Just got my Clazzios today. Need a little help.
Discussion in 'Prius c Accessories and Modifications' started by priusea, Jul 29, 2013.
  1. priusea
    priusea New Member
    22
    As I type this, my fingers ache with each stroke of the keyboard. MAN, you guys weren't lying about sore fingers and bleeding cuticles. Wow. Just wow... Maybe I'm just weak, but the tips of my fingers have never hurt like this!
    At any rate, I got both front seats installed with no problem. The rear seat, however, is a whole different animal... I must be missing something. Why are there so many holes in the rear bench set? Where do these holes go, and what's the purpose? It looks a little weird, because the holes expose the seat. I thought I had the wrong rear piece at first. Can anyone help?
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Access holes for the LATCH child seat attachment points?
  3. priusea
    priusea New Member
    22
    AH.... okay... but how in the world do you hide them?
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    You need someone with Clazzios (not me) to answer that one!
  5. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    hmmm, i'll be installing mine tomorrow. will report in...
  6. priusea
    priusea New Member
    22
    I wish you the best. I'm at my wits end. Considering just returning them. hate to do it, because the fronts look great.
    Also, on the rear bench, the little plugs that they tell you to remove. I can't get them back in. It's almost as if they're a "one use only" deal. Might have to go to the dealer tomorrow to grab some new ones.
  7. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The ones that hold the plastic panels below the rear seat in place? You push the center rod in to remove the clip, then to put them back you push the rod as far as it will go in the other direction (out through the face of the clip), put the clip back in the panel, then push the rod in flush to secure it.
  8. priusea
    priusea New Member
    22
    Perhaps I'm just really dumb, but I tried that and it simply will not work.
  9. priusea
    priusea New Member
    22
    ImageUploadedByTapatalk1375142869.528227.jpg ImageUploadedByTapatalk1375142896.224161.jpg
    Couple of pix for reference. Can i get these at the dealer? I broke one trying to get it in.
  10. B2FiNiTY
    979
    227
    yeah, those things are the devil!
    sometimes when I go crazy after trying and trying, I end up removing the pin and pressing the bottom part in and then inserting the pin separately.
  11. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    you can try your local autozone/pepboys. they usually have those fasteners.
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    In your second picture you need to pull the center pin further out, so as to leave room for the four tabs to go back in the hole. Then push the pin back in to secure the fastener.
  13. B2FiNiTY
    979
    227
    Where do u attach the two loops on the back of the front seats?
  14. estebinbin
    estebinbin Member
    184
    47
    there are hooks that come in the instruction bag, when in place just hook them to the many points under the seat. anywhere really.. i lost one set of hooks and just looped the elastic on a metal wire under the seat, did the trick..
  15. B2FiNiTY
    979
    227
    I didn't get any...zip ties time!
  16. B2FiNiTY
    979
    227
    Pretty good fit and finish. I would have preferred the oem softer but at least these could be custom.
    Black PVC with grey stitching
  17. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    *le sigh*... I really hate this website... *walks away to order new toys*
  18. davekro
    davekro Active Member
    529
    83
    SF Bay Area, East Bay
    2013 Prius Plug-in
    B2 (or others with PVC),
    How is the comfort of the material with regard to:
    1) getting in after parked in hot sun
    2) I don't guess PVC breathes, so to speak, is there any persperation discomfort between seat and your back/legs?
    Am I correct to assume that the perforated leather inserts would be a non issue about #2. Actually, Both our 'other cars have leather (non perforated) and they are not an issue, very comfortable. Would the PVC act/feel (don't mean to the touch here, but that is a good question too) just like non perforated leather I wonder?
  19. B2FiNiTY
    979
    227
    They are very comfortable. Sweating is not an issue at all. But sweating is usually not an issue with me.
    They do get warm after being in the hot sun but not scorching hot. Might even stay cooler than real leather seats.
  20. davekro
    529
    83
    2013 Prius Plug-in
    B2,
    Thanks for the info.
