Prius 04 Not Starting After HV Battery Repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hydride, Jun 24, 2013.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I just want to clarify ... when you say the car "wont start" you mean it wont display "READY" on the dash? Or that the ICE wont start?
    My first thought was - I start the car all of the time and my engine never starts. Heck, sometimes it doesnt fire the ICE at all if its warm. But I always enter "READY" mode.
    hydride likes this.
  2. hydride
    hydride Junior Member
    24
    My engine never starts.
  3. Patrick Wong
    18,210
    6,515
    Does the READY light appear, or not?
  4. hydride
    24
    Lights and display turn on. I can listen to the radio, turn on the A/C, and everything except starting the engine.
  5. Patrick Wong
    18,210
    6,515
    If you do not see the READY status light appear, then the engine will not start.
  6. hydride
    24
    Well it does show the ready light briefly.
    password: gen2prius
  7. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Some people might think I need a good slap for harping on this; but I'm not convinced the safety plug is all the way home and making good contact. Take a look at this video try one more time
  8. hydride
    24
    I did exactly that--one more time. Maybe its the inverter? Just wanted to throw that out.:whistle:
  9. hydride
    24
    Well, I won't be going to dealer just yet. I'm going to order a whole new hybrid battery block from eBay and have the seller send one of his technician to install it on my car. We'll see what happens from there.
  10. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Good luck. Let us know how you make out.
  11. hydride
    24
    Well, I found the problem. Right now I'm letting some of the rusted brass plates and nuts sit over night in some chemical solution. I'll reassemble this bad boy tomorrow and post an update. ImageUploadedByTapatalk1373950209.212736.jpg
  12. hydride
    24
    My Prius runs now. If anyone's curious, I found an extra nut and screwed the metal plate in tight. The car threw out 2 more error codes but disappeared after I nudged the battery a bit. I saved $5000, spent $50 on a new battery cell, $24 on a multi-meter, and $50 on OBD II reader.
    SteveLee, uart and nh7o like this.
  13. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    That nut was missing all along?? You replaced a cell? Could you state your process used to replace the cell? How did it measure up in volts to the other cells? Glad you're back up and running.
  14. hydride
    24
    Yes that nut was missing all along.
    In the beginning the faulty cell was the first issue. I then used a voltage meter (multi-meter) to check each individual cell to see which one had the low voltage. Luckily there was only one faulty one which read around 6.4v instead of the default 8.2v.
    There's a three-part video on YouTube about the disassembly of the battery from the car. I wish I could redo what I did and and record it but it takes way too long.
    I hope that helps.
  15. Patrick Wong
    18,210
    6,515
    Your photo in post #31 shows a missing nut on the far left. Is that what you were referring to? If so, I can see why your battery would not operate.
    Also, what does it mean to "nudge the battery a bit"?
    What chemical solution did you use to clean the busbars?
  16. SteveLee
    645
    180
    North Carolina
    I
    According to the picture above it looks like a main connector on the battery.
  17. hydride
    24
    That is correct. There was no nut, therefore the terminal did not have have any contact whatsoever to the battery, thus no power and dead car.
  18. SteveLee
    645
    180
    North Carolina
    I
    Was the missing nut found? How long had this been a problem? You originally stated "...so I bought a new cell to replace the broken one. " Was this nut missing at that time or was it left off during that repair? Just trying to learn more about the cause of this incident.
  19. hydride
    24
    It's no problem. The nut went missing during the repair and for some reason, I didn't bother to replace it. Fast-forward 2 weeks later, I realized that nut was missing and grabbed a regular nut of that size and screwed it tightly in. Voila.
