I don't understand the solar ventilation
Discussion in 'Gen 3 Prius Main Forum' started by Pangaeus, Jul 4, 2013.
  1. Pangaeus
    Pangaeus New Member
    Unity, New Hampshire
    I'm a new owner...My car apparently has them and I have watched the video's on youtube, but am still not seeing any difference in car temperature. My understanding is that the solar power is supposed to keep the car ventilated, ie at ambient temperature when sitting in the sun. I havent noticed any difference whether I push the button in or not.
    Can someone who has them tell me how it is supposed to work/do?
    Thank you!
  2. Pangaeus
    Pangaeus New Member
    Also, are you supposed to hear anything? Like I said, I do not notice that anything happens when I press in the button.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Had a 2013 Prius 4 with solar rental for a day. Hopped back into it in sun at the park. Could defintely hear a fan blowing and it was surprisingly cool inside. Fan continued to blow while sitting inside, but it turned off when I powered the car on.
    You bought the car used?
  4. Pangaeus
    Pangaeus New Member
    Yes it is a 2010 IV from a dealer. Maybe I need to take in to the dealer to make sure it is working.
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Did they give you owner's manual with car purchase?
  6. Pangaeus
    Pangaeus New Member
    They are going to send me one, but I dont have it yet.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Pangaeus likes this.
  8. Pangaeus
    Pangaeus New Member
    Ooo thank you for that link. Will see if there is anything useful in there about it.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    roof looks like this?
  10. Pangaeus
    Pangaeus New Member
    Yes, and the button to the left of the steering wheel is there too- with the arrow going through the car with a little windmill looking thing
    WE0H likes this.
  11. Pangaeus
    Pangaeus New Member
  12. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    Yes make sure button pushed in not a big difference there's no led on clicking of the button, but when you get in car you will hear the fan running it does help I just forget to hit the A/C button! :LOL:
  13. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Keep in mind the fan does not start when you press in the button. Just make sure the button is in the "in" position. Then, when the car is sitting in the sun and you come back to it after about 10-20 min you should be able to feel the air coming out of the vents (ones on the dash closest to the door) and hear the fan if it's in a quiet location. The fan will stop as soon as you put the car in "ready". It will also stop if you activate the "pre-cooling" function.
    As far as lowering the interior temp to ambient, ain't going to happen! Even with all windows open that doesn't happen. It will lower the temp. How much depends on the colour of the car among other things. It helps if you place a sun shield in the windshield to cut down on the solar insolation.
    ralleia likes this.
  14. MPGnutcase
    579
    114
    Chicago
    yes the dash gets really hot and heavy tinted windows will help I've put some mesh window sun blockers on the rear window they have suction cups, really meant for side windows though
  15. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    Yes.
    The button must absolutely be depressed BEFORE you power the car off in order for the ventilation fan to run.
    Also, there must be sufficient solar radiation striking the panel to cause the fan to run, so make sure that you try the test on a sunny day. The fan is fairly quiet but still quite audible if you listen carefully.
    The fan helps by a few degrees, but keep in mind that cars are effectively greenhouses. I have a greenhouse for growing vegetables, and even when ventilated as much as I can make it, the greenhouse is quite a bit hotter than the ambient temperature.
    As David Beale suggested, it is a major help to also use a sun shield as a radiant barrier in the front windshield. I don't enjoy wrestling with my sun shield, but I like coming back to a cooler car!
  16. Pangaeus
    Pangaeus New Member
    Is that legal? I want to do that because my dog rides back there, but wasnt sure if you can do that.
  17. MPGnutcase
    579
    114
    Chicago
    Just Tint the windows it will help:cool:
  18. Skunkworks
    Skunkworks Member
    101
    You can tint the windows with 3m product that is not really tint, its clear but it's reducing heat and glare if you are worried about tickets. 35 percent tint is nice and not too dark.
  19. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Well, I could not have the solar roof on my Five with ATP but I am somewhat glad after reading this. Testing to see if it works is like testing if the light turns off in your fridge after you close it. You just never know. :p
    WE0H likes this.
  20. michinnom
    michinnom Member
    162
    29
    When its hot, it's hot. It's a gimmick. Very minimal actual temperature difference, especially in hot climates.
