Battery replacement on recently purchased Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by heyomateo, Aug 27, 2013.
  1. El Dobro
    El Dobro A Member
    7,079
    3,259
    And he makes a great car, too. :p
    Andyprius1 likes this.
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . Yep, our genius madman, who lives on in our car.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Looking at the pictures in the trunk of the rusted bolts it looks like there was alot of water in that area.
    There have also been lots of reports of cracked body seams on that year that allowed water ingress into trunk. Most commonly found was a crack in the body seam where the roof meets the rear A pillar right by the rear hatch hinges in the corner valley.
    Look in the corner there next to the hinges and under the paint you'll see where they are spot welded together the roof & A pillar then puttied and painted. Look closely for a crack right there across the spot weld. Water runs through that crack down inside the car behind the interior valences and into the trunk filling the spare tire well.
    Not sure why that seam is failing but maybe from slamming the rear hatch or running hyperinflated tire pressure
    which is quite hard on the car.
    Whenever you close the hatch always leave a door open to lessen air pressure and as you pull the hatch down then put your hand on the Toyota emblem and close it as easily as you can. Use the movement/weight of the door to gently close the hatch in one smooth movement.
    Btw, anything in there that's starting to rust can be mitigated easily by just spraying this stuff on the affected area. It will stop further rust migration. Best product ever:
    Blaster Corrosion Stop Protectant - PB Blaster
    What's great about this stuff is its stays where you put it and does not smell. Do not use WD40 anywhere near the car. Thats stuff stinks forever. Only place I have found that sells CSP is Home D.
    Also if its that rusted inside get the car up on jackstands and get under the front. See how rusted it is under there.
    Spray the suspension down with this stuff. It really helps. One of the known issues concerning corrosion under the car and can be costly is the resolver connector on the transmission. Its the connector right above the 2 Inverter coolant hoses on the side of the transmission. Its high on the side of the trans. It will look rusted or corroded. Spray the hell out of that connector and pray it does not go bad. Failure of that connection due to corrosion is very expensive.
    Greg Grieve and Andyprius1 like this.
  4. Andyprius1
    2,327
    859
    Cool CA
    . Good info Ed.
    Greg Grieve likes this.
  5. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    The more I read of your thread, the more I think your Prius was flooded at some point. Just because there's nothing about it in CarFax doesn't mean it didn't happen. Nothing goes in CarFax unless the person repairing it logs it with the VIN. There are unscrupulous individuals who would pay someone to fix the obvious flood damage and people happy to take that money. If it lived on the Texas Gulf Coast at some point there are floods almost every year.
    That doesn't mean you can't fix it, but if salt water got into electrical components, they at a minimum need a good cleaning. Check under the door frame trim for corrosion.
  6. heyomateo
    heyomateo New Member
    Belton, Texas
    UPDATE: After testing the battery voltage, relays, and resistors none of those are what's causing the check hybrid system light to come on. Also, after checking for corrosion in other parts of the car, it appears that it is limited to the places seen in pictures I posted earlier, which was near the smart key system and in an area that was collecting sand underneath the seats.
    I'm starting to think the smart key system might be to blame for this light. It has very concentrated rust around the component, and is not functioning correctly in the car. Pictures are posted below.
    IMG_20130830_182948_329.jpg IMG_20130830_182954_640.jpg IMG_20130830_183010_685.jpg IMG_20130830_183601_058.jpg IMG_20130830_184055_885.jpg
  7. Patrick Wong
    18,200
    6,497
    DTC P3004 is not going to be caused by the Smart system. Your hybrid system has a problem.
  8. Coolride17
    Coolride17 Junior Member
    55
    Save yourself some headaches, check your 12v battery's voltage, Mine went down to 10.6, and all kinds weird things were happening. I replaced the battery, and that was it. I read this over and over in other threads too.
  9. Andyprius1
    2,327
    859
    Cool CA
    True, it never hurts to check/replace the 12v battery. I would never differ from Pats diagnosis. I most definitely replace that corroded piece of junk in your hand. I don't think that can be cleaned up. Items that I know of influencing the smart key system, "The 12 V Battery" and the Fob battery. Aside from that error code, what is the symptom now? Did all the HV battery cells check at about the same charge level, that is, within specs?
  10. Andyprius1
    2,327
    859
    Cool CA
    . Did you install a new 12 V Bat, recently?
  11. Andyprius1
    2,327
    859
    Cool CA
    What Coolride17 is saying here is absolutely true, and can be verified by researching this site
  12. heyomateo
    Belton, Texas
    My 12V battery, water pump, and serpentine belt were replaced at119,000 miles. Any other ideas?
  13. heyomateo
    Belton, Texas
    And at this point the car is not showing any error messages. The light went off when I pulled into the dealership to get it checked the first time. The HV battery checked out at 210V when I tested it yesterday.
  14. Patrick Wong
    18,200
    6,497
    OK, then keep driving the car and see what happens. It is possible that you had a loose connection somewhere which was fixed as you reassembled the traction battery.
  15. Andyprius1
    2,327
    859
    Cool CA
    . Agreed!
  16. Andyprius1
    2,327
    859
    Cool CA
    I just did some research on Gen 2 Hv Battery. 38 cells X 7.2 volts = 273.6 Volts @ 6.5 AH. According to those figures your voltage output is extremely low. Unfortunately in a series circuit low or bad batteries affect the rest of the batteries and of course read low. The HV batteries are actually in a series/ parallel combination to get the above Specs. The only way to know is to check every single battery. Too bad, we can no longer access all the old posts on Gen 1 and 2, maybe even 3 for all I know..... PS with an output of 210 I am surprised that the HV propulsion is even working.
  17. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    The corrosion on the smartkey antennae mounts won't hurt anything. That antenna does not need to be grounded.
    (although it's looking like the back of the car was underwater at some point, or exposed to salty sea air for an extended period).
  18. PriusInParadise
    180
    91
    Hawaii
    Sorry, but your specs are for the Gen I HV battery.
    Gen II and Gen II have 28 modules x 7.2v = 201.6v.
    210v is nominal, but the voltage alone will not tell you if there is an issue.
  19. Andyprius1
    2,327
    859
    Cool CA
    . OK , I stand corrected. The site I quoted specifically said Gen II 2004- 2009. Thankyou for the correction.
  20. tri4all
    tri4all Member
    99
    Pacific Northwest
    hi patrick could you please point me where in the manual is this? I could only found the number for insulation resistantance on Hv-433. thank you.
