Thinking of Adding Charge Station
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Collins, Sep 25, 2013.
  1. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    As it says in title I'm "thinking"..! I have 2013 PIP Base and don't have much patience waiting for my car to get it's full charge. I see theres all make and models of series two and some series three
    charges on the market. All kinds of prices and what else.. What i need is a fast charge at the lowest cost. Guess thats everyones desire .....right. So who has what and likes it and who has what and is sorry they spent money on it. I already am having one j1776 cable upgraded. But a nice charge station would be nice and make the neighbor's jealous. And be on the road again in the shortest time. possible. My budget is around $1000 less is better
    52,193
    the cheaper the better, cord length is the only thing that matters. unless you're preparing for a larger battery down the road.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    For 'quick' charging (90 minutes) you need a well protected 240V outlet (dedicated circuit recommended). If you have such an outlet and your portable EVSE cable is upgraded (as you say) to 240V, you can DIY "charge station" in less than $100 and impress your neighbor.
    Below is what I did (our std voltage is 230V)
    The box is IP66 protected and has a lock. costed me about $30. You can see I added a 3/4" thick plywood board screwed to the inside back for easy mounting of components. See also the drill (half circle on the box and half on the cover door) for the cable to charge with the box locked (to protect from the neighbor...)
  4. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    I just installed the Bosch Powermax - the 30 amp until with the 25 ft cord. It was $749. The 16 ft unit is a bit less. Assuming you have no major electrical issues, you should be able to get an electrician to run a dedicated circuit for about $300 - as long as you don't used the Bosch certified electrician.
    PeteSJCA likes this.
  5. Bill Collins
    2013 Prius Plug-in
    I like that setup.. I like the BOX ..looks to be like 12x20x8 am I right?? Were did you buy it ? Thats just what i need
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The box is 500l x 300w x 200 mm deep (yes, about what you estimated) made from FRP by Hager - a well known European supplier of electrical components and accessories. They have many standard sizes.
  7. davidhuff
    davidhuff Junior Member
    63
    Salem,OR
    2013 Prius Plug-in
    Just seen a Bosch Level 2 Power Charge Station on Ebay .
    Top bid is $225.30 and bidding ends very soon.
    Note:check out shipping cost before you bid!
    Good Luck
