Bigger v means longer to cool cabin!
Discussion in 'Prius v Accessories and Modifications' started by vsuirpsteve, Jun 18, 2013.
  1. vsuirpsteve
    vsuirpsteve Junior Member
    32
    It was one of my many cons when shopping for a car. The things I did like in the C-max where the steering wheel, the many air vents, dual climate control, the blind spot mirrors and the air vents in the center console for the rear passengers, the optional lift gate and it felt like it had more power over the Prius v with a higher EV control (which really doesn't mean anything but cool.)
    Buttttttt.....my wife could not get the cmax seating high enough for her 5.1 inch frame so Prius v in the end won.
    So I bought a $20 fan sad but true to boost the air flow in the back cabin and ran the 12v wire under the floor mat and behind the rear seats to the 12v plug in the back.
    52,263
    how many more sq. feet than hatchback? same size a/c system and fan? mine throws so much frigid air it feels like it would work fine in a much larger car. but i'm not in a hot climate.
  3. bisco
    52,263
    i saw my first cmax today. cute but looked really tiny.
  4. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Is the airflow really that bad? There are actually vents under the front seats for the rear passengers, no idea how good they are as i've never ridden back there.
    Most of my riding is alone but occasionally have had a car load of 4 adults and no complaints from the back seats, maybe they were just being polite. :)
    I leave Climate control on auto and set to a comfortable temperature. I have noticed I have to dial the temperature lower with more people in the car to maintain same comfort as single driver setting, no biggie, just turn the dial.
    Only car I have to compare to is my previous Honda Fit. That car had a large interior space(for its class), lots of glass and a weak AC system, so I did notice with the Fit it was hard to keep it warm in the winter and AC could not keep up on the hottest days of the summer. My new v despite the larger interior space has no such issue keeping warm at -30*c and cooling nicely at +28*c.(hottest and coolest days i've seen yet)
    As always YMMV.
  5. vsuirpsteve
    32
    Well here in Tampa June means 95-100deg feel like temps...it takes quite some time to cool the cabin and if a vent is not blowing on you then you feel hotter. Even with the tint and being that I keep it in the garage it makes it just bearable but in a direct sun parking lot...forget it.
    The cabin space is a lot bigger! The hatchback.... 21.6 cubic feet with the seats up and on the V 40.2 cubic feet. Folding the rear seat takes cargo on the V to 67.3 cubic feet.
    I sit with the driver seat back and it covers the pathetic floor air vent but I guess it goes with the territory for owning the biggest cargo space to mpg ratio ride on the road.
  6. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Compared to my old 10' Prius IV, I've notice my new v cools down very quickly. I believe the hvac system in the v has been uprated from the liftback. The fan seems to move a higher volume of air.
  7. vsuirpsteve
    32
    I am glad that I got to have felt what REAL ac was in the older cars but today's green tech it seems to be a lot of hot air being blown around! ;-)
    If I could I would put a ceiling fan in the cabin but this little fan I bought really makes a difference taking the what little air that comes out of those vents (only when you have the up/down selected) on the floor and shoots it up where it is needed the most.
  8. vsuirpsteve
    32
    I am looking forward to the cooler months and running in EV mode but with the ac on all the time EV mode is just another dummy button that does nothing.
  9. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Toyota should add the solar roof option to the v like on the liftback ATP. Having the vents blowing air through when sitting in a hot parking lot would make a big difference to cool down time I think. Even my v as it is with tinted rear windows sitting in 68f temperatures outside gets pretty hot! If I could have the solar roof option and power seats on my v without all the other doodads it would be the perfect car. :)
  10. vsuirpsteve
    32
    Yea...good point that would be a nice option. This is my first car that kicks butt in the mpg dept. I never owned a car that got over 26mpg so this is a dream. Here in Florida where the biggest hill is a speed bump, hybrids work great...so far best mpg trip to date is 51.8mpg! I would imagine in BC there are many hills? I did notice that "B" on the shifter I take it is for hilly terrain?
  11. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Pretty sure those floor vents are for air from the front floor vents, as in heated air or any air directed to the floor. You can get some cool air from them in the "bi-level" mode too.
    The outflow air vents for the entire cabin are in the back by the rear door on both sides, so setting the "re-circ" to off should blow cool air all the way to the back. One of the real shortcomings of the v's A/C system is it's default re-circ setting, which cuts off air to the rear of the cabin.
  12. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    in the 90's here and no complaints
  13. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Hills kill mpg. You'll always expend more energy on the climb than you get back on the descent. I Live at 870ft above sea level and descend to sea level on a daily basis. I try not to make more than 1 or 2 trips in a day as climbing back up that same hill uses alot of fuel. Average week driving around Vancouver is 42mpg(indicated) in the summer. 90% city/urban driving, freeway max speed between 40-50mph.
    Took a trip down to Bellingham today, pretty flat most all the way, averaged 51mpg(indicated) there and back. Flat land makes a huge difference! I never went faster than 60mph on the I5 either and surprisingly didn't get run over. :)
  14. mikefocke
    4,038
    1,830
    Sanford, NC
    Yes, SUVs and mini-wagons take longer to cool down. More cubic feet, more glass.
    Happened the same with my CRV. Where my Porsche cooled immediately with so many fewer cubic feet to cool. Move to a mini-van and there is a reason for dual a/c units.
  15. rickrus
    rickrus Junior Member
    Conway, AR
    My own experience is that hilly territory for a Prius means better mpg!
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    This is almost thread necromancy, but oh well.
    Different driving style is needed for hills vs. flat terrain. Both can net good results or poor results. But once a hill becomes large, i.e. a mountain, your mileage will suffer.
    I have a 2000ft+ elevation change between house and city. I get 18mpg-ish going up the "hill" as we call it, but it is a mountain in the Rocky Mountains. Going down, infinite because the engine is off. But about 1/3rd of the way down the battery is completely full. Much much much more energy expelled to go up the hill than recaptured going down.
  17. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    My v cools SO much better than my former V6 RAV 4 that I don't have anything but raves for its performance.
  18. GregP507
    GregP507 Senior Member
    3,002
    481
    And more glass means more heat transfer.
