No low fuel light in Prius
Discussion in 'Gen 3 Prius Main Forum' started by Darhl Ehrgott, Jul 7, 2013.
  1. Darhl Ehrgott
    Darhl Ehrgott Tinyhomes
    Naples, FL
    I have not taken the time to read my owner's manual yet. I recently discovered that there is no low fuel light on the Prius - just the flashing, bottom bar on the gas gauge. I ran out of gas in my Prius the other day and had no battery left to get out of the intersection. It was a tough lesson learned.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    If you refill at 2 pips, you will NEVER run out of gas again!!!
    It's always worked for me!
    Zythryn, WE0H and Felt like this.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Here is how the Prius warns you that gas level is low.
    1. there is a gas gauge
    2. last pip blinks
    3. the estimated distance to empty (DTE) counts down to zero
    4. finally, there is an audible warning when fuel is low
    The gas gauge is all I need to tell me when fuel is low.
    ralleia likes this.
  4. Darhl Ehrgott
    Naples, FL
    Thanks for the info. My theory is that the less weight you have in the car (gas included), the better mileage you can expect - all else being equal. This is the first car I've owned that has no low fuel light. The DTE (Distance To Empty) is not accurate. I was simply pushing the limit and got caught "with my pants down". Never again.
    jgilliam1955 likes this.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Sounds like you kept going on battery only for a while. That can also be a very expensive lesson of something to avoid. If this happens again STOP THE CAR when the battery level is at 2 bars.
    I don't mean to put salt in your wounds, but the flashing pip = low fuel
    GrGramps, ralleia and WE0H like this.
  6. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Some of us got along for decades without a low fuel light. I'm not sure which car I owned had that first low fuel light.
    Not the 33 Plymouth, or the 37 Dodge pickup, or the 49 Ford, probably not the 53 Chevy, maybe it was the 63 Dodge Dart or the 78 Plymouth, or the 76 Honda. I suspect the 86 Golf had one or maybe it was the 92 Saturn. The first time I ran out of gas was with a brand new 94 Toyota Pickup, I mean really brand new, the dealer didn't fill the tank. I couldn't even make it to the gas station on the way to work the next morning.
  7. Darhl Ehrgott
    Naples, FL
    I fin
    I find the bar gauge to be inaccurate compared to other fuel gauges I've had in my cars. I would like to know how much gas in in the tank before it's empty. I fly the 777 for AA and rely on accurate fuel remaining. I will try to fill up immediately after the flashing occurs. Then, subtract this fuel amount from the manufacturer's stated tank capacity. This, multiplied by the average mileage, would be the more accurate DTE. I wonder how many bars you need to drive with electric only? I was showing two bars on the battery, was on flat ground, and it would not budge.
  8. SageBrush
    11,627
    2,531
    Southwest Colorado
    Refueling stations are hard to come by in the sky. Lucky for us ground dwellers there is usually no good reason to push the fuel tank to empty.
    OCD types who just have to know how much fuel remains and can do a little mental arithmetic only need know that the tank holds 11.9 Gallons (US) when full, and the MPG meter is about 5% optimistic. Reset your trip gauge when you fill up. That is what I do ;)
    Well, actually I presume the tank holds 11 gallons and the MPG meter is accurate. That combo underestimates distance per tank by 2.7%, a safety factor I am fine with since it covers about 97% of tanks based on a SD of 1.22%.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    So what kind of MPG have you mustered?
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    While inaccurate, that gauge is mighty precise, and have a lot of safety built in.
    Wow I thought a commercial pilot would be taught to err much on the safe side than to rely on the accuracy of a gauge. What do I know, I am just an engineer.:oops:
    WE0H likes this.
  11. SageBrush
    11,627
    2,531
    Southwest Colorado
    I kept track of some 25 consecutive tanks in my Lexus CTh -- a Prius twin:
    Average error is 5.02%, SD is 1.22%
    Jonny Zero likes this.
  12. Darhl Ehrgott
    Naples, FL
    I was reading something in Prius chat about the question whether or not there was a low fuel light. I was under the impression that if it didn't come on, I could drive with battery to a station. I was only about a mile from getting it refueled. I was thinking the recent 777 crash in San Francisco was due to fuel starvation, but the preliminary reports look as though the pilots simply stalled the jet on short final. The British Airways 777 that crashed in London in 2008 was due to the fuel actually freezing. The fix for that was a heater in the fuel filter. I'm shocked that pilots could actually stall a perfectly good plane, but that's what it looks like so far.
  13. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Conditions were ideal in SF. I just read the pilots requested a go-around, before the crash. Maybe they screwed up and went below the stall speed? Would the aircraft even allow you to get it close to stall speed at any altitude? BTW is landing equipment assisted on a 777 or manual?
  14. bisco
    49,524
    when you're down to two pips, you have around 4 gallons left. 30 lbs? you'll never notice the mpg difference.tenths of a gallon i bet. fill it up and refill at two pips. all the best!(y)
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    As a side note, a while back I was reading the investigations on the KAL Flight 007 that was shot down by the Russians. The author made a comment that in the Korean culture, it would be rude for the First Officer to speak up and challenge the error of the Captain. They speculate that was why both seasoned pilots manage to let it go off course. I wonder if this was the case yesterday in SF???
  16. SageBrush
    11,627
    2,531
    Southwest Colorado
    Less :)
    The rule of thumb from my hybrid engineering handbook states that if weight drops X percent, fuel economy increases by X/2.
    If 30# is called 1% and the tank 10 gallons, then 30 pounds less weight saves .05 gallons -- or about a 2 miles gain.
  17. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Here's my handy-dandy PIP chart:
  18. bisco
    49,524
    you can make that up with a little p&g and lighter clothing.:p
  19. Darhl Ehrgott
    Naples, FL
    Thanks. It really wasn't about the fuel savings for the lower weight as much as the question of how much fuel is really remaining once it starts flashing. The DTE isn't very accurate. I didn't recall how many miles it was from DTE zero to "flame out", but it was at least 30 miles.
  20. bisco
    49,524
    don't feel bad, i ran my 08 out after hearing the beep a few days before. told myself to get gas and then proceeded to forget all about it. never noticed the flashing pip after that. had to wak two miles home in flipflops in the pouring rain, got home at 10 pm, left the car on the side of the road and called the police to tell them i would call aaa in the morning.:oops:
