Japanese Error Msg pls Help!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by maffer, Oct 10, 2013.
  1. maffer
    maffer Junior Member
    I have prius 3rd gen 2010 japanese, used it without any issues for over a year. abt 3 days ago i got an error msg on the dash with exclamation mark when i stopped the car. since then it comes once in a while only when i stop the car. the msg is in japanese. pls help me, i dont know if its a critical issue. pls see image for the msg.
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    It means your key battery is low and needs to be replaced.
    SCH-I535
    Don't believe me? :D
    Go to Google translate English to Japanese and translate: replace key battery
    Most of the characters are the same. ;)
    SCH-I535
    WE0H likes this.
  3. maffer
    Thats it ??
    you are an angel!!!
  4. xliderider
    8,140
    3,274
    Honolulu, HI
    Hardly... but you're welcome. :)
    SCH-I535
  5. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Just to confirm, this is a Japanese domestic market car, right?
  6. bigboco
    bigboco Junior Member
    It tells you only very little power left on your key battery. Base on my own experience, the key battery will die in about a week after this message pop up. You should check how to start the car without key battery in case you won't be able to replace it on time.
    How do you get Japanese firmware? It'll be pretty cool if I can have it on mine.
  7. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Or maybe our Prii are ESL? :D
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    To the Op, it would be helpful if you also put your location in your profile. (y)
    I'm assuming you're from Africa, India or Pakistan where the import of used RHD JDM cars are very popular. Many of these cars will have sat at the docks for weeks, sat on a ship for weeks and then sat at the dealers compound for weeks before being sold.
    As you've made a significant investment in this car, you may want to protect your peace of mind by replacing both the keyfob battery (easily obtainable) as well as the 12v battery which is situated in the boot on the right hand side. The Prius isn't a fan of being jump started (don't get it wrong or it'll be expensive) and the 12v is a weird size, but it isn't that expensive to replace. Once you've changed both batteries you should have a reliable and fuel efficient car.
    Oh, to get the best economy you might want to keep your tyre pressures correct, use expensive 0w20 oil every 10,000 miles/16,000km. It is hard to find but really does bring the best economy and performance out of the gen 3 Prius. Finally, make sure passengers in the back don't block the vent!
    The a/c condenser at the front is liable to stones hitting it, so maybe an additional metal mesh may help? Otherwise the Prius should be ok.
    Enjoy :D
    SterlingH, Szulkarn and WE0H like this.
  9. PubuduG
    PubuduG New Member
    New York
    This was very helpful.I had the same issue.It went away after i changed the battery of the key.
    #9 PubuduG, Dec 19, 2014
  10. kish1212
    kish1212 Junior Member
    Mu
    Hello friend i have a Toyota Prius 2010 and i am sometimes getting the following error message in Japanese, when trying to start the vehicle. It also does not get into the ready mode. Then i tried to put on sequentially that is ACC then ON then Start. Then it started. Can you please help me. ??? 20160730_165259.jpg
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I can't read Japanese, so am guessing here. Have you checked the 12 volt battery? It is possible that it might need to be replaced.
  12. xliderider
    8,140
    3,274
    Honolulu, HI
    I can't read Japanese either, but I will ask my coworker when I get a chance.
  13. xliderider
    8,140
    3,274
    Honolulu, HI
    OK, my Japanese coworker translated the message.
    Your auxiliary battery (12v) is low and needs to be replaced.
    dorunron, GrumpyCabbie and Dino33ca like this.
  14. DavidA
    2,344
    1,820
    Chicago western burbs
    If your car is telling you that the 12v battery is about to die, by all means, and as quickly as you possibly can, get a new one installed pronto. All sorts of bad can happen when the 12v can't start the computers and other gadgets in your car.
  15. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Why don't they provide a corresponding English message when appropriate in the North American version?
  16. xliderider
    8,140
    3,274
    Honolulu, HI
    Most of the people posting these inquiries have JDM imports in other countries like Pakistan and Australia, etc.
    GrumpyCabbie likes this.
  17. kish1212
    Mu
    Thank You very Much all friends,
    I gonna check the 12v Battery.
    But just to point out that i changed my 12v Battery in June 2015 to a Bosch 45 Ah and its only 1 year i have been using the 12v Battery and its almost dead.
    Can anyone suggest me how is it possible? Is there any problem?
    Thank in advance
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Cell phone tower nearby? or airport or radar? Do you keep the keys within about 20 feet/8 meters of the car when it's locked? Have you checked the boot/trunk light as sometimes they don't turn off correctly - ie make sure the hatch is fully closed or maybe turn that light off.
    Failing that, don't use 'ACC' mode when listening to the radio as the 12v is quite weak and takes longer to charge up with a hybrid. Use nomal mode to listen to the radio etc. Also, if you hand the car to a dealer to service it make sure you turn off the interior lights as many dealers will open all the doors and leave them open for hours while they work on your car.
    Charge up the 12v and see if it's healthy and holds its charge. If it doesn't, just get rid. A proper Prius 12v is cheap enough and has all the correct vent tubes etc.
    Szulkarn likes this.
  19. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    That doesn't answer why, if Toyota provides warning of a failing 12V in Prii in their domestic market, they don't do the same for versions sold elsewhere. That might reduce some of the complaints from unhappy customers that they're surprised when the battery leaves them stranded, supposedly without warning.
  20. xliderider
    8,140
    3,274
    Honolulu, HI
    Sorry, misread your original post. Yes, I agree that a similar message would be desirable in USDM vehicles. :)
    CR94 likes this.
