Help me pick the spare tire for my 2012 PIP.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Darup, Sep 18, 2013.
  1. Darup
    Darup Junior Member
    56
    I am going to plan the long trip next weekend and I would like to carry the spare tire.
    I am not sure which model to pick. Please provide me the tire model or link to the website works fine.
    I would also like to see some pictures on how to secure the tire properly in the trunk.
    Thanks always for helping me, I love you guys and also my PIP :)
    51,711
    i think the spec is in the faq. have a great trip!(y)
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    There should be a black tie-down strap in one of the storage bins in the cargo floor area. Loop it through the rings at the rear and through the spare wheel and pull it tight. I also stretch two bungie cords between the four rings and cross over the tire. I bought a donut spare from a 2010 Prius at a salvage yard. The specs are different for the Gen II and Gen III cars, and the Gen III has the proper size for the PiP.
    I now have a full-size spare on an OEM alloy wheel, and it fits fine in the cargo area although I sacrifice some cargo space. OTOH, ours is not used for long vacation trips, so most of my cargo consists of groceries. If I need the space for a trip to the nursery or Home Depot, I can always pull the tire out.
  4. Darup
    Darup Junior Member
    56
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I just got an Altima donut spare for my Leaf (the Ecopia tires they come with are known for blowouts, sadly) and ended up wishing I'd gotten the smaller of two possible sizes, as the larger one doesn't even sit flat in the cargo area because of the $#@! subwoofer enclosure for the sound system. At least it looks big enough to drive safely at 55MPH on... Anyway, how well does the Gen III donut spare fit in the PIP cargo area?
  6. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I paid $100 to include shipping for mine off eBay. I've seen them since for less than that. Depends how quickly you need it.
    :)It lays flat, but it's a fish out of water. When I purchased mine, I carried for about a month. Decided, it took too much space and was a hassle, so I store it in the garage. My travels are mostly local so I'm not concerned. Any travel and I'll carry it.
  7. bisco
    51,711
  8. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    I bought this very inexpensive cover from Amazon to, umm, cover mine while carrying it in the car:
    Camco 45359 RV Vinyl Spare Tire Cover (21-1/2" Diameter, Beige)
    cost about $10 shipped with amazon prime.
  9. rogerv
    1,639
    317
    Darup, did you try contacting a salvage yard? If they are in the computer system with other salvage yards, they can have a wheel shipped to them in order to sell it to you. Granted, it may not be any cheaper than the deal you found. Too bad you aren't closer to where I live- I would make you a deal on mine.;) You said you needed one right away for a trip. It will probably take a while for one to be shipped to you from an eBay seller, and the shipping charges aren't likely to be cheap, due to weight.
    The $450 mentioned above sounds like it would be for a matching alloy wheel and tire from the dealer, rather than a donut spare.
  10. Darup
    Darup Junior Member
    56
    I can change my road trip by one more week, I am in transition between jobs :)
    I do not want to go for the trip without the spare.
  11. Darup
    Darup Junior Member
    56
    How to find if this fits ??
    T135/ 70R16. Previously came with 2010 Toyota Corolla
    There is one guy selling it close to my home.
  12. bisco
    51,711
    you need the spec on the wheel. the correct one is in the faq. if it matches, you're good. if you read through some of the spare tyre threads, you will find some people have used a corolla wheel.
  13. bisco
    51,711
    full price on donut and steel wheel, mounted and balanced. hard to believe, i know. that's why nobody wants to buy a new one.
  14. Darup
    Darup Junior Member
    56
    It doesn't match exactly.
    The specs from the FAQ --- T135/80D16 101M
    But, it comes from the 2010 corolla.
    T135/ 70R16
    T -- temporary -- matches :)
    135 -- width --- matches :)
    70 - -aspect ratio -- no match ( some bought the aspect ration of 70 in this thread)
    70% of section width to 80% of section as per manual is not much difference.
    R -- does not match --- it might not matter as Radial is better than Diagonal as per manual.
    16 -- tire and wheel diameter -- matches :)
    I am not sure on what is 101M.
    Seller responded that he will call me.
    I am going to pick it up, Please let me know if I am doing any mistake......
  15. bisco
    51,711
    it says the wheel size is 16 x 4T, i don't see that in your spec? i don't think the tyre much matters.
  16. Darup
    Darup Junior Member
    56
    Thanks, I need to find it out from the Seller.
  17. Darup
    Darup Junior Member
    56
    Can I find the wheel size from the markings on the wheel ???
  18. bisco
    51,711
    sorry, i wish i could be of more help, but i'm no wheel expert an purchased a used gen III donut because of it.
  19. bisco
    51,711
    i have no idea, hopefully someone with more knowledge will jump in here.
  20. Darup
    Darup Junior Member
    56
    Thanks, I read in this forum that somebody bought the corolla later model donut and it worked well.
    I am going with that instinct.
    I do not want to be stranded in the middle of nowhere while on vacation because of the small mistakes.
    I am anxious and dont want to spend $450 for a new one :)
