Changing Transaxle oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Weinerneck, Mar 14, 2008.
  1. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I think your dealer just gave you a little extra lovin'
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Even if your labor rates are a bit lower than ours, and I don't know that they are, it's still reasonable.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    You know your really bored when you quote yourself :rolleyes:
  4. willchu
    willchu Junior Member
    51
    Northern NJ
    Got a price over the phone to change the trans fluid at $99
    Went there and the service manager told me it actually is $289 but he would give me a 10% discount for the misquote ... I left and was pissed.
    How do you get around these toyota dealers and their effed up scheme?
  5. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    If I had bothered to go there at all I would have told him his bait and switch method just lost a customer forever and that his outrageously priced service can be done by any teenager for $75 or less including the fluid in less than 30 minutes. I would say the same thing to the dealership owner later over the phone. But I probably wouldn't go there for this anyway because any mechanic can do this. My independent mechanic did it for $30 when I supplied the fluid, funnel w/long neck, and basic instructions and pictures with the Haynes manual.
    PriusGuy32 likes this.
  6. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I dont want to jinx myself, I do all of my own maintenance but had my Prius in 2-3 times for recalls and stuff they screwed up after touching my car (steering wheel off center after steering shaft recall).
    The dealer didnt try to upsell or overcharge me on anything... I was surprised. I even bought wiper blade refills at the Toyota dealer parts department on the cheap.
    A transmission fluid change on the Prius seems easy peasy, compared to the trans fluid changes Ive done in the past (dropping the pan, replacing the filter/filter grommet, etc). Even if I got lazy, I would NEVER pay any place over $99 for the job.
  7. willchu
    51
    Northern NJ
    Why is my nearby Toyota parts charging me $11.75 per quart of fluid?
  8. PriusGuy32
    1,417
    513
    Holy crap. Let me call my local Dealer real quick and ask what they are charging.
    EDIT: My local Toyo Dealer (Hoot McInerney) charges $8.98 per quart of Toyotas World Standard (WS) transmission fluid. Hope this helps!
  9. Mendel Leisk
    38,992
    Regardless of the price (House Brand transmission fluids tend to be pricey), it's peanuts. The few bucks you're sweating over, you'd drop that amount on a few hours in a Vancouver parking lot, LOL.
    I forget the details, haven't got the receipts on hand, but I believe 4 Liters and the washers set me back around $40 Canadian when I did ours.
    Merkey likes this.
  10. exbauer
    exbauer Active Member
    1,185
    101
    Washington
    I just got mine transmission fluid drained and filled at a local shop that specializes in Toyota and Lexus maintenance only. They charged me $80 for everything. Not a bad deal since the Toyota dealer wanted to charge me $289 even though I told them it was just a drain and fill and not a flush.
  11. willchu
    51
    Northern NJ
    I'm taking my 4 quarts of ATF WS to my local jersey mechanic who works on my family's cars and used to work on my nissan. Any last minute suggestions you can give that I can mention to my mechanic?
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Don't forget two aluminum crush washers for the drain and fill plugs. Good luck!
    willchu likes this.
  13. willchu
    51
    Northern NJ
    Alu washers - check. Hopefully he has a fluid pumper to fill it up from underneath.
  14. usnavystgc
    3,159
    989
    Tucson, AZ
    This may help him. It is for a Gen I but, many of the steps are similiar (sorry, I don't have one for a Gen II).
    The main difference is, you don't have to remove the pan because the magnet is on the drain plug bolt on the Gen II (plus there is no pan).
    After posting this I realized this will probably confuse him more than it helps so I don't recommend even showing this to him.
  15. willchu
    51
    Northern NJ
    It was sure easy. He did it under 30 mins plus slapped on the G7 chassis stabilizer for $25 cash. Toyota dealers can kiss my ____!!!
    usnavystgc, PriusGuy32 and Merkey like this.
  16. Wheelin1
    Wheelin1 Junior Member
    89
    Just did 3 of my 4 pri tonight, my silver car was bought used has 105,000 fluid was dark normal magnet fillings, tan prius was bought used has 83,000 fluid was not as dark normal magnet fillings, red prius was bought new we payed a dealer to change the fluid at 60,000 so this Change was a 60,000 mile change and the fluid was still red but darker than the new fluid. I would Say 60,000 miles is right on.
  17. Wheelin1
    89
    Here is a bill from oemtoyotascion.com
    they have a special on parts purchases now free shipping on $300 dollar sales!
  18. Wheelin1
    89
    Here is a photo of the fluids in ziplock bags! Hope this helps everyone.
    usnavystgc likes this.
  19. gatorglenn
    gatorglenn Member
    138
    45
    Atlanta
  20. Wheelin1
    89
    Yep that's the one.
