Install a bike rack
Discussion in 'Gen 2 Prius Accessories & Modifications' started by preass, Oct 8, 2013.
  1. preass
    preass New Member
    Hello everyone I`m new here. I have a 2009 prius and a bike rack from my 2003 highlander. The bike rack is the universal type that touches the car in two places with padded rubber. Then it has straps to attach it to the car. It should fit any car based on the instructions. My concern is the prius and its glass under the wing in the back. Is it OK to put all this pressure on that wing section? I attached an image of the type of rack. Has anyone used this type of rack on the prius.
  2. preass
    preass New Member
    Is no one using bike racks or are these forums dead?
    iPhone ? - now Free
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Forum is far from dead, no one has replied to your post. Several use bike racks, but most are using racks that are mounted on the hitch.
    I don't use racks, simply replied to state Prius Chat is far from dead.
  4. preass
    preass New Member
    Thanks for the update I was starting to wonder. Is anyone out there using the type of rack that I'm showing here? If you are how many bikes do you put on it my rack holds three bikes.
    iPhone ? - now Free
  5. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I use a Saris bones III that is similar with no problems. IMG_4035.JPG IMG_4035.JPG IMG_4037.JPG IMG_4038.JPG
  6. preass
    preass New Member
    Wow, thanks for the info. That dosent make you nervious that the top is resting on the glass?
  7. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Hitch much better IMO. More stable. Access to hitch. No paint contact w either car or bike. Ours from 1UPUSA.com :: Home is so clean and tidy. We love it. image.jpg
  8. john1701a
    john1701a Prius Guru
    12,821
    5,305
    58
    I used this Saris for many years, on both my 2004 Prius and the 2010...
    ...except I located the feet on the bumper, directing about 95% of the weight there. That way, the glass contact is virtually nil and only serves the purpose of stability.
    Recently, I upgraded to a receiver-hitch... at triple the cost. The strap-on rack is definitely the better priced option. But being able to lock a rack and carry 4 bikes with little effort was a big draw. You can still open the hatch too. I leave the rack on the entire vacation, not having to find a place to store it when not in use during trips is nice. It folds down as well, allowing me to load our 3-wheel recumbant inside without having to remove the rack.
    Do some searching in the forum. You'll find a number of threads addressing bike carrying options.
  9. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Thought i have a Gen 3. , I don't trust those trunk racks. I thought those type of racks were "dead".
    No comparison to hitch or roof mounted ones.
    Here's a bunch. Show Us Your Rack! | PriusChat
  10. tjamscad
    tjamscad New Member
    Goddard, Kansas
    I use the same rack as pictured in the OP. It has been no problem but it gets removed when not in use.
  11. Prius904
    Prius904 Junior Member
    48
    I have a saris bone for two bikes and haven't tried it on my prius for the same worries the op had... I have seen multiple testimonies though from prius owners that the rack is fine. I used to keep my rack on my old car 24/7 so I was always ready to load and go... Im not going to do it on the prius, because the visibility out the back is already poor... Looks like the rack makes it even worse.
