Battery’s charge
Discussion in 'Newbie Forum' started by e.e. comings and goings, Aug 30, 2013.
  1. e.e. comings and goings
    e.e. comings and goings Junior Member
    I recently purchased my first Prius, a 2010 that had 98,114 miles on its odometer. I bought it from a dealer, but there was no Carfax for it, so I don’t know its history. Somebody did a lot of driving, or maybe it was a rental.
    Anyway, when I leave work and first get in the car, which has just been sitting there for 12+ hours — the icon indicates that the battery’s charge is up to six or seven bars. That’s good. But by the time I get home, only 12 or 13 miles later, the charge is down to two or three bars. Shouldn’t it be going up during the drive, rather than plummeting?
    I have to encounter a number of traffic lights, so there may be frequent braking, depending on how lucky my timing is, but that is supposed to recharge the battery, not drain it.
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Before we get crazy with scenarios, what is your current average mpg?
  3. haole man
    haole man Member
    107
    35
    Podunk, California
    It depends on conditions and what your car needs. If you do a lot of accelerating or climbing hills, battery energy is used for more power. If you live uphill from where you work, the battery will recharge going to work and discharge going home.
  4. e.e. comings and goings
    There is a fairly big hill on the way home, come to think of it. There are also some pretty good downhills, though. I kind of miss not being able to coast down them as I did with my dear old ’99 Corolla with the manual transmission, but I know that coasting in neutral with the Prius won’t recharge the battery, so that’s out.
    I’ve only filled the gas tank once so far; it worked out to about 53 miles per gallon. I think it says 55.1 m.p.g. or so now on Trip B, which I reset after about the first 100 miles or so of owning the car. It also says that the best is 57.1, but I don’t know to what that refers.
  5. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    With that mpg, the topo of the land, and assuming your ICE is cycling on and off, it's sounding normal. I think the other guys were spot on.
  6. haole man
    haole man Member
    107
    35
    Podunk, California
    That's normal behavior, then. We live in a mountainous area, about 1500 ft higher elevation than town. When going to town we get 80-99 mpg depending on the route we take, and 32-42 mpg coming home. Even the paltry 32 mpg is twice the average mileage we used to get in our truck.
  7. e.e. comings and goings
    Thanks for the reassurances, everybody. I suppose it’s natural to keep an eye on the battery. I was pretty worried the first time I set off and noticed only two bars on it. I thought I had a huge expense coming up right off the bat after buying the vehicle, but pretty soon the power was up to seven bars, and it’s been going up and down ever since.
    I could have bought a 2012 Mazda2 with only 7800 miles on it for the same price, but thought I would be happier with the 2010 Prius, despite the high miles on it. And so far, I really like it.
  8. bisco
    51,838
    welcome to priuschat! sounds perfectly normal. no worries and all the best!(y)
  9. Mendel Leisk
    41,302
    I'm confused: in the morning, when you set out for work, state of charge is high. By the time you get home at night, it's depleted. And then the next morning, the state of charge is high again?
    Something's missing: is someone else driving the car in the evening, with a more aggressive driving style?
    The main thing I find that drives down our state of charge is my driving style. I have to tone it down: if I go out of my way to lift-off-and-reapply the gas pedal, to get it into stealth mode, I can quickly run down the charge.
  10. e.e. comings and goings
    No, it’s often low in the morning when I first get going to drive to work. After two 12-hour workdays last week, the charge both evenings was seven bars when I began the drive home, then went down during the 25-minute drive.
    No one else is driving the car, and I live in Eastern Massachusetts, so it’s not as if I’m driving extreme elevations. There are hills, but nothing very long or steep.
    One morning, the charge was two bars at the start, but within two miles was up to four bars. I think it was about six by the time I arrived at work; in the evening it eventually got up to seven while heading home, but dropped back down to four or so again by the time I arrived home. I’m not sure if I should be racing up to stop signs so that I can brake as much as possible (I’m used to hyper-miling with my old Corolla, coasting as much as possible to eke out about 41.6 miles per gallon over 11 years of owning that car) or if I should still be coasting as much as possible. I see that the battery recharges while I’m coasting, but I suspect that if I coast too slowly up to a stop sign, the electric motor may kick on. I usually drive slow and steady; no jackrabbit peel-outs. I’ve noticed that one traffic light in particular downtown seems to sense my presence in this car, and changes green as I roll up to it, so I haven’t had to sit and wait at it the way I used to.
    I’m also paranoid about sitting in the car after I’ve arrived anywhere, listening to the radio. I now just turn everything off as quickly as possible, afraid of draining the battery.
    I’ll be seeing my brother-in-law later today, and he has had a Prius for a year or more, so I will be able to discuss it with him.
  11. Mendel Leisk
    41,302
    There might be a problem with your battery, if the state of charge is consistently on the low side.
    OTOH it could your driving style. The main thing that will deplete the charge is purposely getting the car into stealth (electric only propulsion) and then protracted running just below the threshold where the gas engine kicks in.
    The Hybrid System Indicator (HSI) is a good display to use, for keeping an eye on things, if you've not already set it. Once you're in stealth mode, as long as you keep the bar to the left of center, the engine will stay off (unless the battery's really depleted). Your charge will be eaten up fastest when you're near that center point:
    There's nothing wrong with stealth mode, and there's nothing wrong with running the charge down a bit, in my opinion. That's what it's there for. If you put the car in cruise control you'll see it doing the same behaviours. It's mainly a matter of degree, you just don't want to push it too hard.
    There's a stretch of road I run fairly regularly, pretty flat, slight down grade, and almost without fail the charge starts dropping; it's too easy to slip into stealth. I'll stay in stealth, using light to moderate energy, 'till the state of charge drops nearly to half full. Then I'll purposely pulse the gas pedal to wake up the engine, and try to use pulse-and-glide more.
    Regarding sitting and listening to the radio with the car off, I've pretty much given up on that behaviour since getting our Prius. But it's not the Hybrid Battery that's being used (at least I don't think so): it's the (diminutive) 12 volt that's employed when the car's off.
    It's got a meagre capacity, so I avoid using it as much as possible when the car's off. Our model offers auto-headlights with delayed shut-off. I avoid using them. I also completely shut off the dome and hatch light systems, so they don't go on when doors/hatch are open.
  12. e.e. comings and goings
    Hmm. I hadn’t realized what was meant by stealth mode.
    I’d have to go out of my way to depress the EVO button, wouldn’t I? The screen you’ve illustrated above is what I have on display most of the time, and the indicator is usually in the Number 4 area, but I figured that was because I’m usually on back roads and the speed limits are no more than 40 or so. I’ve done hardly any highway driving yet.
    The first day I owned the car, I pressed the EVO button while stopped at a traffic light, not being completely sure what it was, but I heard the engine come back on once I got a little speed going again. Does the gas engine turn itself off every time I’m in the ECO area? Or does it just stay off if I’ve turned it off?
    When I back out of the driveway, I can hear the gas engine come on before I hit the brake now (just before I shift into Drive), as though the car knows how far I back up and is anticipating the shift.
    This is very interesting, thanks for all the information.
  13. Mendel Leisk
    41,302
    At normal, around-town town speeds, with engine fully warmed (or close), with a decent state-of-charge, any time you lift right off the gas, then gently re-apply while taking care to stay to the left of that HSI bar center line, you should be in stealth, ie: engine stopped. The in-dash display showing your mpg graph will show mpg up at the top. (I'm assuming you're in the 'States). Step on the gas a little harder, pushing the HSI bar graph past the middle point, and you'll see the mpg graph react, as the engine starts up.
    Note, at highway speeds, do the same behaviours and again that mpg graph will again show bars right up at the top. But in fact the engine will be at least idling (as indicated by a ScanGuage or similar, which can show rpm). I guess the engine's using very little gas though.
    Any time you come to a stop (assume decently warmed up) the engine will shut off. Then when you start rolling again it'll stay off, as long as you're to the left of that HSI bar mid-point. I recall our first test drive of a Prius, getting back to the dealership there was a modest upgrade into their lot. I had to come to a near stop, then started fairly slowly up the ramp. I could hear that engine had stopped when I'd near-stopped, then stayed off going up that ramp. ;)
    Another case in point for me is a multi-story parking garage we use: I'll pull in with decent charge, reach out to get a ticket, then start spiralling up through the levels. It's at low speed and almost without fail the engine stays off. By the time I park the charge is quite a bit lower, or down to two bars (where the engine is forced to fire up).
  14. e.e. comings and goings
    Yes, I have noticed the mpg shooting up to 100. I guess that must be it, then, that the engine is off and I don’t realize it. Wow.
    Thanks very much for all your help with this. I greatly appreciate it.
  15. Mendel Leisk
    41,302
    You're welcome ;)
  16. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    If you want to use the radio or A/C while stopped, put the car in P but leave it in ready mode. The HV battery and engine will maintain the 12 volt battery level. This is NOT accessory mode...make sure the ready light is on. You can do this for extended periods if necessary.​
