Prius only Starting after Jump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Baquio, Sep 12, 2013.
  1. Baquio
    Baquio New Member
    Alright, so I think this picture is actually from a post by you, so sorry for taking it.
    Anyways, 3 questions/descriptions.
    Is 1 the wire I would be replacing? or is the one connected at 3?
    (and how would I even start going about that lol.)
    I tested the terminal connector located inside 2 and it is still a solid 12.9 volts.
    The cable at 3 refuses to come out no matter how hard I pull. There is also only one, even though it looks like there should be room for 2. Is this alright?
  2. Patrick Wong
    18,200
    6,492
    I suggest that you use a large flat screwdriver to pry off the red plastic cover so that you can easily see what is going on. There will be one very fat cable that is connected to a 120A fuse. Use your meter to verify that there is 12V on both sides of the fuse, and that the cable also has 12V. You should be able to find a problem somewhere there.
    If not, pls take a sharp photo of the positive battery terminal after removing the red cover, and post.
    You will also see a very thin wire that is connected via a 5A fuse, and that provides sense voltage to the DC/DC converter so that unit knows how much voltage is being provided to the battery when the Prius is READY. There should also be 12V on both sides of that fuse.
  3. Baquio
    Baquio New Member
    Should I cut open the rubber on the 120 A fuse to test the voltage?
  4. Patrick Wong
    18,200
    6,492
    It might be better to use a needle to pierce the rubber so that if the fuse is OK, you don't loose that protection.
  5. sach0325
    sach0325 Junior Member
    I am in same situation. When I check the battery voltage it shows 11.5 V but it wont start the car. I have to jump it always to start it.
    @Baquio: What worked for you?
  6. Patrick Wong
    18,200
    6,492
    Two possibilities: 1) your 12V battery has a low charge and needs to be recharged or replaced. 2) A battery cable is loose which introduces resistance into the cabling and reduces voltage further, as you try to start the car.
  7. Mendel Leisk
    40,575
    Yeah a battery in so-so shape would be showing voltage of AT LEAST 12.4 volts; 12.6 or higher is good shape. Voltage readings can vary, and don't really check the battery's capacity: get it checked out with an Electronic Load Tester. Automotive retailers often have them and will usually test for free. Dealerships will have the tester too, but charge maybe $75~ to test.
    If you want to DIY the test google Solar BA9, for one such tester. They measure Cold Cranking Amps, and typically give a verdict on the battery, whether or not it's viable, needs charging, or a dud.
  8. Jan_Marcel
    Jan_Marcel Junior Member
    Brazil
    Any updates guys? Same problem.
    brand new battery
    all battery wires checked.
    but car just start when you connect the jump or another battery.
  9. Mendel Leisk
    40,575
    Check voltage at jump point? That’ll check if there’s a loose connection somewhere.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    That information might have been useful for him........about 9 months ago !!
    :rolleyes:
  11. ChapmanF
    17,326
    Some posts just need a little time to ripen. #30 will come into full flower just about 9 months after post #28, so around the last week of January 2022.
  12. Mendel Leisk
    40,575
