New to Prius: Can't achieve above 45 MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by Jaybird124, Aug 3, 2013.
  1. g4_power
    g4_power Junior Member
    105
    I
    When I'm cruising, I tried to keep my HSI looking like this. When I'm accelerating, the bar moves a little more to the right but I try to keep it out of the "power" region.
    Jaybird124 likes this.
  2. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Sounds like you're getting some good advise, but I understand your concern. My recent new Prius experience was completely the opposite. Around my third tank I traveled 350 freeway miles at 75mph and averaged 51.3mpg. A few weeks later the same trip, same speed, but A/C on the whole trip and got 47.4, my lowest mpg to date. I was beginning to think excellent mileage was effortless.
  3. Jaybird124
    Jaybird124 Junior Member
    28
    Central Florida
    Bob,
    I'm going to assume you're coming from a place of constructive criticism. And if you've taking this post as trolling, I apologize. I made a point to talk about MY vehicle and not the Prius model as a vehicle.
    You're darn right I'm disappointed. Of the 7 cars I've had the past 10 years, I've been able to meet or exceed EPA estimates with little effort. And I categorically disagree about the EPA ratings. Since the '07 standards change, they've been easy to achieve. And while the Prius is a wonderful car, if I'm moving from a 55k BMW to a Prius, I expect it to do what the reputation bills it as.
    My 265hp 425 lb/ft 335d hauled 3800 lbs to 60 in just over 5 seconds. And would get 38 MPG all day long above 45. So yeah, I expect My Prius to get close to the 51 it promised with marginal effort, NOT 42-45 MPG with a lot of effort. In 600 miles I've never touched 46 let alone the 48 you posted.
    What's more, how many people on here are getting so much more than that? I don't think everyone is coasting behind a semi doing 20 to get over 50 MPG. I know that the majority of Prii owners are not practicing extreme hypermiling to achieve 50.
    There's no way the Prius would have the reputation is does if that were the case. Again, this discussion is about my car and the effort to resolve the situation.
    G4_power thanks for the tip. I've been trying to focus on that. It can be challenging with traffic, but point taken.
    SAronian, thanks for empathy. We'll see what shakes out.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    There's only one universal variable between Priui and the mileage they get. That's the driver. You need to learn how to drive it, and that doesn't mean "coasting behind a semi at 20". Its expected that the mileage a Prius gets could vary by 10MPG or more depending on the driver. No other car can say that. The tools one needs to figure out how to drive for max MPG are all right there in the on-board systems. If you're desperate to tweak something, tires is a place to start. OEM tires suck in every possible way.
  5. Jaybird124
    28
    Central Florida
    That's why I'm picking y'alls brain. Thanks for everyone's help.
    I'm new to hybrids so its's clear the driving style is very different. With gas and especially diesel engines, you ride the torque wave to bring you up to speed and just coast and feather the throttle. The ZF transmissions decouple during coasting (much like popping the clutch in a manual), which minimized driveline loss and allow them to coast very easily.
    Hopefully, we'll figure it out together and get to the 50's and 60's. Fingers crossed.
  6. Former Member 68813
    3,524
    983
    US
  7. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Jaybird, I think you know diesels are more efficient at highway speeds than hybrids. I was real close to buying the Passat TDI and likely would have if most of my driving was highway miles, but my driving is about 50/50 mix of city and highway. I had a 2010 Prius IV prior to my current v and I was getting between 50 and 54 regularly, and while the v is only returning 41-45 consistently, I'm happy with it because it's what I expected. Funny what a couple hundred lbs, slightly less aero, and different gearing will do to your mpg. You also stated your BMW got 38 mpg over 45 mph, but what was your overall mpg? It wasn't 38 was it?
  8. bwilson4web
    16,491
    Ignoring the thread does not turn off alerts to a reply to my earlier posting. Still, you've helped decipher the Consumer Reports puzzle. The August 2013 issue of Consumer Reports:
    source: pp. 50.
    More than a few of us have wondered how Consumer Reports gets such low urban mileage. They can not even reach EPA numbers and complain bitterly that the EPA does not justify their track nonsense:
    In contrast, every independent mileage database shows significantly better Prius MPG:
    If you want to achieve EPA mileage, you need to start by reading the EPA test protocol . . . and replicate it.
    Detailed Test Information
    But following the EPA driving protocol requires self-discipline and introspection:
    • accurate record of your driving profile - use a Garmin nuvi or GPS mouse to record your driving profile. This provides engineering metrics.
    • self-discipline to drive EPA style - bad-habits with former rides do not work.
    Your contribution is:
    This does not work with the Prius to achieve EPA mileage:
    1. Driving outside of the EPA test protocol returns different mileage.
    2. Driving the Prius like a legacy "gas and diesel engines" car achieves Consumer Reports mileage.
    Poor Prius MPG reports do not really matter:
    Mastering Prius driving takes a curious mind willing to experiment, to learn how the car actually works. Over 2/3ds of all Prius owners achieve better than 44 MPG and some can do significantly better.
    One last observation from the original GreenHybrid.com days. It turns out that Prius MPG performance is not so much a function of driving style as: routes and climate. One can mitigate some of the effects by driving style but it isn't worth it.
    Given your driving style, a plug-in Prius, Ford, or Volt might be a better match. Electric drive does a good job of dealing with lead-in-foot driving.
  9. Jaybird124
    28
    Central Florida
    Problem solved!
    So I figured I might as well check the tire pressure, even though I bought it from a great dealer. 8-10 psi under all the way around!
    Filled the tires up to factory spec, went for a spin and yielded 74 MPG. Whew. Just got done waxing it. Will post pictures soon.
    Bob - I'll make sure to look through that info.
    jhinsc - You're right, and I loved my diesel as a road king. It obviously depended on my driving but worst case I got 29-30 in town, without much effort and occasional hard pulls. On the Interstate it was 38 at 78-80 all day long. Obviously would have been in low 40's with LRR tires. Although that's nonsense on a BMW. Those Pilot Super Sports are the best tires I've ever had short of a cup tire.
    My wife is the road warrior though, so we bought the Prius to almost double her MPG's. While she's on the interstate, there's lots of stop and go during rush hour, tipping the scales to the Prius vs her 128i or my diesel.
    I'm going to be driving the 128i. I wasn't going to make her give up the car she worked hard to get after grad school.
    jhinsc likes this.
  10. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Add another 5-7 lb and you'll be good to go.
  11. Jaybird124
    28
    Central Florida
    While that certainly could improve fuel economy, what's been your experience on adverse affects (uneven tire wear, braking, turn in, etc)?
  12. g4_power
    105
    I
    Glad the problem is solved. Did you see my earlier message saying I set my at 40 psi? Check the max psi for the tires and then set it 10% lower.
  13. Jaybird124
    28
    Central Florida
    Yes I have them set at 37 and 40 psi respectively. Although, I'm somewhat concerned about contact patch. I want optimal braking, tire wear, and turn in. I'm willing to sacrifice a little efficiency to achieve that. Open to comments.
  14. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    1: The OEM tires are not worth saving so who cares if they wear out quicker?
    2: I've not been able to demonstrate any difference in the tire footprint with higher pressure. Low profile tires don't seem to be very sensitive in this regard. But at $4 per gallon, you just need to figure your savings with 3-4 more MPG over the life of the tire.
  15. SAronian
    334
    144
    Oakland, CA
    Excellent! Glad to hear you fond the missing link and nothing's wrong with the car.
    I've found my Prius Plug-in very sensitive to tire pressure, both for steering balance and fuel economy. While F35 R33 is recommended, the stock Bridgestone Ecopia EP20 feel best at F39 R33.
  16. hill
    8,999
    Bob knows what he's talking about ... you're lucky to get the mpg's that you get considering how fast you drive. The e p.a doesn't base their results driving 80 mph. Driving that fast is not hyper mileing
    I see you recently checked your tire pressures ... that's what I was just going to suggest. If you're happy now - just think how happy you'll be once your Prius is broken in. ... give it a few thousand miles.
  17. Jaybird124
    28
    Central Florida
    Can't wait!
  18. TWong1200
    TWong1200 Junior Member
    26
    Corona, CA
    I live in the hills and only avg 40mpg, sadly. Hills make such a huge difference.
    SCH-I605 ? 4
  19. CdotK
    CdotK Member
    376
    46
    Feather the gas.. i get 53mpg in a 2013/2 @70-75mph... just have to use momentum to your advantage
  20. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I came from a BMW(540 & 545) as well & while I loved the extra power, comfort & luxury I do not miss it at all as the prius more than makes up for it in the fuel savings. I'm glad u got your low mpg problem resolved as I was going to say give it some time as a BMW diesel & prius must have different techniques in hypermiling but it sounds like u indeed have some skills after hearing u getting 60 mpg w/ the proper inflation. For me inflating to 38-40 psi or slightly more gets better even tire wear than being 36 psi or under in which the tire seems to sag under the weight of the car somewhat. Oh btw, I just came back from a trip slightly over 1200 miles to Vegas-Zion National Park-Bryce Cyn. & back w/ a full load of family & luggage averaging 75-80 miles w/ AC on 85-90% of the time & I averaged 50.3 Indicated & 48.2 Calculated miles(actual) on the whole trip. & I was comfortable throughout most of the trip, other than fatigue of the long trip. There is no way any BMW could have done that;) . Drive on, you'll learn to love & appreciate the prius more as time & miles pile up:) .
