One-Touch "3-flash" turn signal for lane changes?
Discussion in 'Gen 3 Prius Audio and Electronics' started by came_to_party, Jul 8, 2013.
  1. came_to_party
    came_to_party Junior Member
    48
    This seems to be a fairly common feature on a lot of newer cars and I was wondering how we can get it on ours. I know the 2013 Camry has it which is encouraging because I’m hoping it’s a simple case of swapping out the relay. I saw this online (AutoWindow Tap Turn flasher) but it’s $80 and I’m sure there’s a cheaper alternative out there. Anyone have any experience with this retrofit?
  2. peterjmc
    917
    189
    Clarksburg, MD
    That's what I have. works perfectly
  3. came_to_party
    48
    How hard was it to install?
  4. xliderider
    xliderider Senior Member
    8,122
    3,265
    Honolulu, HI
    Looks like you replace your flasher module with the one you purchase. However, the OEM flasher relay is located way up behind the dash and isn't easy to get to, unless you're Lillipution sized lol.
    SCH-I535
    striker308 likes this.
  5. came_to_party
    48
    Damn, I pissed off all my Lillipution friends last week when one of them overheard me telling a short people joke.
  6. peterjmc
    917
    189
    Clarksburg, MD
    Pretty hard because its far up in the dash. I had to train a hamster to do the work for me.
    Not sure what's easier... Jamming your hand up there and struggling or just taking the dashboard off.
    Fingered from my phone using Taptalk version 9 Beta
  7. came_to_party
    48
  8. Tideland Prius
    16,491
    Toyota is finally adding it to their new products so the new Avalon and RAV4 have it (I'm surprised to learn that the 2013 Camry has it. Thanks for that info!).
    I'm guessing the Prius will incorporate that in the next redesign.
  9. came_to_party
    48
    What I'm really curious about is if the "3-flash" feature is controlled by the relay in the Camry or Rav-4 and if it will fit in the prius. A stock relay on ebay will go for $10-$15 as opposed to the $50 one I found.
  10. Tideland Prius
    16,491
    Good point. I'm not sure. If so, that'll be an easy add on.
  11. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    The 2013 Prius plug-in I test drove recently had the momentary turn signals so it might just be a matter of ordering the new relay?
    I had it on my previous SUV and it was a surprisingly useful feature.
  12. came_to_party
    48
    Well that's really interesting, time to do some research! Thanks for the info.
    Edit: I've been searching everywhere and the part number for PPi flasher relay is the same as it is for the regular Prius. Either the one you drove had the aftermarket relay installed or the "three flash" action is built into the electrical system somewhere.
  13. Onex Prius
    Onex Prius Junior Member
    Puget Sound WA
    You'll need the aftermarket flasher relay. The new 2013 Camry or RAV4 use a circuit built in the odometer to control the turn signals.
  14. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    Has anyone tried the WebElectric one touch module?
  15. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    good thread. i always wanted this feature.
  16. Onex Prius
    Puget Sound WA
    Got my webelectric one touch relay yesterday, installed it on my Sienna pretty easy (located just behind the fuse box when removed the knee air bag cover). Tried to located it on my Prius but seem pretty hard to get to like someone point it behind the top dash. Will figure out before order another one for Prius.
    Work like advertised. However there is one glitch: the first turn signal on pause for a second before it start flashing, just like some cheap regular LED relay on vleds. Email the vendor and still waiting for reply.
  17. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    Hi Vito,
    . I have used 2 WebElectrics relays with no problems. The last one I put in, I left the original relay in place and hung this one separately. Neat things about WebElectric relays: LED ready and programmable! I set mine for 4 flashes. Seems to work better then 3 flashes for me. This is the first mod I did to my new Prius, and then the horns!
    -Zed
  18. RaZa
    RaZa Member
    480
    93
    how hard was it to do the install in a prius? I'd like to get one myself, but not if I have to tear apart the car to get to the relay
  19. Onex Prius
    Puget Sound WA
    Really hard! I tried few times with hazard flashing to locate the relay by the clicking sound but unsuccess. At least a good portion of the dash bottom need to remove to gain access.
  20. Onex Prius
    Puget Sound WA
    Is it pausing for a second when first turn on?
