ClipperCreek Launches LCS-25P: World’s Smallest Cord and Plug Connected 20 Amp Level 2 Charger
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, Sep 16, 2013.
  1. Francos
    Francos Member
    118
    Finally found the ideal toggle s
    Finally found one:
    Product Datasheet -- 3025I
  2. Francos
    Francos Member
    118
  3. hill
    8,831
    In many areas, that won't be to code. There's a much better (and equally simple) way to go. Have that 240 line fed into a disconnect box. In the box have 2 individual breakers - one for the heater & one for your EVSE. Have both breakers on an 'interlock' plate (see picture). . Interlock.jpg
    Turning on which position your breaker is in - it's impossible to feed the other breaker. And, each utility has its own breaker.
  4. Francos
    Francos Member
    118
    Thanks for the advice. The disconnect box looks very nice. what is the brand and model of the box?
  5. hill
    8,831
    There are several brands ... ours is made by "Square D" - but there are several others.
  6. Francos
    Francos Member
    118
    This one pictured serves my purpose perfectly. Can you provide a link to the disconnect. I did a search and could not find one. thanks
  7. Francos
    Francos Member
    118
    My friend got this charger. He loves it.
  8. cooljw
    cooljw Member
    183
    46
    Toyota and the rest of the car companies should make these dual voltage and they should come standard with plug-ins. Just like the chargers for my laptop, smartphone...etc. It makes no sense they haven't figured this out yet!
    Oh wait, Tesla already figured it out.
  9. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I agree it seems really silly not to include that circuitry in every model.
  10. hill
    8,831
    if you buy or build your own quick 220 appliance...
    Quick 220 Systems
    ...you can reassemble 240v from opposite 120v legs ( as long as neither have ground fault interrupters).
  11. Tikiman
    Tikiman Junior Member
    When you move you can take it with you. Most of the EV chargers for the garage are hardwired to your electric panel and cost more.
  12. bisco
    52,068
    mine is plugged in, open evse project.
  13. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    It means you don't need to run wires or install a breaker. Depending on the situation, it might be as simple as the electrician installing a second electrical box next to the existing one and using the new one to connect your equipment. It may be a very quick and simple job.
    13 amps at 120 or 240 volts.
    The first generation pip will not, but a 40 amp system does not cost double the price of a 20 amp setup, only a little more, and you would be ready for later and presumably more powerful machines.
    #33 kenmce, Jul 26, 2014
  14. hill
    8,831
    #34 hill, Jul 27, 2014
  15. ELYKB
    ELYKB Junior Member
    32
    Los Angeles
    2014 Prius Plug-in
    Leviton 1288 toggle switch
    #35 ELYKB, Jul 27, 2014
  16. bisco
    52,068
    someone here got a juice box a while ago. i think they liked it, but it didn't come with the battery case like they show in the pic for the low price. looks like it comes with a built in timer?
    #36 bisco, Jul 27, 2014
  17. hill
    8,831
    Clippercreek is a great product imo, but I know many want more plugin range/capacity. That means you're going to want to have faster charging. That'll require more power. The JuiceBox can deliver about FIVE times the 204v charge rate of what the PiP's system is designed to receive. But Dee's have already mod'd pack sizes as well as charging speeds. For example, the folks on the Toyota RAV4ev forum are finishing up a ~ $2,000 "J-plug to Chademo adapter" called the Jdemo
    Toyota Rav4 EV Forum • View topic - CHAdeMO for Rav4 EV "JdeMO"
    .... that'll supposedly provide almost 100 miles in a tad more than a half hour. All that to say - it's good to buy more evse than one needs ... looking forward to the next generation.
