Charging at work
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by antonyhsu, Oct 3, 2012.
  1. antonyhsu
    antonyhsu openhearted78
    Ann Arbor, MI
    I just received my new plug-in prius. Haven't even named it (willing to listen to suggestions).
    How does one frame the conversation at work regarding charging and etiquette/cost sharing?
    Thanks,
    Tony
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    u got a neighbor jimbo69ny, ask him
  3. antonyhsu
    Ann Arbor, MI
    Right, I'll ask him. In the meantime, what about the rest of you? Here is what I received back from the VP of Facilities:
    The Center is in the process of master planning for both the building and the outside property/parking lots. We plan on tearing down the barn at some point (hopefully in the next year), so we can’t commit to setting up a parking area for electric cars at this time. I will put your e-mail into my master planning folder for future reference as planning progresses.
    Sent: Monday, October 01, 2012 12:14 PM
    Subject: Electric vehicle parking
    I know this is coming from Left field, but we have 3 staff with hybrid cars and being one of those, I'm looking to move forward with a plug-in hybrid myself in the next 2-3 months. My poor Prius has 181,000 miles on it. I've talked to GH and other maintenance guys about outlet options and the barn by the parking lot already has weather protected outlets (at least one does, the other needs to have its plastic clear cover fixed). If it's okay with you, I'd like to plug mine in when I get to work, but I have a couple questions...
    1. The electric cost may range depending on how much I need to charge. I plan on the 4.4kW battery to be depleted by the time I arrive. At $0.10 per kWh, that would be $0.44 per day that I work.
    2. If others decide to go that way too, each 120W outlet requires its own fuse because it draws up to 15 amps.
    3. I would recommend that the spaces be specially marked for "plug-in cars only" to minimize cord stretching (25 feet long) in other spots.
    4. Maybe a survey to the staff would help determine future needs and administration should come up with outlet-use rules and regulations.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  5. Rebound
    Rebound Senior Member
    3,991
    2,638
    Portland, OR
    I wrote up estimates of annual electrical costs by vehicle model, and recommended that employees who want daily charging should donate that amount to the Company's favorite charity, a local food bank.
    I also told then that 8 120V outlets is better and cheaper than two EVSE's.
    drash likes this.
  6. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
  7. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    antonyhsu,
    Where do you work in Ithaca? I'm in Rochester.
    If you're looking for a Policy, check with Cornell or Ithaca College. Both should have policies in place by now.
  8. RBooker
    RBooker Member
    154
    56
    At cornell it is OK to plugin. There is at least one level-2 charger employees can use.
  9. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    You live here in Ithaca huh? What color is your PIP? What is your average mpg? These hills are really rough on the ev range.
