Check Hybrid System....message received
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by seat007, Oct 30, 2012.
  1. theshark
    theshark Member
    164
    Martinsburg, WV
    52,417
    ?????o_O
    lensovet likes this.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
  4. bisco
    52,417
  5. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Jumpjet,
    Any update on your issues?
    I just got the message today on my way to work. The message has since disappeared, but the car is acting funny (ABS and VSC lights on and it doesnt appear to be regen'ing at all, friction brakes only). I checked my coolant levels and they both seem to be OK. I tried pulling the code(s) with Torque, but it said there were no codes stored (strange).
  6. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Trackside do you have a Torgue transmitter in you car I've had two that have given my the same trouble lights, turn off the car pull the transmitter and your fine!
    Tracksyde and Chazz8 like this.
  7. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Lourun,
    Yes! I havent been able to update this thread.. but after posting on Tuesday, on my way home, I disconnected my ODB2 adapter and the lights all went away. Coming back to work today, there were no issue either.
    So at this point, I'd say it was the OBD2 adapter. The only thing that bothers me is that my OBD2 adapter has been plugged into the car for the past year or so without any issue.
    Something I was also thinking was that because I havent used Torque in a long time, when I set up the data logging last week, Torque updated to the latest version. So I dont know if that has something to do with it. Although with all the PiP owners here who use Torque, I would've expected to hear something if that was the case.
    Either way, the adapter is unplugged now. I may try it again at some later date, but at this point, I'm just happy the messages and lights went away.
    Since you unplugged yours, have you tried plugging it back in and using Torque again?
  8. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Tracksyde
    Yes not only have I tried plugging it in many times, I bought a different one from a different manufactor, on Amazon, and it did the same thing. So right now I am running without it plugged in.
    Tracksyde likes this.
  9. davekro
    davekro Active Member
    529
    83
    SF Bay Area, East Bay
    2013 Prius Plug-in
    How do you tell the date (or month) of actual manufacture?
  10. bisco
    52,417
    i think there's a plate on the drivers door pillar.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Correct! cookie cumbler!:D
  12. bisco
    52,417
    like a broken clock.:cool:
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y) :eek:
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Hmm.. strange.. I wonder if an update to Torque messed with OBD2 adapter or something. There are settings in Torque that "do something" to the adapter (like one setting was making Torque turn off the adapter, if supported)..
    My adapter was one of the cheapie ones for like $20 or something. I know usbseawolf2000 uses a more expensive one.. maybe that will be the one we need to get.
    Its just so odd that my adapter has been plugged in for so long without issue.. but pretty much the day after I started logging after not using it for 6-8 months, it starts acting up.
  15. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    My two were cheapies from Amazon, and yes maybe "you get what you pay for".
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Yup, driver door pillar where the tire psi are printed.
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    How often does it happen to you?
    I can't recall the last time it happened to me with PiP but I think it happened once.
  18. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Haven't been able to use either one for more that about 15 minutes.
  19. davekro
    529
    83
    2013 Prius Plug-in
    Consistency is a good thing, right? :D
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Do you have "Faster Communication" setting turned on?
    If those adapters cannot handle it, disabling it may help? Just a thought.
