another victim of the "too tight oil filter cap"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Maroon, Mar 18, 2013.
  1. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    What is Aluminum? The filter housing is composite material (non metallic).
    Posted from my iPhone via the Tapatalk app.
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,723
    1,762
    Bay Area
    woops, guess I was thinking of the oil filter cap wrench and not the housing.
  4. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    OK so I always would change my oil myself and have had many many cars I think at last count 36, I love cars!
    But now my dealer offers $99 charge and you get oil changes for life,
    The Fox Lake Toyota Difference
    Fox Lake Toyota is pleased to introduce
    “The Fox Lake Toyota Difference”, a comprehensive plan which offers the following benefits:
    • No charge oil changes for up to 200,000 miles
    • A comprehensive 200,000 mile engine guarantee
    • Complimentary service loaners
    • Free car washes with every service
    • Customer Appreciation Saturdays – free car washes and refreshments
    The “Fox Lake Toyota Difference” plan is eligible for all new Toyota and Scion models as well as Certified pre-owned Toyota and Scion models.
    This complete Peace of Mind Protection Plan is offered at the time of sale for only $99!
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    A lot of those offers do not cover synthetic oil, but even if it was $300, that's a steal. However, you can count on a hard upsell during every visit.
    iPhone ?
  6. Mike500
    Mike500 Senior Member
    2,593
    767
  7. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    dustoff003 likes this.
  8. The Critic
    3,193
    2,333
    CA
    I received my Bluepoint cap today. My oil change is coming up in about 1k so I will report back once I use it.
    iPhone ?
    PJB likes this.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    That's a nice cap filter tool. Interesting how the dimension is 64.5mm
    SCH-I535
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    That's te same one I have. I loaned it out once and my friend broke on of the little pieces off, but it still works just fine.
  11. The Critic
    3,193
    2,333
    CA
    If yours was also purchased from Snap-On, they should replace it for you under the lifetime warranty.
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    Nope, not from Snap-On. The company that makes them sells them to whoever wants them and puts their stamp on them. When my friend broke mine, he gave it back to me along with the Assenmacher tool, because he felt bad about it.
  13. Mike500
    2,593
    767
  14. NutzAboutBolts
    1,723
    1,762
    Bay Area
    wow 55$? that's one expensive oil filter wrench, and any life time warranty on that?
    I bought mine from Snap-on and hasn't broken on me yet, but I don't know how anyone can break this filter wrench.
  15. The Critic
    3,193
    2,333
    CA
    Weird. Did yours have the powder coated finish?
    iPhone ?
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
    Mine's exactly the same as the one in your pics, except it has JTC auto tools 4904 stamped on top. Here's another one with BGS tools stamped on it.
  17. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    So how are you guys getting the car in the air to access the engine from the back? Jackstands on the side jacking points? Lifting from the front centre jacking point with jackstands on the sides? Could I do it with ramps from the front? Looks like I would get about the same clearance as the video showed. It's tight under there for a big guy like me!
    Just ordered the Assenmacher tool after reading this thread. I'm 130 km from change time, and was going to do it today with the tools I have, but decided to research on here first. sigh. So when it arrives in a week to a week and a half I'll be changing the oil for the first time. It's been 14 months since I took the car home from the dealership. I guess it's a bit long time wise but I haven't been driving it that much. My FJ Cruiser plows through the snow in winter, keeping the miles off the Prius. Now at 78xx km.
  18. NutzAboutBolts
    1,723
    1,762
    Bay Area
    If you use the ramps, it'll give you more room than jack stands depending on your jack as well, but using the ramp is much easier since all you do is drive up onto it.
    As for jacking up the vehicle, the front has a jacking point underneath where you jack it up and then you want to put your jackstands on each of the pinch weld on the side.
  19. El Dobro
    El Dobro A Member
    7,088
    3,270
    I use ramps and while under there, I also remove the entire bottom cover so I can look around.
  20. patsparks
    10,664
    567
    Adelaide South Australia
    The cap has an O ring seal, finger tight is fine. Making it tighter wont prevent leaks. The seal seals around the housing, it doesn't even have to be screwed right home to seal, the housing and seal just have to engage. Finger tight should be written on the housing. The tool is only used to remove the cap because over time the O ring will stick a little. No tools to tighten, that is why the cover has finger grips.
