Spark plug replacement - tools needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tomiha, Jul 7, 2008.
  1. Pink5owen
    Pink5owen New Member
    Thanks. :)
  2. Pink5owen
    Your right, it says, "trivalent metal plating provides superior anti corrosion & anti seizing properties". In short, I don't need to put anti seize on it. Thank you 2009Prius. :)
  3. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Told ya.
    DROID RAZR ? 4 Beta
    Pink5owen likes this.
  4. Pink5owen
    I just did it this morning. These are my spark plugs after 136,000 miles. image.jpg image.jpg
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Wow, it's amazing how little wear the electrodes on those iridium plugs show after all those miles. I've got my new plugs here ready to go in next time I give it a service, just gotta wait for a nice warm day to do it.
    BTW. I'm impressed that you got them changed out without breaking a nail. :cool:
    2004priusgal and Pink5owen like this.
  6. Highmiles
    Highmiles New Member
    Thanks to all who posted pics and advise. Waited a little longer than most. Just changed mine on the '08, at 222,800 miles. Plugs looked pretty worn. Test run was a success, now for another 70,000 then I'll do it again.
    boppo likes this.
  7. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    I'd love to see a picture of those "pretty worn" plugs.
  8. xyzzy42
    xyzzy42 Junior Member
    PNW
    Just changed one of mine, '05 with 68k on it. I removed the wiper cowling and pan, changed the PCV valve, cleaned the wiper drain pan (good thing, as the two drains in the bottom were totally plugged), and inspected the plugs and ignitors. The '05 has the defect TSB where the wiper cowling leaks onto the engine. The rightmost plug was all rusty so I replaced it. The other ones seemed fine.
    The bad plug once removed:
    I suggest that if you see the plugs are rusty, try to get the debris out before removing the plug. I vacuumed before removing the plug, but a lot more rust was broken free when I removed the plug and fell into the cylinder. I think it would be better to loosen the plug a few turns, vacuum around it, and then remove it the rest of the way.
    I think I got most of the debris out of the cylinder by taping a small rare-earth magnet to the end of a long 1/4" socket extension that would fit down through the hole into the cylinder.
    If your spark plug socket has a rubber ring to hold the plug in place, make sure it's still in the socket when you're done and not still on the plug.
  9. northcoaster
    northcoaster Junior Member
    32
    northcoast
    I'd never advise putting something into a cylinder to get out some rust or debris unless absolutely necessary but instead would suggest getting some clear tubing that fit into the spark plug hole with room to move it around and tape that to a vacuum, the difference in aperture size from the vacuum to the tubing (it would need be tough enough not to collapse from the vacuum suction, got some in my garage) the difference to create quite a suction and should be able to suck out the smaller pieces and be able to lift out any large ones. What if that magnetic came off and stuck to the cylinder wall or piston? Head job?
  10. xyzzy42
    PNW
    I tested it first by sticking it some pieces of iron and seeing if the magnet will rip through the tape. It was clear that it wasn't going to come off. I'm not sure if the vacuum would work all that well. The locations of oil spots on the garage floor are easy to see after I vacuum up sawdust, as the sawdust doesn't get picked up at all where the spot is.
  11. mfa-prius
    299
    46
    Hansville, WA
    Northcoaster, how'd you take those pictures of the spark plug wells?
  12. PriusFruit
    PriusFruit Member
    97
    102
    San Francisco
    Thanks for sharing! This post along with others on the same topic helped a lot!
  13. Mendel Leisk
    41,820
    I appreciate this is 3~4 year old posting, but just a tip:
    I had debris in a spark plug well, and what I did was hacksaw just the thread portion off an old plug, and jam/glue a wooden dowel on the end. Then reach that down, screw it in a few turns, then you can freely blow air in there without fear of getting debris into the cylinders. Much narrower than a whole spark plug, it allows you to get the air in and debris out without restriction.
  14. Patrick Wong
    18,210
    6,511
    Or, use a vacuum to suck out any dirt?
  15. Senchronize
    Senchronize Junior Member
    30
    arizona
    Doing mine soon, you guys think replacing one plug a time will work with the wiring scheme? Or take all out first and replace them all together?
  16. AndyZaa
    AndyZaa Junior Member
    35
    17
    New Brunswick, NJ
    +1 on the swivel magnetic socket - I purchased the GearWrench equivalent (same price) and it made the job MUCH easier. Thanks for the tip!
