 Prius v wagon
    Yes, the same charger that works in the front socket does not work in the rear, along with many other chargers we have around the house.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I thought my center console was busted as well. I tried another charger and it worked. Turns out the center console is sized really tight. I jammed harder with the 1st charger and it worked.
  6. attyjeff
    attyjeff Member
    153
    40
    I added a new power outlet like most cars have on the back of the armrest. Look in the mod section if you want to learn more.
  7. ES44AC
    ES44AC C.A.U.S
    319
    77
    I'd be checking the socket with a simple 12v test light to see if you have voltage. If you do then plug in what you want to use and use the probe on the light to test if the wire on the charger or whatever is getting power. You may not be making contact to the center of the socket.
    hope this helps
    ES44AC
  8. El Dobro
    El Dobro A Member
    7,093
    3,271
    If you don't have any voltage coming through, the connector on the back of the socket may be disconnected.
  9. mtbiker53
    87
    22
    cape cod
    nice...thanks for posting.
