Jack Points / Lift Points
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by B2FiNiTY, Apr 21, 2013.
  1. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    ill take one lol. why not support a us seller and maker and also a fellow prii driver
    Merkey likes this.
  2. col127
    col127 Member
    345
    Illinois
    What's the advantage of using these 'adapters' vs. jacking it up at the circular jack points on the car with the lift?
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    SAFETY! Especially when changing and rotating tires.
    Lifting one corner is much safer than lifting one end. This is important when working on brakes.
    Also, if you place jack stands in this area, you have full access to the center front area under the engine and the front suspension and axles. Toyota recommends the pinch weld area for "jack stands" or, as they call them "safety stands."
    I would NEVER get under the car when it is supported only by a jack on either the front or back centerline jacking point.
    ztanos likes this.
  4. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    Mike, please make these for sale. I'll buy one.
  5. Mike500
    2,593
    767
    Unfortunately, I cannot post anything for sale after August 30. If anyone wants these, I might be posting them for sale on eBay in the future.
  6. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    The head of my jack stands have a slight lip on the sides, making a "U". Anyway, this shouldn't be a back and forth on who's safer.
    The OP wanted to know which jack to purchase. Hopefully, there's enough info here to guide the OP to something safe. Here is the take home message:
    1) The pinch weld jack adapters, whether they are home made or commercially available, are highly recommended to safely lift the car without mangling the pinch welds.
    2) The use of jack stands are required (or at least highly recommended) before going under the car.
    ztanos likes this.
  7. Pando
    Pando New Member
    Don't be like this guy:
    steveoknievo and ztanos like this.
  8. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    at least he chalked up the rear tire!
    steveoknievo likes this.
  9. mahout
    mahout Active Member
    655
    116
    NC
    A point: when you lift one side of the car you should also support both front and back with jacks or stands. Chassius do not like to be supported only front or only rear as it imparts a bending momoment to the chassis that can actually bend the chassis. Chassisd are not all that rigid, especially in the sb class of vehicles. the support locations are the double circular cuts in te frame flages.
    And using a piece of wood cross the grain will be a good way to 'anchor' the jack or stand to the flange..
    Those double circular cuts in the frame rail flange clearly mark the location to lift at each corner. When you jack one side for more than 15 minutes you should support both front and rear of the car on that side so that the chassis does not 'bend or twist'. Yes, they will; its not a really outstandingly rigid chassis.
    And if you don't have that 'slot' lift point that anchors the jack by either side of the flange use a thick piece of wood ACROSS THE GRAIN TO ANCHOR THE FLANGE.
  10. at_leo_87
    at_leo_87 New Member
    Boston
    2015 Prius c
    Hello all,
    I've scoured the internet and have not been able to find an answer. I can not for the life of me find the rear jack point for the 2015 Prius C. I've looked at the manual but can't tell what that protrusion is. Is it the thing that I've circled in white?
    Any help would be greatly appreciated!
  11. XRinger
    XRinger Member
    201
    47
    Woburn, MA
    If you want to lift both sides of the rear-end at once, you could try using two jacks under the side lift-points. Make sure the front tires are well blocked and the car is on a flat surface.
    I'm not a car guy, so get some input from a car guy..
    I'm sitting here thinking, why would you need to pick up the whole rear end of your car?
  12. Mendel Leisk
    41,873
    Sure looks like it. Page 366 of the manual:
  13. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Yes that is the one I have been using on my 2014 C
  14. at_leo_87
    Boston
    2015 Prius c
    Thanks for the confirmation!
    Looking at it, it doesn't look super sturdy but I guess it works.
    Thank you!
    I don't see any other protrusion in that area so I figured that was it.
    If it came down to it, I was thinking of resorting to exactly that.
    I used to lift up my entire car for quick tire rotations and figured I'd try that with the Prius.
    #34 at_leo_87, Aug 11, 2019
  15. at_leo_87
    Boston
    2015 Prius c
    What's funny is I asked the service guy at my dealer and he said that wasn't it. *facepalm*
  16. Cp2019
    Cp2019 New Member
    Oregon
    2014 Prius c
    Do you think you or anyone else could post a picture of the front jack point? I really appreciate your pic and others verifying so. Trying to complete the 105k maintenance on my own with the tire rotations left.
  17. Mendel Leisk
    41,873
  18. Cp2019
    Cp2019 New Member
    Oregon
    2014 Prius c
    I have the manual and have seen the illustration; though I’d be much better for me to see a actual photo.
  19. Mendel Leisk
    41,873
    The components in the line drawing look quite unique. It's near the front, central, I would just take a look.
    Cp2019 likes this.
  20. Henryk
    Henryk Junior Member
    New Jersey
    I want to jack my car up to do the Transmission fluid change. However the issue I have with the rear jack point, is that it's off center.
    This cleary seems that it would be an issue, in trying to evenly raise the rear of the car.
    Has anyone here actually used it.
    Thanks
