Master, VSC, Brake and Hybrid Indicators On - Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GreaseNerd, Jun 16, 2013.
  1. GreaseNerd
    GreaseNerd New Member
    Hello All,
    I purchased a 2004 Prius about a month ago for my kids to drive. I like it so much I traded in my Accord V6 for a 2010 Prius.
    Everything was fine up until it warmed up here in Virginia and the car (2004) started smelling pretty bad inside. I could tell when I purchased it the previous owner had a dog from a few scratches inside, but never imagined that I would find what I did. The dog left a little something of itself to be remembered by, and it was ill when it did it. How that odor was masked at the point of sale up until it did is beyond me! Needless to say I took the rear seat out as I was tracking down the odor and found the solidified treasure down on the passenger side under the bench, under the black metal brace for that side of the bench. I started to trace back the path and ended up taking apart the back end and passenger side. While I was at it I removed and cleaned out the Hybrid cooling fan that is next to the battery. Sorry for the disgusting prelude but it is necessary to set context unless this is pure coincidence.
    I put it all back together and yesterday afternoon I started it up and ran an errand. After about 5 miles the Master error indicator (red triangle), brake (!), VSC, and Hybrid indicator in the MFD all came on. I checked the voltage on the 12V battery per suggestions here on the site. Indications say it is in spec. I checked the inverter fluid for turbulence and saw plenty.
    The Hybrid water pump (assuming this is the inverter cooling pump) was replaced according to Toyota owner web site at 108,717 miles and 4/06/13 or 3 weeks before I purchased it. The 12V battery was replaced back in March 2010 at 84k miles.
    Today after having let it sit overnight, the 12V still reports good, but only the Master indicator and Hybrid icon in the MFD are displaying. The traction battery is down from 5 bars to 2, but that could be a result of putting a load on (A/C and lights) several times while testing the 12V I suppose. The ICE does turn on.
    I have an Actron 9175 OBDII scanner but it either will not pull hybrid system codes or there are none reported (not likely right?).
    Is it possible I knocked something loose or got something wet (spraying - but tried to be extra careful) in all my cleaning activities or is it pure coincidence that this has happened now? Any ideas on what to check or am I stuck calling the dealer and getting it checked out? It was originally titled in NY so the battery should still be covered under the 10 year 150k mile warranty.
    Thanks in advance.
  2. northwichita
    481
    102
    29
    Wichita KS
    Since this follows removal of the HV cooling fan, I would take off the rear panel over it and check the electrical connection powering the fan is firmly clicked in.
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Getting the codes read by a Prius specific reader is required. But I would put my ear by the HV fan intake while the car is in Ready mode, and make sure that the fan is running first.
    ...OK he said it first. Great minds think alike.
  4. GreaseNerd
    Thanks for the responses. I took the back end apart again and disconnected the battery entirely while taking things apart. I hooked up the fan directly to the 12V battery since it is a 12V motor - it worked. I made sure all connections were snug, reconnected the battery and drove for 10 minutes around the neighborhood with the rear panel off and the plastic air funnel to the rear seat removed so my wife could see if the fan came on. It did (after a couple minutes) and it stayed on. The codes were one as I would expect after having the battery disconnected. The indicators stayed off during my 10 minute test run, but they all came back (master, vsc, brake, hybrid) after going out again this evening (came on before making it down the driveway - its a short driveway).
    While doing all this I noticed a lot of water down in the auxiliary battery compartment. There was enough water to come up about an inch above the bottom of the battery (I removed the water and dried it out down there). I am thinking that the since the voltage levels are good and the battery is encased in hard plastic that it is ok. Am I asking for trouble?
    Any additional ideas? Any recommended code readers that will work on a prius?
    Anyone have experience with the mini-vci reader on ebay (I can't post a link yet, too new...) -- does it still require a techstream/TIS subscription?
    Thanks again.
  5. nh7o
    1,686
    340
    Hawaii
  6. GreaseNerd
    On the 2004 is there a difference between the (!) brake light and ABS ("ABS") error light?
  7. GreaseNerd
    Ok, so I jumpered the DLC3 pins 4 and 13 and got a solid red triangle, continuously blinking (!), ABS, and Airbag icons, and a VSC blink code of 51.
  8. nh7o
    1,686
    340
    Hawaii
    VSC Blink code 51 is C1310 "malfunction in HV system". That doesn't give much specific help, unfortunately. It just means that regen braking is being limited by something wrong elsewhere in the hybrid system. So more info required.
  9. GreaseNerd
    That's a start. I will see what the service manual says to check.
  10. GreaseNerd
    I re-checked the codes this evening since last time I let it sit this long the VSC and Brake indicators turned off. They did again this time and I jumpered pins 4 and 13 and got a continuously blinking airbag, Brake, ABS, and VSC indicators...no pause.
    I double checked the battery test again a couple times:
    Push power button once: 12.6 - 12.8v
    Push power button twice: 12.2 - 12.4v
    Brake and power button 3rd time: dropped to 11.9v briefly and jumped to 14.1 - 14.4v
    If I turned on the AC (max), lights, and rear defroster I would see the voltage drop to 14.1 and then 14.0 (saw it drop to 13.9 a couple times). When I turned these all back off it would only recover to 14.1v.
    If I read correctly these are all within spec. Am I wrong - is the drop to 11.9 an early indicator?
    Still trying to make heads or tails of the C1310/51 code and the service manual. Also saw thread where Leighman poo-poos AutoEnginuity (Got Autoenginuity, anything else I would need | PriusChat). Anyone have issues with this tool or any other (what have you had success with in terms of being able to read all codes including the hybrid systems)?
    Thanks
  11. nh7o
    1,686
    340
    Hawaii
    Your 12V looks to be fine for now. Note that the load test with the car in ready mode does not tell about battery health, as the inverter is supplying all the power at that point.
    The mini VCI does what you want out of the box. Torque will read the codes also. Toyota will do so for ~$100.
  12. GreaseNerd
    Thanks nh7o. Has anyone found a mini VCI that can get to northern Virginia faster than the slow boat from China? (checking Google and eBay now).
  13. GreaseNerd
    All,
    I received my mini-vci and plugged it in (thanks for the recommendations). It has been sitting so the VSC, Brake and ABS lights disappeared. Received the following:
    Past codes:
    Hybrid Control - P3000
    HV Battery - P0A85
    Current Codes:
    Air Conditioner - B1421 (my heat shield is on so it is blocking the light sensor...)
    Immobiliser - B2775
    Am looking these up and will scour the site. Any tips are appreciated.
  14. Patrick Wong
    18,200
    6,493
    DTC P0A85 is reported by the traction battery ECU and means that there is a problem with the battery cooling fan. Had you previously tried to run the car while leaving the fan disconnected?
    DTC P3000 is reported by the hybrid vehicle ECU and means there is a problem with the traction battery or the traction battery ECU.
    Given the water that you reported seeing around the 12V battery, it is possible that excess humidity has damaged wiring harness connections around the traction battery fan and traction battery itself. I suggest you clear the codes and see if they come back. If they do then you will need to fix whatever damage to the wiring harness occurred - if you can find any damage - and if not, then seek professional assistance.
  15. GreaseNerd
    PO8A5 was a previous code. I cleared codes and put 5 miles on the car with the rear exposed so my wife could see the fan working (also hooked it directly up to the battery and it worked). Later it quit again. Checked the relay which was bad and replaced - still not coming back on now. Time to check the controller... voltages on the battery seem fine - gap between min and max voltage across blocks is .1v
    Checking terminal connectors for signs of humidity damage...
  16. GreaseNerd
    Update: when I run the active test for the hybrid cooling fan it will not come on. Connecting the fan directly to the 12v auxiliary battery always works. In further testing I found that the plug for the cooling fan is receiving 2.3v. This is a little more than it is supposed to have for SP1.
  17. GreaseNerd
    I hope I have found the problem. I believe the water issue is related to the fan no longer working. Attached are 4 pictures showing corrosion on and in the plug that sits above the fan assembly secured to the body. The leak seems to be up high, possibly at the bolts that secure the hatch pistons to the body. Water then drips down (both sides of the body) and is what caused this. Anyone have experience replacing the connectors instead of the entire harness? 04 Prius Harness_Plug_4.PNG 04 Prius Harness_Plug_3.PNG 04 Prius Harness_Plug_4.PNG
  18. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    E-mail Plug In Hybrid Electric Vehicle PHEV and ask for a salvaged connector with all wires still attached. If they have one then all you have to do is to cut off the bad connector and splice the wires. Good luck!
  19. nh7o
    1,686
    340
    Hawaii
    As a quick work around, since you will need to cut wires anyway, is to cut the two trouble causing wires on each plug, and jumper over them with butt splices. It may be a long time before you are in there again, and you can splice in the good plug later.
    Patrick Wong likes this.
  20. Patrick Wong
    18,200
    6,493
    I agree that splicing the two faulty connections (four wires) is the best (and cheapest) approach given the circumstances.
