Gen2 Puddle lights?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Jun 3, 2013.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Anyone attempted doing this? Wiring in some lights under the side mirrors to turn on with dome lights as the car is unlocked - or when the smart key is sensed and the interior lighting comes on?
    I know the Gen3 has it and you can order the turn signal mirrors for the Gen2 and they have it...but I don't want to spend that much on turn signal mirrors.
    Also..best place to connect the wiring? I keep hearing of a 'magic blue wire' - any advice?
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Couldn't find anything about the Gen2 but more on the Gen3. DIY JDM style side mirrors combo lights (Signal+Parking+Courtesy lights) | PriusChat
    Might try this approach:
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Thought This would be a good place for the lights.
    Found these: Aliexpress.com : Buy New !!! 9W High power IP68 DRL Daytime light Reversing Radar shape Eagle eye Led Rear backup tail lamp Full Aluminum body from Reliable daytime light suppliers on Easylink Technology Co., LTD
    A month later or so - they arrived. Installed with a 15/16 wood circle bit.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Inside shot:
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Routing the wiring:
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Wanted to try something new as well while I had the mirror covers off - PlastiDip'd the side mirror covers
    Daves09prius likes this.
  7. Tideland Prius
    16,615
    That's an interesting alternative!
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    One Nice thing is they are waterproof...so I'm not concerned with moisture getting into the side mirror. Pretty bright on initial testing...
  9. cozmisu
    cozmisu Junior Member
    24
    Romania
    Post some pictures on night with them.
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Plan on it. Currently the LEDs are mounted in the mirrors and the wiring is rounted thru the mirror into the door, but I haven't routed the wiring thru the door thru the rubber wire loom into the cabin.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Last night I attempted to locate the wiring from the dome light under the dash. No luck. Found it again in the pillar but didn't feel confident tapping in there.
    Ended up routing some wiring from the dome light down the B pillar and up to the dash area where I'll connect the LED wiring after I route it thru the rubber wire loom in the doors. Once I have it completed, I'll show more how I connected it all.
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Posted up pictures of the final install HERE
