OG Prius ?
Discussion in 'Gen 3 Prius Main Forum' started by Delta Flyer II, Aug 30, 2013.
  1. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Hello fellow Prii owners...
    My mom is a commuter, and her current car is drinking way too much gas, we were thinking about getting her a 2002 / 2003 Prius, something she can just use for a commuter or switch off and on, doesn't need to be anything spectacular....
    Has anyone heard or know of any problems or such? We've seen them anywhere from $3k - $5k some in really good condition...
    Any thoughts, comments, suggestions, look out for's would be greatly appreciated....
    PS Sorry if this is posted in the wrong area.
  2. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    You may find it easier to locate a good second generation (2004-2009) Prius.
    iPad ? HD
  3. bisco
    51,840
    stay away from gen I (prior to '04) unless you are a crackerjack mechanic.
  4. wheelsup
    wheelsup Junior Member
    97
    Raleigh, NC
    I just recently bought a '99 Volvo V70 for $250 locally. The negative battery cable was disconnected and it kept cutting out on the previous owner. I didn't need the car and flipped it but it gets 30 MPG highway. Honestly unless you are driving a lot around the city the Prius doesn't make sense from a cost standpoint IMO. The extra $5000-$8000 or so you'd spend for a decent one buys a lot of gas.
    If she is doing a lot of highway driving look for a small commuter car like the Pontiac Vibe (same as Toyota Matrix without the name markup) or something similar without the potential $3k charge for a new battery pack (a very real possibility on an older higher mileage Prius).
  5. Delta Flyer II
    547
    248
    69
    Thank you all for your feedback....
    She drives 150 miles per day... has a V6 and its not the best on fuel....
    We will see how things will work out in the upcoming month. A buddy of mine and I changed out spark plugs (sadly the rears you have to take off the exhaust manifold, damn British cars) MAS cleaned, and a bunch of other stuff cleaned... Seems to be running much better and we will see if the fuel economy goes up.
    But thank you all for your comments and suggestions
