Suppressing Backup Beep
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by wmh37, Aug 2, 2013.
  1. wmh37
    wmh37 Junior Member
    Memphis, Down in Dixie
    2013 Prius v wagon
    Some years ago I was an active member of the Priuschat forum, but somehow drifted away. Well, I'm back, with a new one.
    I have just acquired a 2013 Prius v Three, having traded my 2006 Prius for it. There was a protocol one could follow to disable certain beeps, such as the seatbelt beeps, and not have to listen to that incessant noise. I would like to disable the seatbelt beeps, as well as that hyper-annoying backup signal. Can anyone tell me if there is a similar protocol for this Prius?
    wmh37
    jlhancock1342 likes this.
  2. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    There is for the Gen III Liftback, I've done it on mine. It uses a ScanGauge II and the XGauge functions. There's a Google document on the forums here, you can search for, with all the info. Good Luck!
    wmh37 likes this.
  3. bisco
    52,091
    welcome back, congrats on the new wheels!(y)
    wmh37 likes this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    wmh37 likes this.
  5. wmh37
    wmh37 Junior Member
    2013 Prius v wagon
    Thanks to all who answered. Jimbo, your admonition is well-taken. My salesman and I did talk about it during our negotiations, he saying that the sales staff could not do it, but that Service could. I'm well introduced at my dealership's service department, having my 2006 Prius, and my 2006 Highlander Hybrid serviced there,exclusively. I am at the dealer's service department right now, having the backup beep disabled. I don't think they are going to charge me for it, but we shall see.
    In addition, I have ordered a ScanGuageII through Amazon, and will attend to the seat belt dings myself. Couldn't talk my service manager into doing it. The suggestion made him look furtively about.
    There seems to be plenty of information and data available for the ScanGuage II, if one searches for it. I'll need it, because some of the talk was absolute jibberish to me.
    Jimbo, next time you're in Memphis, and have some time, let me know, and I'll meet you for lunch at Mr. B's. E-mail me off-line for contact info.
    Thanks again, everyone. I'm glad to be back, and loving the V.
    wmh37
  6. wmh37
    wmh37 Junior Member
    2013 Prius v wagon
    As a follow-up, it should be noted that the dealer did not charge me for disabling most of the backup beep. I say, "most", because it still sounds one beep, when reverse is selected. Seems like I've seen something about that in ScanGuage discussion. In any event, one beep does not annoyance create, so I can live with it. Besides, my 20-pound cat, Babe, is accustomed to resting under the Prius, and the single beep is enough to mover her on.
    Thanks again, y'all.
    wmh37
  7. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    That IS the Beep disabled. It is SUPPOSED to do 1 beep. What is being disabled is the continuous beep. They did it right. The seatbelt beep however can be completely disabled, you never hear that.
  8. wmh37
    wmh37 Junior Member
    2013 Prius v wagon
    Thanks for that, Flux. Can you tell me how to disable completely the seatbelt beep, or point me in the right direction?
    wmh37
  9. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    Sure. I can only tell you how to disable it, with a ScanGauge II, since that's what I used to disable mine. You'll need to add 2 X Gauge's. The values are as follows:
    Seat Belt Beep Disable
    TXD 07C03BA700
    RXF 047B15A70000
    RXD 2008
    MTH 000100010000
    Name SBS
    Seat Belt Beep Query
    TXD 07C021A7
    RXF 046115A70000
    RXD 2808
    MTH 000100010000
    Name SBQ
    40 Disabled 00 Enabled
    If you don't have a ScanGauge II, I strongly suggest picking one up. They are well worth it. Good Luck!
  10. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
  11. jurascience
    jurascience Junior Member
    Michigan
    Can you explain where and/or when you use the 40 or 00 to enable/disable the beep? I managed to shut if off, now I would like to be able to turn it back on but I don't know how.
  12. Mendel Leisk
    41,640
    I think these custom settings are volatile, ie: if you disconnect the battery for a few seconds, everything goes back to basics. Not 100% sure though.
  13. Offline
    Offline Active Member
    644
    237
    Lenexa, Kansas
    I've never lost customized settings on a vehicle made by Toyota when a battery was disconnected or replaced regardless of who customized the settings - dealer, independent repair shop or me. My understanding is that these settings are stored in nonvolatile ECU memory as are the tire pressure sensor ID codes.
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Gen2 has a number of settings that are volatile, such as the backup beep, seatbelt, and radio station buttons. Gen3 backup beep is nonvolatile (don't know about radio station selections).
