Eco mode and EV mode
Discussion in 'Prius c Main Forum' started by infoguy1981, Jul 30, 2013.
  1. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Your picture didn't work, but if the EV isn't on, your ICE is still running. Most likely, your car isn't fully warmed up yet, but you are getting over 100 mpgs at that current moment in time.
  2. infoguy1981
    infoguy1981 New Member
    Boynton Beach, Florida
  3. infoguy1981
    click the link below for picture
    Eco mode and EV mode | PriusChat
  4. infoguy1981
  5. infoguy1981
  6. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    It looks like your EV mode is on and you are running on just battery.
  7. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    The simple approach to understanding the "EV" indicator is to just keep in mind the fact that the engine will shut off and times and other times it will continue spinning but not consume any fuel.
    The system will seek out efficiency opportunities. Having a power-split-device makes that very convenient. In fact, you'll see that happening frequently... hence the EV switching often and at seemingly unpredictable times.
    minkus likes this.
  8. Perl1947
    Perl1947 Junior Member
    28
    Israel
    According your statement
    regenerative brakes does not produces electricity?!
  9. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    Xpcman was last here over four years ago. But, at any rate, that's not not what he said. When you regenerate by braking or coasting, that energy came from the gas engine. Braking converts energy supplied by the gas engine into electricity. The only source of energy for the Prius, except in the Prime or PiP, is gas. (Unless you pick it up and carry it up a hill so you can coast back down it.) His entire statement was spot on. Some of the potential energy in the gas gets converted to kinetic energy (motion) by the ICE. Braking or coasting converts some of that kinetic energy back into potential energy (electricity). In both conversions, a great deal of energy is lost to heat, which is why gliding w/o regenerating is less wasteful.
    jwl2000 likes this.
