coatings and sealants... so many options... looking for guidance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2clicker, Sep 17, 2013.
  1. 2clicker
    2clicker Member
    114
    28
    St. Louis
    so after some research on PC and other forums including AutoGeek i am officially lost. what i am after is a coating or sealant that is tough, low maintenance, and only needs to be applied every 6 months (12 months even better!). so far i believe i am planning to use Rejex due to its price, slickness (super easy to clean), and durability. The curing time seems to be a PITA, but i can live with it. i really like that nothing really sticks to it so cleaning off most dirt can be done with a stream of water.
    during my research i have come across Zaino, Chem Guys, DPcoatings, Klasse, BlackFire, Wolfgang, Opti Coat II (would love to hear more about), and others that i cant remember. also read about ceramic coatings and polymer coatings... my head is spinning at this point. im a looking to get my prius protected before the end of October.
    looking for something durable/long lasting with great shine. what advice can any of you with experience with these different sealants and coatings give?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    You're basically describing almost any quality car wax. I like Turtle Platinum liquid, it does pretty much everything you ask for and is a snap to apply. No polishing and it LASTS. Add a second coat and its bullet proof. Don't ever-think this, there's too many snake oil sellers out there telling you that you need this or that. All you need is a quality car polish.
  3. 2clicker
    2clicker Member
    114
    28
    St. Louis
    thanks, but im def not looking for any carnauba wax. ive been using mothers 3 step system for a while now and while it is really good stuff, it just doesnt last as long as i would like. 3-4 months tops before i needed to reapply. i doubt turtle wax makes anything better than mothers.
    and to be more clear i should say that the 6 month lifespan i mentioned is on the low end of what im looking for. more like 8-12 months like Rejex and others offer. going to look into opti coat II some more as its supposed to be permanent.
  4. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Collinite 845. Going on 10 months on my Subaru and still beads up nice.
    2clicker likes this.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    No car wax on the market can last 6 months. You'd need a polymer sealant or equivalent.
    elementnomore and 2clicker like this.
  6. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Being more expensive doesn't make it any better.
    The Turtle Platinum liquid is formulated with flouropolymer resins. It lasts about a year for me. Vehicle garaged and washed about once a month. Like I said, if you want more protection you can apply double coats. Its amazingly easy to apply, no rubbing at all. Suit yourself, but it doesn't take expensive products or special effort to get what you're asking for.
  7. 2clicker
    2clicker Member
    114
    28
    St. Louis
    first you said that im "describing almost any quality car wax", but a wax wont last near as long as i need the protection to last (that pic is a sealant not a wax). then say "All you need is a quality car polish", but polish is for prepping and cleaning the paint surface not protecting it. and follow that up by posting a pic of a Turtle Wax brand sealant... of which is neither a wax or a polish.
    i understand that just because something is more expensive doesnt make it better, but i also believe that if something IS better that its likely going to cost more (usually because its made of better materials). ive used numerous waxes including Turtle Wax and Mothers was by far the best ive used, but im done with waxes at this point. they do not last long enough. i need a sealant or a coating.
    thanks for the recommendation on the Turtle Sealant. you say it lasts you a year eh? and the application requires no rubbing? sounding good. ill look into it.
    my top two candidates so far are Rejex ($15) and Opti-Coat 2.0 ($70), but i would love to hear of any experience PC users have had with them.
  8. 2clicker
    2clicker Member
    114
    28
    St. Louis
    *EDIT* my normal edit function isnt working properly
    rdgrimes, my apologies... i was wrong about the pic you posted. i will have to look into that stuff, its wax, but its not carnauba eh?
  9. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Its a blend of polymers and Brazilian carnuba.
  10. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I used Duragloss sealants followed by Collinite 845. Great combination, very durable and highly affordable.
  11. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Check out Liquid Glass
    Check Amazon for reviews. I got about 4-6 months coverage last winter then shine tapered off but protection remained.
  12. LordEastwood
    LordEastwood New Member
    I bought some Zaino brothers about a month ago and clay bar'd, put on a coat of z5, then z6, followed by z2, z6, and finally a coat of z8. Having a black prius helps but, the shine is outstanding. With Zaino, you will be wiping your car a number of times if you are starting with clay bar and putting on multiple coats however, the results are worth it in my opinion. The beading action is fantastic, the depth of shine has no limit, and the black actually looks darker and richer.
    I would highly recommend it but note that there is one down side of Zaino. You will be washing and wiping your car dry more than you ever have before as a clean zaino'd car looks awesome.
    dbcassidy and 2clicker like this.
  13. 2clicker
    2clicker Member
    114
    28
    St. Louis
    while looking at Liquid Glass i also found "Liquid Glass Shield" Liquid Glass Shield - Welcome to a revolution in protection... stuff looks pretty incredible for all kinds of uses.
  14. snead_c
    667
    58
    Hendersonville
    I'm not familiar with it. LG makes very long life claims but does require reapplications as any of them will. LG Shield seems interesting but I'd wait for lots of others to try it on their cars before I do...I don't believe ANY product will last more than 6 months when exposed to weather. Besides after that long I usually have enough tar and stuff clinging to my paint that I need to give the finish a seasonal clay bar+ work over anyway.
  15. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Hi 2clicker,
    I always being user of KLASSE products over 10 yrs, and only found out about Opti-Coat 2.0 about two yrs ago.
    you can read my comments on this thread, Should I buy $50 Zymol car wax? | PriusChat
  16. 2clicker
    2clicker Member
    114
    28
    St. Louis
    i think im going to go with Optimum Opti-Coat 2.0. i really REALLY love the idea of never having to wax it ever again. i will use high quality wash and likely a quick detailer on top of the opti-coat, but other than that it seems extremely low maintenance.
    with October coming i should have quite a few days that will allow me to apply it w/out cover (no garage).
    NoMoreNow likes this.
  17. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    I posted this in a stickied thread over in the Gen II forum, where it would probably never be seen by Gen III owners. This details my experience with the new paint coatings compared to premium sealants and thought it might be useful to Gen III owners. Hope this type of reposting isn't frowned upon.
    I'm not very active here any longer, but I just checked this thread and noticed that there hasn't been any mention of the new paint coatings that have become available within the last three or so years. I did a quick search for "opti-coat" and "Gtechniq" in this same forum for the Gen III Prius and there were a couple threads, but that was all.
    Paint coatings for automotive paint application were introduced about three or four years ago. The first time I heard of them was when there were rumors of a new product from Optimum undergoing testing that would make paint sealants obsolete (Optimum happens to make a very good paint sealant, Opti-Seal). The early versions were somewhat tricky to apply, and didn't produce consistent results, but in the last three years, I'd say they've been perfected, and I now no longer apply sealants to my own cars. Previously, I had settled on a combination of Zaino Z-2/Z-5, with Optimum Opti-Seal to top it off between applications. Now two of my cars (including my Prius) have Gtechniq EXOv2 on them, and the third has 22PLE Pro on it.
    The coatings are like sealant on steroids. You can expect about 4x the life of even the best sealants - two years is expected under normal conditions, and Optimum Opti-Guard (available only to pros) can essentially be considered permanent. The EXOv2 on my wife's Lexus is six months old, a point where Zaino would barely be showing any evidence of its presence. In contrast, the EXOv2 is still exhibiting hydrophobic properties (beading), gloss, and slickness I've never seen from a new application of any sealant I've used (and I've used many: products from Optimum, Zaino, Four Star, Klasse, Blackfire, Wolfgangs, Meguiar's and others I can't recall). It's amazing how the water beads (measured as the angle between the surface and the edge of the water droplet) and just slides right off. There are many videos on YouTube showing this property of paint coatings. Water slides off the paint so easily that there is almost nothing to dry after washing and rinsing your car (using the nozzle-less "sheeting" technique to rinse). It makes it really easy to dry your car by just draping your waffle-weave microfiber towel on the car, and drawing it lightly across the surface. This was true of drying a car that had a fresh coat of sealant on it, but the coatings take it to a whole new level. There is literally 10x less water on the car after rinsing compared to the same car if it had sealant on the paint, using the same rinsing technique. My drying towel doesn't even look like it's been used after I'm done.
    The big drawback to the coatings for most is their price (well, that and the required prep work, but for me that is the same regardless of what's going on top). A single application uses about $35 worth of product, while the same car wouldn't even use $1 worth of Opti-Seal or Zaino per coat. IMHO they are well worth it though; with a sealant I'd be looking at a light decontamination and possible light paint correction before reapplying sealant now, while I've probably got a year or more to go before I need to consider that for the paint coating, all the while enjoying protection and appearance that far exceeds anything I ever got out of a sealant. I've also found that "topping" the coating with anything - instant detail spray or spray sealant - reduces their performance and worsens the appearance, so I don't put anything on the paint after I wash and dry. I keep the instant detail spray around to get off the occasional bug or fingerprint, but I've got an almost full bottle of Gtechniq C2 sealant that I will probably never use, at least not on my own cars.
    If you can properly prepare your paint for a sealant - this means decontamination with clay or similar product (they have sponges and towels that do the same thing now), followed by machine polishing (I am partial to Menzerna polishes and have used them for ten years, although I have some Meguiar's M105 Ultra-Cut Compound for fast defect removal), you can apply a coating. While you may be able to apply a sealant or wax to a less than perfect finish, the coatings demand a near perfect surface. You're basically locking in the appearance for the next two years, so you want it to be as good as it can be.
    Paint coatings are mentioned a lot in some of the forums I frequent, such as the Lexus and Tesla forums. I imagine this is because owners of those cars don't mind spending $500 or more (usually a lot more) to get their paint corrected and have a coating applied.
    Here are a few coatings that have good reputations:
    CarPro CQuartz Finest (only available to pros, non-pros can get regular CQuartz - I would love to get my hands on some CQuartz Finest)
    Optimum Opti-Guard (only available to pros, non-pros can get Opti-Coat 2.0)
    Gtechniq C1 and EXOv2 (EXOv2 is especially easy to apply, in any temperature, but not as long lasting as other coatings)
    22PLE VX1 Pro
    There is general agreement that Optimum Opti-Coat and Opti-Guard are the longest lasting, but that others have better hydrophobic properties, better gloss, and more slickness. Gtechniq EXOv2 is very forgiving in its application, so its a good choice for someone new to paint coatings. With other products you need to be careful to follow the directions exactly, and insure they are applied within the mfgrs recommended temperature (and sometimes humidity) range.
    32kcolors likes this.
  18. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    I Opti-Coated the Prius a while ago and it's by far the best vehicle paint product I've ever seen or used. I highly recommend it. ...after a thorough clay-barring of course.
  19. mrbigh
    3,686
    699
    Long Island, NY
    Great write-up. Thank you for the inside info
  20. Mendel Leisk
    41,192
    Just to toss it out:
    I've been using Meguiar's NXT Generation Tech Wax 2.0. Spring and Fall. It's about $25 a bottle (Can) on sale, $30 not on sale. Goes on-and-off easy, seems pretty durable. Smells nice.
