PiP: All the software versions...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Totmacher, Dec 17, 2012.
  1. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    EnTunes (AT): 1.1.156289
    EnTunes (Base): 2.1.1
    . - (found by clicking the toyota logo in upper left in entunes)
    Navigation (AT): V6673220
    . - (found clicking update under general tab in setup)
    Bluetooth (AT): 21.210
    Grace Note (AT): 05052 (2012-06-1)
    Map (AT): 21-12-27 (2012-06-1)
    . - (found by clicking maps in info tab)
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    usb only for base PIP:D
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Just got the following e-mail from Toyota. I assume that one has to be connected to the car with the Entune app to get this:
    Dear Toyota Owner,
    Thank you for your recent purchase of a new Toyota. We hope you are enjoying all of the great features and functions in your new vehicle, especially Toyota's revolutionary new multimedia system– Entune®!
    We are very pleased to announce that your vehicle will soon be receiving an upgrade for your Entune system. This upgrade will enable voice recognition for Pandora®, iHeartRadio, OpenTable® and MovieTickets.com™ apps. This upgrade will be delivered to your vehicle "over the air", so all you will need to do is click "OK" on your navigation/audio screen when your vehicle prompts you to accept the Entune upgrade. This upgrade is being provided at no cost to you and should take less than 10 minutes to complete. (Your vehicle needs to be running, so please do this in a well-ventilated space).
    Please be on the lookout for this upgrade to arrive in your vehicle on or around June 28, 2012. Thank you again for your purchase, and we hope you enjoy the new capabilities of your upgraded Entune system.
    Sincerely,
    Toyota Motor Sales, U.S.A, Inc.
    Read more: http://priuschat.com/threads/entune-update.111452/#ixzz2FMNceKAC
  4. Totmacher
    301
    110
    Mission Viejo, CA
    yeah that should be the 2.1.0 upgrade and then following that is the 2.1.1 OTA update. But I don't think those update versions jive with the AT headunit.
  5. lensovet
    2,615
    496
    Burlington, NJ
    FYI, 2.1.1 just updates the sports app. Also people were getting it as early as August, but it showed up for me only two weeks ago, and I've had the car since October.
  6. lensovet
    2,615
    496
    Burlington, NJ
    Not true
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Ok, to clarify, I was under the impression that the Entune update for the AT was OTA and via USB for the base, sorry for the confusion
    LG-MS910 ? 2
  8. Totmacher
    301
    110
    Mission Viejo, CA
    I called the customer care and they told me that my PiP AT does not get the update just as I suspected.
  9. Totmacher
    301
    110
    Mission Viejo, CA
    I believe this is the case, I was just more curious about the discrepency in the software versions. It makes sense 2 different platforms would be on 2 different software versions, I had just read in another thread someone made a comment that the update put both styles on the same version. My guess is that comment was not accurate.
  10. CharlesH
    2,796
    1,163
    Roseville, CA
    On the Advanced, the Sports App (and the Stock Price App, as well as several others I can't think of right now) is one of the Sirius/XM applications, whereas on the Base, it goes through the Internet connection on your phone to get the data. So while the results may look the same, it's an entirely different application internally.
  11. lensovet
    2,615
    496
    Burlington, NJ
    Right, and this is wrong. The 2.1.0 update had to be done over USB, but all future updates will be OTA.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    thanks! Do you have all the updates and what medium is used to upload the updates that pertain to Entunes in your FAQ?
  13. lensovet
    2,615
    496
    Burlington, NJ
    i'm going to link to this thread in the FAQ.
    OP, however, can you please explain this part:
    Which screen is this on? Is it in the car or the phone app? In the base, the way to get to it is Setup→General→Down arrow→System information, and 2.1.0 is the latest (though there is an APP update to the Sports app which makes it 2.1.1)
  14. TonyQ
    TonyQ Junior Member
    2013 Prius Plug-in
    I have a new 2013 AT, and there are later versions of all of the software other than Entunes on it. Here's what came with it:
    I'm not sure how you'd get these newer versions though if you didn't have them already.
  15. Jumpjet
    Jumpjet Member
    77
    25
    Unfortunalely I feel abandoned when it comes to the software updates. Toyota claimed that there will be more apps coming soon when I purchased the PiP AT last year. Almost a year later and I have not received any updates, additional apps, or information on any upcoming apps. Does anyone know if there will be any additional apps coming out? Any improvements to the current apps such as the weather? I find it to be useless if I have to figure out where I am before it shows me the weather.
  16. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Tech is not a priority with these people. People buy a car, and it's apparently assumed (by Toyota) that you will not need/get another update until you buy a new vehicle. However, it's not just Toyota that makes this erroneous assumption. It's practically all of the car makers. You'd be better off getting an iPad mini and using that for most of your functionality - that is if you ever want to be up-to-date once you drive your car off the lot.
    Even the service department won't give a rat's-azz if anything goes wrong with your tech. The consumer is on their own with the tech problems. For example, after a year, I still have not been able to upload a picture as a screen. I'm not technically obtuse, either. Do you think the service advisor knows how to do this? No. They plug the car in, see that everything is "working" and shrug their shoulders. This is an extreme example, but it points to the much bigger problem.
    SAronian likes this.
  17. Jumpjet
    Jumpjet Member
    77
    25
    Sad but true. I think I'll just get a base model next time and add my own tech. I guess updates usually means bug fixes and not enhancements to a majority of auto makers.
  18. Totmacher
    301
    110
    Mission Viejo, CA
    updated, I'm going to hassle them to update it at my next service as it's my 25k one and there last chance to rope in my business.
    bfd likes this.
  19. bfd
    659
    172
    This is not a bad idea. I think my next is 20k, but I'll get it on the worksheet so it's in print that the "Customer Requests…" Then at 25k I can put the pressure on about continuing business. They probably won't care. Years ago, they replaced the steering in my Solara ($1500 out of warranty). I think that was my one-time 'goodwill' repair for the rest of my life. LOL
  20. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    what Button do you press to get to the screen on the display that has the Toyota logo to press to get the Entune version? Tks
