Wheelskins Steering Wheel Cover my Favorite Mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cycledrum, Jun 14, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ok, I haven't done so many mods on my Prius, but I would do this mod over any day. Before getting it, used to think, I don't know, takes away the OEM look, covers up silver spokes, blah, blah. After lacing, one spoke ended up a little bunched up, but I don't care. Wheel feels great. Good for big hands too.
    If any complaints about the rough plastic, either replace with JDM wheel or get one of these. Priuschat shop sells them. :)
    (I know, it's a little bunched in places, but hey, first time lacing)
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    My installation of my Wheelskins is similar to yours.
    In other words not perfect.
    But also similarly while I wouldn't say it's my favorite "mod", I almost call it a necessary modification.
    I'm NOT spoiled, I don't need "Fine Corinthian Leather" at every place around me. I don't mind a plastic dashboard, infact I kind of like the durability and ease of maintenance.
    I bought a Prius 2, and it seems plenty well appointed for my desires.
    But the "standard" plastic steering wheel in a Prius? Oh my god, it's not just plastic and economically produced, it's absolutely horrible. Why Toyota produced a steering wheel, even entry level plastic with the feel of fine grain sandpaper? I don't know.
    Yeah, wheelskins are nice quality leather. Gives a nice feel to the steering wheel. Installation, especially I think on a wide spoked Prius wheel is NOT easy. But outside of buying an entirely new wheel, I would say it's just about a necessary modification.
    I don't consider myself a particularly picky person, and I've owned and driven vehicles with simply standard plastic steering wheels, but the hellish feel of the original Prius Steering wheel demanded SOMETHING be done. Therefore for me the Wheelskins became almost undeniably necessary.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Well said.
    btw, I've seen even wider spokes on a particular brand of car starting with an H.
  4. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I agree! This has been the first mod I complete for my last 5 cars. This is kinda tricky to make sure that the leather doesn't bunch up. Each of the stitches needs to be very tight as you are going along. Well worth the $38!
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I've heard it's possible to pull the laces a little too tight which can stretch the cover a bit causing a bit of bunching. Pretty sure that's what happened on my left spoke as I started at 12 oclock, went clockwise and it was last spoke. No biggie, love it anyway :)
  6. xliderider
    xliderider Senior Member
    8,122
    3,265
    Honolulu, HI
    Yup, one of the first things I put on a car that doesn't come with an OEM leather wrapped wheel.
    Gotta love that nice smell of real leather too. :D
  7. rj250
    rj250 Junior Member
    22
    San Diego
    I spent 2 hours installing my Wheelskin, well worth it. No wrinkles, and feels great. You do have to put on some gloves, and pull the lacing very tight. I bought mine from the PriusChat store. Best price around.
  8. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I bought a WheelSkins cover for my steering wheel, even though it is leather. The finish was coming off at the 9 o'clock position (where my hand rests), so I wanted to cover it. I did have an automotive interior upholsterer install it. Cost me slightly more than the price of the cover, but, to me, it was worth it. I've done them before and they're a PITA to be sure. And, mine looks close enough to perfect as to not make a difference. (I'll try to remember to grab a photo and post it up.)
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Same thing happened to me and it is a factory defect (replaceable under warranty). But I simply replaced it with the much nicer JDM piano black steering wheel for $190.
  10. chrisj428
    680
    144
    35
    Vernon Hills, IL
    32k, by the time the "defect" appeared, I was at about 70k miles, way outside of any warranty, wear-and-tear or otherwise. Sometimes, things just wear out. That doesn't mean they're defective.
  11. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It's not normal for leather to wear out in that short period of time. An extreme example of factory defect can be found here.
  12. chrisj428
    680
    144
    35
    Vernon Hills, IL
    Mine wasn't anywhere near that bad. I know that when I worked for VW, we found a correlation (right, wrong, or otherwise) between hand cream usage and how quickly the finish peeled off the steering wheel covers of MkIV Jettas.
    I feel that, after 70k of my hand primarily touching that one spot, the failure was not out of line and indicative of a manufacturing defect. There may have been a nick or some other inflicted blemish there which accelerated the process (not unlikely, given that's my main point of contact). Either way, I'm certainly not going to blame Toyota for a wear-and-tear cosmetic issue on a vehicle which has accumulated over 80k miles in less than four years. If I wanted near limitless durability, I would have chosen the plastic wheel option. But, I understand the tradeoffs.
    To wit: while my great aunt's covering of the couches and chairs in the living room extended their longevity where cosmetic issues were concerned, it certainly didn't make them enjoyable to use. I'd rather enjoy the use.
  13. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Fair enough, as that's your prerogative. In my case, the deterioration happened to be aligned with the path of the sun while my car was parked outside on the weekends and I don't normally drive with my right hand there. I'm fairly certain if my car were to sit outside daily it would have looked like the OP in that thread.
    chrisj428 likes this.
  14. TchmYng
    TchmYng Junior Member
    2013 Prius v wagon
    I just installed a wheelskins cover today. I LOVE IT! My install looks similar but I had a little more puckering at the bottom spokes. I think I went a little overboard on making it "tight".
    iPhone ? - now Free
